Old 07-02-2015, 08:59 PM   #43
civdaddy
Drives: Slow
I can never understand this statement.
How is an engine "boring"? A boring car I get but just the engine? If they put a different 200hp engine in there would it be exciting?
k20a2
civdaddy is offline   Reply With Quote
Old 07-02-2015, 09:01 PM   #44
Originally Posted by civdaddy View Post
k20a2
I think not!
Old 07-02-2015, 09:04 PM   #45
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
k20a2
You wanna change this into FWD car?
Old 07-02-2015, 09:08 PM   #46
civdaddy
Drives: Slow
I was just answering @Tcoat question about there being a more exciting 200hp engine, which I believe there are.
Old 07-02-2015, 09:09 PM   #47
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I'm not real fond of boxer motors from past experience... when it was announced that the 86 would be using a Subaru boxer motor my first reaction was: "Why?" I understand the technical reasons for going with a Boxer motor... but even so, give me an I4 every time over a flat 4. It's not like Toyota doesn't know how to make nice I4 motors perfect for sportscar use.... Was really hoping for a motor somewhat following 4AGE lineage, a nice rev happy one in the 2L range.
That said, I bought the car in spite of the motor that was put in it because even with that Subaru motor in it, I still wanted it - the only car in two decades that I have wanted enough to buy new. The FR-S has been the best Subaru I've ever owned along with being the worst Toyota I've ever owned at the same time... The FA20 is 'okay' as a motor mechanically other than the low oil pressure with high engine bay temperatures (I've noticed little issues start appearing once the oil temp gets over a constant 220F - really want to get an oil pressure gauge for this car.) It has a nice, smooth power delivery characteristic that I do like with a broad torque range that works well for daily driving. From 5K through redline the motor is really at home, just not as rev happy a motor as a Honda.
The little quirks bug me though; the check engine light coming for ignition coil issue (stock motor no tunes or tinkering with it) and little hiccups it has not wanting to start sometimes - it's definitely not a Toyota or Honda level drivetrain in actual execution. I would definitely feel more at ease with an actual Toyota motor in it... My 2RZ powered Tacoma was bulletproof and I beat on it and redlined it daily for 170k miles...autocrossed it, tracked it, offroaded it, and cruised cross-country with it.
And then there was the B18A in my '90 Integra RS....sweetest non-vtec I4 Honda motor that can take abuse and has a very nice rev-happy characteristic about it. With 8lb racing flywheel that motor LOOOVED to rev and increased/decreased RPMs extremely quick. It was a solid motor that you could use the full RPM range all day long, for 200k miles...and sounded very good as well.
The FA20 just can't take the same abuse...it throws a fit and starts balking, you have to baby it to keep it happy. Babying a motor to keep it from throwing fits doesn't sit well with me...I don't care about power levels as much as a robust motor you can beat on daily and gives zero complaints back - the FA20 is not such a motor from my experience. Or maybe it's just the early one's issue?
Not sure what I want to do in the future, but I absolutely know I want to keep the car. Just unsure of what to swap out the motor for when the FA20 finally lets go from not being up to the task...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
frsvr4 (07-06-2015)
Old 07-02-2015, 09:10 PM   #48
Iand518
Iand518's Avatar
Drives: 2013 asphalt fr-s
Years ago when I heard Toyota was working on the small sports car (FRS) my fear was the they would use the 2AZ-FE (I4 from Camry/RAV4) engine, 6500 rpm red line, 177 hp in RAV4 trim. IMO Toyota made a good decision going to Subaru for a engine. If you've every wound the RAV4s AZ engine to redline you'll agree. The Toyota AZ is tough as nails, but sounds like bees in a box to me.
The Subaru engine feels like it loves spinning all the way to redline all the time. Bottom line, I like the Subaru boxer, "REAL" or not.
Iand518 is offline   Reply With Quote
The Following User Says Thank You to Iand518 For This Useful Post:
strat61caster (07-02-2015)
Old 07-02-2015, 09:14 PM   #49
ichitaka05
Site Moderator
ichitaka05's Avatar
I would of said 3S SR or F20
coil #1 or #3?
Old 07-02-2015, 09:18 PM   #50
civdaddy
Drives: Slow
I would have said an f20 as well, but I was being fair with the "200hp" comparison.
The Following User Says Thank You to civdaddy For This Useful Post:
ichitaka05 (07-02-2015)
Old 07-02-2015, 09:21 PM   #51
That is a sample maybe but still does not reduce my confusion over how just and engine is more exciting. An engine is just part of a whole package not the be all and end all of a car.
Old 07-02-2015, 09:21 PM   #52
Vracer111
Vracer111's Avatar
coil #1 or #3?
P0351 code... so coil #1. Going to get newest revision coil pack and do whatever I can to get heat out of the engine bay along with protecting all the coils thermally. Gold foil tape, heat shielding, ducting with active airflow, and making the TRD fender vents actual functional vents in addition to their primary aerodynamic deflector role is where I'm heading...
Tcoat (07-02-2015)
Old 07-02-2015, 09:25 PM   #53
ichitaka05
Site Moderator
ichitaka05's Avatar
P0351 code... so coil #1. Going to get newest revision coil pack and do whatever I can to get heat out of the engine bay along with protecting all the coils thermally. Gold foil tape, heat shielding, ducting with active airflow, and making the TRD fender vents actual functional vents in addition to their primary aerodynamic deflector role is where I'm going...
I've heard that issue with aftermarket header &/or FI, but never heard that issue w OEM.
Old 07-02-2015, 09:34 PM   #54
Vracer111
Vracer111's Avatar
Plenty of stock cars with this issue reading the massive P0351 issue thread....it will happen to all 86's given enough heat in the system. I live in a really hot & humid climate, so I imagine that accelerates things too along with oil temps reaching 220+ range daily...
Old 07-02-2015, 09:37 PM   #55
Vracer111
Vracer111's Avatar
Why would you think Camry motor and not a newer version of this?
[ame="https://www.youtube.com/watch?v=sbXTAI_guvk"]4AGE 20v Blacktop 110mm Open Trumpets At Full Throttle - YouTube[/ame]
Ultramaroon (07-03-2015)
Old 07-02-2015, 09:44 PM   #56
Iand518
Iand518's Avatar
Priceless! A Camry with velocity stacks. Does that make the bees sound louder?
stupid thread
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 08:44 PM
Toyota/Subaru D4S "engine cover" rattle canadaRS1.0 Issues | Warranty | Recalls / TSB 4 06-14-2015 08:12 PM
Are there varying levels of engine leaks? Apparently this isn't considered a "leak" tracerit Issues | Warranty | Recalls / TSB 9 05-26-2015 05:02 PM
2015 Series.Blue Engine "Chirp"and 2nd Gear Grind s30series Issues | Warranty | Recalls / TSB 33 09-07-2014 02:26 AM
"Hot" smell coming from engine after latest OpenFlash - 1.59 Kody Software Tuning 25 04-15-2014 06:07 PM
