Old 10-07-2016, 09:13 PM   #57
tracerit
Drives: '13 SSM BRZ Limited 6MT
I'm not too knowledgeable on suspension parts, picked up the Flex Z because of the adjustable ride quality and it's nice. However I notice that when I'm going 35-40mph and drive over the railroad tracks, the front will make a loud clunk, like it bottomed out. I'm at the Tein recommended height and damper settings. Would there be a way to adjust the coilovers to avoid that clunking? I wouldn't say the railroad tracks are that bumpy either. No other issues driving otherwise.
tracerit is offline   Reply With Quote
Old 10-07-2016, 11:01 PM   #58
bfrank1972
Drives: 2013 FR-S Argento
make sure the top nut on the coilovers is tight, also check sway bar end links.
Sent from my SM-N920V using Tapatalk
bfrank1972 is offline   Reply With Quote
Old 10-08-2016, 12:47 AM   #59
HachiRo
Drives: 2013 White-Out FRS
Originally Posted by HachiRo View Post
Sorry for my noob question, but if base drop is 1.2 inches and I only want my car lowered that much, I wouldn't need to make any adjustments right? Would I have to in the rear still as the rear is usually higher than the front? Or am I mistaken.
Anyone?
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 10-08-2016, 12:57 AM   #60
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Anyone?
You didn't specify what adjustments you were referring to.
shiumai is offline   Reply With Quote
Old 10-08-2016, 01:01 AM   #61
HachiRo
Without adjustments made. For example, setting the pre-load to factory sets and not making height adjustments, would it lower just 1.2 all around as that's the stated base drop? If that's as much as I want to lower it, I wouldn't need to change anything right?
Old 10-08-2016, 01:40 AM   #62
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
yes. make sure pre-load ring is snug not loose.
I slightly increased pre-load from default though.
between 2nd collar ring to bottom collar, it's 28mm on front and 35mm rear.
when i lowered mine, front gap seems little higher than rear. try 25mm or 26mm at front and should be looking similar to rear but i havent adjusted anything yet. lol
I have sti lips around and front lip still doesnt seem like very low enough to scrap anything but if i lower 0.5 inch more, i would scrap everything..haha
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
HachiRo (10-08-2016)
Old 10-08-2016, 02:26 AM   #63
HachiRo
AHHH thanks for the info!
Old 10-08-2016, 12:49 PM   #64
shiumai
shiumai's Avatar
Even if you preset everything I still think you'd have to make minor ride height adjustments, as the car will sit with different weights on each corner, and the chassis itself isn't perfectly symmetrical, especially in the rear (which is why when lowering, you often get different camber from one side to the other which you fix with adjustable LCAs).
The Following User Says Thank You to shiumai For This Useful Post:
zc06_kisstherain (10-08-2016)
Old 10-08-2016, 05:07 PM   #65
zc06_kisstherain
Drives: SWP BRZ
no problem. i am getting alignment next saturday so i will post some pics after. currently sitting front at 28mm and rear at 35mm as default setting from manual.
x 2
Old 10-15-2016, 11:44 AM   #66
zc06_kisstherain
Drives: SWP BRZ
i just got alignment done
HachiRo (10-15-2016)
Old 10-15-2016, 02:52 PM   #67
shattered_memory
Drives: Satin White BRZ Limited
I notice that I got almost a degree of positive caster when I installed the Flex Z coilovers. Steering still felt light even with 245/40/17 tires. i decreased tire pressure to 31 PSI. Steering feels much better, but MPG is slightly suffering lol
shattered_memory is offline   Reply With Quote
Old 10-29-2016, 07:17 AM   #68
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Agree with OP and @CSG_Mike in regards to the 5 from full hard (all round). The install for mine (with EDFC) was finally completed today and I went for a decent drive to feel the difference. Up till this point I drove the car with completely stock suspension, wheels, tires and alignment for 2 years.
Sadly I had to switch the EDFC from auto to manual as, though it was working, it started at an initial 12 (from full hard) and then adjusted down from there depending on G's and road speed. Could not stand it as it made the car ride like a boat.
The flipside was I able to adjust front and rear dampening without ever leaving the car, while stopped (naturally), and it was really educational playing with say 8 front 9 rear and then trying the same setting like 7 all round.
In the end I arrived at 5 all round and then it clicked (for me) as being the sweet spot. The car felt more or less similar to stock only firmer and more planted. I only dropped the car 10mm and had the front camber adjusted to -1. Seeing as I'm still on stock rubber the workshop felt it was a safe setting.
The only negative so far is the steering feels a touch heavier than prior. I'll check tire pressure on the way to work on Monday and see if its still at the usual 35psi and (if so) perhaps try 36 and see if that helps, but I imagine its a side effect of the -1 camber in the front?
Going to take me a while to digest the EDFC manual and start experimenting with settings, which is going to be awesome fun, but I digress.
Speaking to the FlexZ's I think they are great for a daily driver, but the real revelation was coming to the realization that the stock suspension is actually ridiculously good. When my FlexZ's were set too soft I genuinely sat there and thought what a freaking waste of good money, but realized I just needed dial it in more to suit my tastes.
I'll need more seat time to truly appreciate the subtle benefits of the FlexZ's. One pleasant side effect is my stock tires feel like their grip has improved, which would likely be the new suspension doing its thing and keeping the tires in better contact with the road. I see my fuel economy worsening as the improved stability and grip makes me feel more inclined about increasing throttle just about everywhere Orz.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
The Following User Says Thank You to Mim For This Useful Post:
CSG Mike (11-11-2016)
Old 11-08-2016, 01:47 PM   #69
mclovin85
mclovin85's Avatar
Drives: scion fr-s
Originally Posted by Shady195 View Post
Also, for those wondering how low these go...
The fronts are pretty much completely bottomed out in this photo. Only a few more turns to go before you would need to start using the spring pre-load to go any further.
So for those looking for "Super" low, probably not for you.
The rears actually have about another 1" or so of threads left.
Wheels are 18x9.5 with 225/40/18's.. No rubbing issues at all
is this setup without rolled fenders? cause i just got my flex z and will install them this saturday
mclovin85 is offline   Reply With Quote
Old 11-08-2016, 02:17 PM   #70
mclovin85
mclovin85's Avatar
Drives: scion fr-s
screen grab
cant wait to install these >.<
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 04:44 PM
Tein Street Flex Review! Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 04-20-2016 07:56 PM
Tein Street Flex Review and Short Video! RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 04-13-2016 03:17 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
New Tein Street Flex Coilovers - Review and Initial Impressions RallySport Direct Announcements, Contests, Giveaways 6 02-18-2013 01:06 PM
