| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
tickle fight referee
Drives: 2015 Subaru BRZ
BRZ traction control won't stay off
Just bot a 2015 subaru brz with about 500miles on it now. Still doing engine break in.
I can turn off traction control (not the sport mode button the other button that says off) at low speeds or a dead stop only. Above 20mph it won't turn off. Sometimes it will only turn off for around 8-10seconds and then turn back on other times it will stay off much longer. Anyone had this experience ? |
also might as well mention - have a slight idle issue - Idle seems like its searching sometimes. It holds at 600RPM the vast majority of the time with slight dips to 500RPM and occasional gains to 700 or even as high as 900. Its tough to tell if headlights or Air conditioning is to blame.
#3 | |
#4 | |
Drives: 2015 WRB BRZ Sport-Tech
Site Moderator
Drives: ichi 86 Project
1. Are you just pushing the TC or Are you holding both VSC & TC til Sports mode is off?
2. Idle issue happens when? When you start it in the morning or...? Cuz if car isn't fully warmed up, it can cause idle issue AC is blasting. |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | tyrantcf (07-13-2015) |
Yea I live down in Houston TX so its fawkn so hot all the time. Puts the AC thru its paces. I am just scared that I might have that stupid idle issue that plagued the first edition models.
Site Moderator
If there is idle issue, you can get it fixed/update the ECU at the dealership
Do you know how long that fix takes to complete ?
About 5 minutes but I doubt that is you problem with a 15.
Not impossible but really rare.
#10 |
ok cool ... at every stop light i find myself just starring at the idle. I am a nervous wreck ... i love my car
#11 |
#12 |
Site Moderator
Any time car need to do extra work (fans, ac, headlight & so on) extra extra power, that causes idle to drop. When extra stuff is off and even with that idle is still dropping, get it checked... but I wouldn't worry too much.
#13 |
Drives: '16 WRX, CBR1000RR
For TC, you need to hold the button down until vsc and traction is off.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
#14 | |
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 01:48 PM |
| Traction control | PolishFrs13 | Issues | Warranty | Recalls / TSB | 14 | 12-30-2014 01:31 PM |
| Traction Control vs. Stabilization Control vs. Sport Question | MurderRider | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-07-2014 12:56 PM |
| Why does my BRZ have LESS traction with traction control on??? | BRZnut | BRZ First-Gen (2012+) — General Topics | 19 | 12-16-2013 03:28 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 11:20 AM |
