#29 |
Do you own one? I do. Do you know of anyone who can recode the transmission controller? I don't. I'm not saying the AT doesn't shift at all. It just won't shift manually, under boost, in my car, tuned with an OFT OTS turbo tune. Techstream only has a few basic options, and I haven't heard of ecutek or OFT having any AT options either. What were these turbo AT's tuned with? Maybe you should only go turbo if you tune with ecutek. I don't use ecutek or anything other than RomRaider and OFT, so I don't know the capabilities of other tuning solutions. I did experience the unresponsive shift paddles numerous times during the month I had my turbo.
#30 |
Drives: 2013 "AVO Orange" FR-S
Then it is an issue with OFT, not with turbochargers. We only tune with Ecutek.
I own a manual, but we've sold over 300 kits worldwide, 28 of them local to the PNW. Several of the local customers have the 6AT, and one has had his 6AT turbocharged for over two years now, I believe. Not a one has come back to us with that issue. I drove one of the 300whp 6AT setups, and it was an absolute blast to drive. And I did use the paddle shifters. |
#31 |
Junior
Drives: a car
and the plot thickens.....to be honest, the whole loosing boost from the turbo to shift vs supercharger is...well ill just let someone else handle that.
#32 | |
Drives: 2010 MS3
#33 |
Junior
Drives: a car
He still wont get it.
| The Following User Says Thank You to cdrazic93 For This Useful Post: | Andrew025 (07-20-2015) |
#34 |
That's right. I won't get it. So long as I use an OFT. I like being able to change my own tunes and get help from others on the forum. I wouldn't get free software, or help changing tunes with ecutek. I'd have to pay for the tunes, the license, and pay to retune it for any hardware modifications I make. the software learning curve is steep, and full access software is very expensive. Open source software is free and people are able to share what they know. Ecutek is costly software, patented, and people could be sued if they share what they know. So, if you know anyone who is boosted, drives an AT, and tunes with an OFT, let me know.
#35 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
I hear that you can only manually shift AT if you remove both your sway bars, seat belts, and get a smaller steering wheel. Then you're totally safe.
What makes you say a AT is somehow stronger than the MT? |
#36 | |
This is going to be the problem with any guide per se, in that it will be put together by a bunch of people that don't necessarily have the same experiences as others. There is a multitude of different turbocharger kits, and each different kit design will have different needs for best performance. For instance, a turbocharger kit based around a large turbo (as in 50+ lb/min of flow) is almost certainly designed around the idea of going e85 or race gas, whereas the "smaller" turbo kits will work better on a pump gas setup. Some kits ship with a fuel pump and injectors, some don't. A turbo kit that doesn't see full boost till much later in the rpm range may not need a clutch at 300whp in comparison to a kit that sees the same 300whp but is generating it's torque peak much, much earlier in the power band. All these variables does make it difficult to post a one size fits all guide. Somebody that lives up in or near Canada is much less likely to need an oil cooler in comparison to somebody living in Nevada. That's why I shy away from the "must get oil cooler" statement. Not to mention that some kits have less cooling needs than others...
#37 |
Drives: 2013 Scion FRS
Thanks for all of the comments.
Still didn't hear any recommendations on internal thresholds or differential. Any thoughts |
#38 |
To a degree, finding the thresholds on the internals is like finding the thresholds on bridges. You keep putting more and more into it until they break. But engines are expensive to keep rebuilding, so...
If you don't want to worry about internals, my opinion is to stick around 300whp on pump gas and 350-380whp. That's not the limit of the engine, that's staying well within the limits of the engine. |
| The Following 2 Users Say Thank You to AVOturboworld For This Useful Post: | airrick (06-04-2020), ShadowReaper (01-01-2018) |
#39 |
Drives: 2015 Subaru BRZ
Don't forget cam block off plate, clamping the PCV solenoid hoses, and upgrading the PCV valve. You should probably plan on learning how to create and interpret data logs too. These are things to consider with any FI on these cars.
#40 |
Drives: 2015 FRS RS1, 93 Supra
Do you think we can get the goals/hp list going?
For example: 250 or less 250-300 300-350 350-400 400+ Obviously is going to vary depending on kits, and I am sure other mods as well. I think this along with the 5,000 +/- thread will help a lot of people out.
| The Following User Says Thank You to erbaker67 For This Useful Post: | D_Thissen (07-23-2015) |
#41 | |
Drives: Series 10 FR-S
| The Following User Says Thank You to raytrix For This Useful Post: | D_Thissen (07-23-2015) |
#42 |
Lol figures I pick the expensive brand haha
| Tags |
| horsepower, planning, threshold, turbo, upgrade, wheressquadroguethesedays |
| Planning on buying a FRS, Need help. | dragonboy221 | Scion FR-S / Toyota 86 GT86 General Forum | 66 | 02-12-2015 05:32 PM |
| Need help: Planning to buy... | duasto | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 09-01-2014 07:10 PM |
| Subaru planning BRZ special edition for United States, still no turbo - report | vh_supra26 | BRZ First-Gen (2012+) -- General Topics | 21 | 03-17-2014 02:47 PM |
| FRS roadtrip planning. | Ludacrits | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 10-16-2013 02:17 AM |
| Planning on buying a new car | rcm47 | Other Vehicles & General Automotive Discussions | 2 | 09-07-2013 03:35 PM |
