86WORX
Old 07-16-2015, 02:18 AM   #57
Fastbrew
Drives: 2014 Pearl White BRZ
The stock transmission and axles will cry about this.
Fastbrew is offline   Reply With Quote
Old 07-16-2015, 06:52 AM   #58
EcuTek
Drives: Toyota GT86
Originally Posted by Turdinator View Post
There was talk it lasted 10 full power runs before blowing. This was on an Aussie facebook page though so i doubt people were talking from first hand experience.
We have had the following confirmation from JK Tuning:
'This engine is 100% stock, unopened 2013 FR-S so standard in every way. There is also a rumour going round about it blowing up. It is indeed still running and is 100% healthy.
It has done 12+ pulls at 450 - 690bhp the day of the pictures, with the highest pull being towards the end but not the last. I did two additional pulls in the 630 - 650bhp range after making 693bhp, to back this figure up.'
EcuTek is offline   Reply With Quote
The Following 4 Users Say Thank You to EcuTek For This Useful Post:
DriftinFRS (07-20-2015), GhostOp86 (07-16-2015), Sgtfluffy16 (01-15-2016), Turdinator (07-21-2015)
Old 07-16-2015, 02:23 PM   #59
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I can't see how you could make almost 700whp with a 6266 on 27psi, with an E cover on it as well. At 27psi with mbt timing we make 580-600 on a 6262 with an S cover. Plus larger and way shorter piping than the full blown kit came with, plus the upgraded core. Granted it's at 10:1 compression but I'm sure your timing is less to compensate for compression ratio making everything somewhat similar. I trap 133mph, I'd love to see a trap for this car to back up that dyno number that seems a little exaggerated
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
raven1231 (07-16-2015), Shit Luck (08-13-2015)
Old 07-17-2015, 06:52 PM   #60
JKTUNING
Drives: Civic
We haven't had a chance to get this car to the track. The owner will need a much better set of tires or radials before even attempting that though.
This turbo manifold was the PRL kit that there were only apparently a few of this design made. I didn't do the install; but can get more details of needed.
The compression ratio for sure would have a lot to do with the difference in power vs psi range but to what extent; I can't be sure on this car and the pump e85 fuel we are using.
I am hoping we have some track data to share with you guys soon, but that might not be for a little bit since we are getting the car ready for pick up next weekend.
JKTUNING is offline   Reply With Quote
Old 08-09-2015, 10:50 PM   #61
Shit Luck
Drives: red frs
The bit you failed to mention is that IMW has a dyno that is notorious for reading higher numbers than any other dyno in the area.... they constantly claim numbers that are higher than anyone else.
I know of more than 5 cars that dyno'd there and then made pulls the following day or week elsewhere and were down over 30-70hp. These guys numbers are always suspect at best...
Shit Luck is offline   Reply With Quote
Old 08-10-2015, 09:09 AM   #62
Tim Radley
Drives: GT86, SQ5, RS3
Originally Posted by Fabron757 View Post
This is what 471p feels like with no drag radials on.
A lot of TC cutting in there but it does show that its not spinning the wheels that bad. Doesn't actually sound that quick in fairness considering it's 2.5 times stock power
Tim Radley is offline   Reply With Quote
The Following User Says Thank You to Tim Radley For This Useful Post:
raven1231 (08-10-2015)
Old 08-10-2015, 06:38 PM   #63
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Not trying to be a ****head about this, but they're saying 690BHP, not WHP. Assuming a low 10% parasitic loss, we're still talking low 620-630whp. A more acceptable 15% loss puts us around your WHP level. So technically.. You could have the worlds most powerful setup on EcuTek if you went off BHP ratings, too.
Travisty75 is offline   Reply With Quote
The Following User Says Thank You to Travisty75 For This Useful Post:
WHITE (08-10-2015)
Old 08-10-2015, 08:47 PM   #64
spitfire481
Drives: 2JZ FRS
I highly doubt they have an engine on an actual engine dyno, so I'm not sure how many % they are adding to the bhp number they got. Good eye, I didn't even notice the bhp vs whp discrepancy. I'm also curious on the full fuel setup on this car. We have pushed the stock return-less system to the limit and had to convert to go any further than 550 safely.
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 08-13-2015, 04:06 AM   #65
350z
Drives: 350z
I remember in 2015 where gopros, cameras, and phones that take video were everywhere... Lets see some video!
350z is offline   Reply With Quote
Old 09-03-2015, 01:19 AM   #66
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Got a pull with traction control off? Seems slower than most 300-350whp cars I've seen.
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
Tim Radley (09-03-2015)
e85, ecutek, frs, racerom, world record
Stock, tuned with Ecutek 19eightysix Software Tuning 10 03-23-2015 01:46 PM
P087 Code and Car Dies, EcuTek Tuned, FI---Help! kmbkk Software Tuning 34 04-05-2014 11:53 PM
Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned Visconti Forced Induction 697 11-13-2013 07:18 PM
What is the highest HP/Torque going all motor? Atropine Engine, Exhaust, Transmission 40 10-29-2013 05:45 AM
Worlds fastest BRZ - Accelerated Performance Built - Visconti Tuned !!! Visconti Forced Induction 135 09-06-2012 06:43 PM
