86WORX
Old 06-23-2015, 07:29 PM   #29
D K
Stig's dark passenger
I want to see it
This is all Im able to show since the rest of our conversation was not something Im willing to share.
David
If possible please use a serpentine, since all our testing is done with this
type of belt.
As long as timing is not required we recommend s-belts for many reasons.
D K is offline   Reply With Quote
The Following 5 Users Say Thank You to D K For This Useful Post:
ATL BRZ (06-23-2015), ck-GT86 (06-23-2015), CSG Mike (06-23-2015), themajesticone (06-23-2015), zc06_kisstherain (09-21-2015)
Old 06-23-2015, 10:55 PM   #30
slipdog
slipdog's Avatar
Drives: 2013 WRB BRZ
Originally Posted by themajesticone View Post
@slipdog
You can also argue that the fact they specifically put,
"Not following these specifications voids warranty and may result in permanent damage of the supercharger system and/or other systems in the vehicle/application"
...explicitly states it is highly not recommended as well as discouraged because of the above said repercussions.
Not really. If you look at the specifications, the only ones mandatory are things like bolt pattern/spacing, shaft diameter, depth, etc. So there is no explicit statement about cogged or not. If your pully is too fat or the diameter is too big, then yes. But you could make a cogged belt that fits their specifications and it will not void the warranty. Causing damage is unknown.
slipdog is offline   Reply With Quote
Old 06-23-2015, 10:58 PM   #31
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
Originally Posted by John92 View Post
I drove from WA to FL no oil cooler and the only problem I had my whole trip was due to bad fuel. I have not snapped a belt yet, and you should run clogged idler pulleys just saying.
that's a long ass drive
Sammakko is offline   Reply With Quote
The Following User Says Thank You to Sammakko For This Useful Post:
Sportsguy83 (09-21-2015)
Old 06-23-2015, 11:02 PM   #32
themajesticone
themajesticone's Avatar
Drives: '13 UM86
You are clearly missing it and ignoring the words right in front of you provided above....
It is plenty clear and there is no room for confusion or doubt.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 06-23-2015, 11:20 PM   #33
Fastbrew
Drives: 2014 Pearl White BRZ
Wow - OP - so sorry you are dealing with an issue like this. What a total buzzkill. GL in your effort to get a stable ride.
Fastbrew is offline   Reply With Quote
Old 06-24-2015, 12:35 AM   #34
enivid
enivid's Avatar
Drives: WRB JR BRZED
Originally Posted by KraftWerks View Post
Please show us where Rotrex doesn't recommend the cogged system?
What is your hypothesis on why your kit tends to breaks belts? All user error or a design problem?
enivid is offline   Reply With Quote
The Following 2 Users Say Thank You to enivid For This Useful Post:
Apoc (06-24-2015), ck-GT86 (06-24-2015)
Old 06-24-2015, 03:26 AM   #35
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'm assuming this is rhetorical?
Old 06-24-2015, 05:00 PM   #36
s0sl0w
Proud of Boxer
Seems like KW could resolve this easily enough by offering or changing the kut to a ribbe belt. However the shock explanation makes a hell of a lot of sense to this engineering student. Damn shame that kraftwerks doesn't seem to want to recognize the issue either as I believe they honestly have the superior tubing route.
s0sl0w is offline   Reply With Quote
Old 06-24-2015, 05:14 PM   #37
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Originally Posted by s0sl0w View Post
... as I believe they honestly have the superior tubing route.
Please elaborate; from what I've observed the charge piping on both the JR and KW kits follow the same route.
From the SC outlet they both route the piping under the driver's headlight down around the washer fluid reservoir with a bend feeding the intercooler and then back up under the opposite headlight and onward into the intake manifold.
Old 06-24-2015, 05:38 PM   #38
Andrew025
Andrew025's Avatar
He's probably talking about the curve right before the TB, although it isn't as drastic a curve as many people think.
The Following User Says Thank You to Andrew025 For This Useful Post:
s0sl0w (06-24-2015)
Old 06-24-2015, 05:41 PM   #39
s0sl0w
Proud of Boxer
That's exactly it, I'd also like to see the j/r utlize a more sealed filter. I can fix the filter quibbles myself. Not much I can do about the curve ahead of the TB.
Old 06-24-2015, 05:50 PM   #40
ATL BRZ
Driving Coach
ATL BRZ's Avatar
The air in that curved inlet tube has already been metered by the MAF and most tuners use a speed density hybrid tune using the MAP sensor in the manifold past the TB so not sure what his point is.
After looking at the dyno comparisons between the kits and understanding how they both measure airflow and manifold pressure again I don't see anything superior about the routing of the KW kit's charge piping.
Did you know that CSG has measured and logged intake air temperatures to be lower than stock with the JRSC kit? It's not hindering performance in any way having the air filter exposed in the engine bay. Intercooling takes care of all those concerns. The filter gets fresh air through the same opening that the stock airbox snorkel does at speed.
If you're really that worried about it and have money to burn then you can buy what Pure made for the Vortech kit. Should be relatively easy to adapt or put your own together.
Old 06-24-2015, 06:02 PM   #41
s0sl0w
Proud of Boxer
If you looks at the exhaust data, the Kraft kit makes almost all of the power of the JR but is doing it with a cat back and 2 cats in play vs the JR car having no cats and "full exhaust" (header?). Since the tuner and gas was the same and they use the same blower that pretty much leaves the tubing. Kraft has placed the blower and filter better (more efficiently) but then fucked it all with belt/pulley setup. Ideally a Kraft kit with non cogged pulleys/belt would be the best I'd hazard.
Old 06-24-2015, 06:17 PM   #42
Andrew025
Andrew025's Avatar
Exhaust setup doesn't make that much of a difference with a SC setup anyway, not like a turbo at least.
I don't think the tubing will make much of a difference either.
forced induction, kraftwerks, supercharger
Wtb: kraftwerks supercharger darnbry Want-To-Buy Requests 1 08-31-2014 03:04 PM
F/S Kraftwerks supercharger kit captain_jack Engine, Exhaust, Bolt-Ons 27 06-10-2014 11:34 AM
Kraftwerks Supercharger kit-Now stocked at JRP Stav Canada Classifieds 4 05-27-2014 10:07 PM
KraftWerks SuperCharger Ocho Seis CANADA 18 04-06-2014 11:33 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
