| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
Corn Juice
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
#16 |
Drives: 2015 CWP BRZ Limited
I would also get some way of reading oil temperatures and pressure, if you think that's the culprit. It'd be putting the cart ahead of the horse to install an oil cooler without actually knowing what your oil temperatures are.
In lieu of dedicated gauges, any number of the Bluetooth OBDII readers and the Torque app will let you see what's going on for under 30 dollars. |
#17 |
Drives: WRB BRZ
decals, definitely decals.
#18 |
#19 |
Seņor Member
LS swap /thread
#20 | |
a lot of these non-aesthetic mods can really do wonders. |
| The Following User Says Thank You to mixxxx For This Useful Post: | strat61caster (07-02-2015) |
#21 | |
Drives: 2014 BRZ Limited
I run Torque almost all the time with a first gen Galaxy Note phone set up as a dedicated engine computer. I have water temp and oil temp gauges set up on it side by side. It usually stays below 220° unless I drive with the RPM up above 4K or 5K for an extended period of time. I seriously doubt any of us really need an oil cooler if we're not tracking the car. |
#22 | |
#23 |
Drives: 2014 Silver BRZ Limited
Cool. Thanks for the suggestions. I like the idea of the BT ODBII reader for reading stats.
I'm saving for blizzaks now. TSW wheels and Michelin PSS, along with DBA rotors, Motul 600/660, SS lines all next year... Just started my job here in the D. I'll probably do redstuff pads and a master cylinder brace this year since it's not too expensive. As for bone stock tunes/flasher systems that are flexible enough to have stepped and reliable tunes as you add things like air intake, catless header, etc.; what do you guys recommend? |
#24 |
The Fail Boat
Drives: CWP S.B.
Do it slow, learn the car. & add things that you feel it's lacking on track 1by1
Brake pad is a very good start. |
| The Following User Says Thank You to chaoskaze For This Useful Post: | strat61caster (07-03-2015) |
| all season high performance or winter performance tires? | Aloxi | NY / NJ / CT / PA | 29 | 03-24-2015 10:23 PM |
| Excelerate Performance: Your Northeast Performance and Installation Center | ExcelerateRep | NY / NJ / CT / PA | 40 | 07-22-2014 06:55 PM |
