#15 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
If you're free today I'm home if you'd like to help me. If so PM me and I'll give you my info. If you're not free then no worries.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#16 |
fabulous
Sorry, I'm in the middle of installing new struts in my wife's camry.
These are the coil packs. You'll recognize what I'm calling the frame rails when you locate the coil packs on your engine.
#17 | |
Just the tip
Does this mean I have a bad coil pack? If so why would it have failed back on the morning of July 1st, then be ok up until this morning?
#18 | |
fabulous
99.5% of the time, intermittent failures are cracked solder joints or other component connections that move relative to each other during expansion and contraction of thermal cycling.
Last edited by Ultramaroon; 07-06-2015 at 01:19 AM. Reason: Read the damn codes, stupid. |
#19 | |
Just the tip
Could it also be a fried spark plug? and is the spark plug inside the tube where the coil pack is and to get to the spark plug I'd need to remove the coil pack first? Should I change both? All this makes me wish my debt was paid off and I have my BMW i3 still. I'll be getting an electric car for sure after I pay my shiz off.
#20 | |
fabulous
If the car had 100 Kmi then I would recommend replacing all 4 because they are like light bulbs. They have a certain life expectancy, give or take. In that case, I might just go with some aftermarket ones.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | stockysnail (07-05-2015) |
#21 | |
fabulous
When I replaced the coil packs on my daughter's Acura, I pulled one of the iridium-tipped plugs just to check. At 150K, it was practically new.
#22 | |
eg p0200 subaru. they are for injectors o2sensors heater circuits. i think you have an electrical problem crook or dying battery or crook alternator causing voltage fluctiuations rearly weird stuff happens in modern cars if voltages not stable. or you have a intermittent short in wirinig to 02 sensors maybe melted ect check your fuses for 02sensor heater circuits, check the 02 sensors are actually plugged in correctly. |
#23 | |
eg p0202 subaru. they are for injectors o2sensors heater circuits. i think you have an electrical problem crook or dying battery or crook alternator causing voltage fluctiuations rearly weird stuff happens in modern cars if voltages not stable. check earth connections check battery and alternator connections, measure volts when car is running should be stable 14 v or close to that. or you have a intermittent short in wirinig to 02 sensors maybe melted ect check your fuses for 02sensor heater circuits, check the 02 sensors are actually plugged in correctly. |
| The Following User Says Thank You to steve99 For This Useful Post: | Ultramaroon (07-06-2015) |
#24 | |
fabulous
Oh, if the codes don't point to a simple misfire, then, yeah. I wouldn't go for the o2 sensor because that wouldn't cause a single cylinder misfire. A dead injector or driver circuit would correspond to a dry misfiring cylinder which would drive the o2 level high because it's just an air compressor. ...probably not the igniter. -____-
#25 |
Just the tip
I don't think I've ever changed a coil pack or distributor before, only spark plugs. We shall see if I can find one tomorrow at a dealer, get my tools up there and get the new one in. It's really tight.
Checked the battery and it has the correct voltage. Checked all the wires on the o2 and maf and various other areas like coil packs and they all look tight and stable. I'll check the fuses inside the cabin and let you guys know if I see anything amiss. Would you say don't drive my car until I get the new one installed? Wondering if I should drive it to get parts and to work or work from home.
Past (sold): Click here to see previous cars and bikes ![]() Last edited by stockysnail; 07-06-2015 at 12:08 AM. |
#26 | |
fabulous
P0202 is a dead giveaway and fits with the misfiring cylinder. Injector or circuit.
#27 |
fabulous
@steve99, are there fuses for each injector driver or is it just one fuse?
If there's just one fuse, I'm going to suspect bad port injector. Swap #2 and #4 injectors and see if the code changes to a P0204.
#28 | |
Just the tip
| unichip p0172 engine code | bvelna | Software Tuning | 16 | 08-13-2016 09:45 AM |
| P219A ENGINE CODE | Albaro08 | Issues | Warranty | Recalls / TSB | 6 | 12-29-2015 06:15 PM |
| P0328 Engine Code | Lil Abner | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 10-23-2014 01:10 PM |
| Engine Code: P0172 P117B | *KID* | Engine, Exhaust, Transmission | 2 | 01-25-2013 05:23 PM |
| check engine/CEL/DTC/MIL code list | arghx7 | Engine, Exhaust, Transmission | 3 | 07-04-2012 11:37 PM |
