#15 |
Drives: Toyota 86 GTS
Isolating the code would be easy. Just take an OFT A01G rom, copy any different tables from a stock A01G to the OFT rom, then compare the two.
Adding handles to the code and finding room for it in the new format roms would be the problem. If it was easy they would have done it as part of releasing the OTS D00 roms. |
#16 | |
Drives: Toyota 86
Original A01G: Code:
ROM:00066344 mov.l #flt_10C524, r6 ; Loads value at 664a4 (10c524) into r6 ROM:00066344 ; 0664a4 hook for lc/ffs ROM:00066346 fmov.s @r6, fr8 ; Loads value at r6 (7450) into fr8 Code:
ROM:00066344 mov.l off_664A4, r2 ; loc_BAD00 ; Loads value at 664a4 (0bad00) into r6 ROM:00066346 jsr/n @R2 ; Jumps to new subroutine at 0BAD00 ROM:00066346 ; Rev limit returned in fr8 Code:
ROM:000BAD00 loc_BAD00: ; DATA XREF: ROM:00066344o ROM:000BAD00 ; ROM:off_664A4o ROM:000BAD00 mov.l @(h'3C,pc), r0 ; Move Immediate Long Data ROM:000BAD02 fmov.s @r0, fr9 ; Floating-point move single precision ROM:000BAD04 mova flt_BAD50, r0 ; Move Effective Address ROM:000BAD06 fmov.s @r0, fr8 ; Floating-point move single precision ROM:000BAD08 mov.l @(h'38,pc), r0 ; Move Immediate Long Data ROM:000BAD0A mov.b @r0, r0 ; Move Byte Data ROM:000BAD0C cmp/eq #1, r0 ; Compare: Equal ROM:000BAD0E bf/s loc_BAD1E ; Branch of False with Delay Slot ROM:000BAD10 nop ; No Operation ROM:000BAD12 fcmp/gt fr9, fr8 ; Floating-point compare greater than ROM:000BAD14 bt/s loc_BAD24 ; Branch if True with Delay Slot ROM:000BAD16 nop ; No Operation ROM:000BAD18 mova off_BAD58, r0 ; Move Effective Address ROM:000BAD1A bra loc_BAD2C ; Branch ROM:000BAD1C nop ; No Operation ROM:000BAD1E ; --------------------------------------------------------------------------- ROM:000BAD1E ROM:000BAD1E loc_BAD1E: ; CODE XREF: ROM:000BAD0Ej ROM:000BAD1E fcmp/gt fr8, fr9 ; Floating-point compare greater than ROM:000BAD20 bt/s loc_BAD2A ; Branch if True with Delay Slot ROM:000BAD22 nop ; No Operation ROM:000BAD24 ROM:000BAD24 loc_BAD24: ; CODE XREF: ROM:000BAD14j ROM:000BAD24 mova flt_BAD54, r0 ; Move Effective Address ROM:000BAD26 bra loc_BAD2C ; Branch ROM:000BAD28 nop ; No Operation ROM:000BAD2A ; --------------------------------------------------------------------------- ROM:000BAD2A ROM:000BAD2A loc_BAD2A: ; CODE XREF: ROM:000BAD20j ROM:000BAD2A mova off_BAD4C, r0 ; byte_0 ; Move Effective Address ROM:000BAD2C ROM:000BAD2C loc_BAD2C: ; CODE XREF: ROM:000BAD1Aj ROM:000BAD2C ; ROM:000BAD26j ROM:000BAD2C fmov.s @r0, fr8 ; Floating-point move single precision ROM:000BAD2E fadd fr8, fr14 ; Floating-point add ROM:000BAD30 mov.l @(dword_14,pc), r6 ; Move Immediate Long Data ROM:000BAD32 fmov.s @r6, fr8 ; Floating-point move single precision ROM:000BAD34 rts/n ; Return from Subroutine with No delay slot ROM:000BAD36 ; --------------------------------------------------------------------------- ROM:000BAD36 nop ; No Operation ROM:000BAD38 nop ; No Operation ROM:000BAD3A nop ; No Operation ROM:000BAD3C nop ; No Operation ROM:000BAD3E nop ; No Operation ROM:000BAD3E ; --------------------------------------------------------------------------- ROM:000BAD40 .data.l RAM_VEH_Speed ROM:000BAD44 .data.l unk_FFF8939B ROM:000BAD48 .data.l flt_10C524 ; Rev limiter ref ROM:000BAD4C off_BAD4C: .data.l byte_0 ; DATA XREF: ROM:loc_BAD2Ao ROM:000BAD50 flt_BAD50: .float 10.0 ; DATA XREF: ROM:000BAD04o ROM:000BAD54 flt_BAD54: .float 2000.0 ; DATA XREF: ROM:loc_BAD24o ROM:000BAD58 off_BAD58: .float byte_0 ; DATA XREF: ROM:000BAD18o |
| Is this a healthy log? D00C | cookiesowns | Software Tuning | 3 | 08-26-2014 05:39 AM |
