86WORX
Old 08-23-2015, 09:55 PM   #113
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Originally Posted by solidONE View Post
^glad to hear I'm not the only one. lol
Is 1mm of deflection all that significant in terms of effect on braking performance or feel?
moar graphs!
I could definitely feel a difference during daily driving - I'm surprised that difference was about 1mm!
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
JS + BRZ (08-27-2015)
Old 08-27-2015, 05:50 PM   #114
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Things have been slightly chaotic with the acquistion last week, but we're still chugging along. We're basically folding two shops into one, so there's lots of work to be done. We're getting ready for the open house this Saturday, so we've been getting the BRZ all prettied up.
I've had "rewire auxiliary electronics" on my agenda for a while now, and finally got around to it. We bought a Painless fuse block, and installed it in the glove box, along with an Innovate LC2 and a generic hourmeter.
Ran the wires through the firewall, and added them to the battery clamp:
Found a nice little ground spot in the passenger footwell, just forward of the door:
We're in the middle of an alignment and cornerbalance, and then we'll wire up the dash tomorrow morning. We'll be running the Velox undertray and splitter this weekend, but since we'll be doing ride-alongs on the 3.1 mile course, we won't have any useful lap time information.
We will have the Aim Smartycam running, so if any forum members lose their lunch or scream like little girls, we'll have evidence.
GSpeed is offline   Reply With Quote
Old 08-27-2015, 07:33 PM   #115
philooo
Drives: 13' Scion FRS Track car
very high quality work as expected !
What is the hour meter thingy for ?
Can you tell us how it is wired in general ? I mean I see 2 red cables, are these the one going to the battery terminal ? and they split into two relay, then relay go into the fuse box ?
I hope you guys are going to make a master cutoff switch, I am still waiting for something professional to be documented around here !
I am just about finished with my car so I'll be getting in the electrical stuff very soon, I'll PM you next week. If Hurricane Erika doesn't wipe me out of the map
philooo is offline   Reply With Quote
Old 08-27-2015, 08:16 PM   #116
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
What's this ride-along stuff you speak of? I'll be running the 3.1 on Sept 19th weekend. Hopefully my Velox front splitter comes in soon so I'll have time to drop off my car for an alignment and suspension setup by you guys.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 08-27-2015, 08:50 PM   #117
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
The hour meter is just a different way of keeping track of maintenance. For a purpose-built track car, an odometer isn't quite as useful anymore. Like, we've got 450 miles on the car, and we're on our fourth set of brake pads.
The two big red wires are running to the battery. Each one has a 40A fuse, and is switched by one of those two relays. The pink wire is hooked up to an "ACC-ON" line to activate the coils of the relays based on key position. That way we can run the dash and everything else on their own fused circuits without having to tap into the OEM harness.
Let me know if there's anything we can do to help! We'll be redoing all the wiring and such when we do the cage.
We're hosting a DFW meet at our shop on Saturday! Dave will be giving rides in our car on the 3.1 in the morning, then we're doing a mini DE in the afternoon.
http://www.ft86club.com/forums/showthread.php?t=92586
Old 08-27-2015, 10:29 PM   #118
philooo
Where did you tap into the ACC-ON ? did you go all the way up to the steering column ? or one of the fuse boxes (under hood/driver footwell) ?
I only need one line "always on" for my SPOT GPS transmitter, for everything else I think your setup look great.
Old 08-27-2015, 11:38 PM   #119
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Probably going to go off of the radio, we've still got a full interior.
Jake
Old 08-28-2015, 09:01 AM   #120
philooo
I think the connector d29, called optional connector , which is a loose plug behind the radio offers easy access to switched power
The Following 2 Users Say Thank You to philooo For This Useful Post:
DustinS (09-04-2015), toast (02-19-2016)
Old 08-30-2015, 09:42 AM   #121
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
We had a great time with everyone yesterday at the FT86Club.com meet. It's always nice to put faces to the names we see on here. Hopefully we made some racers out of everyone!
The Following 5 Users Say Thank You to GSpeed For This Useful Post:
Bramick (08-30-2015), civicdrivr (08-30-2015), JS + BRZ (08-30-2015), philooo (08-30-2015), Tristor (08-30-2018)
Old 09-03-2015, 02:22 PM   #122
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Today we went out on the Whiteline bars and PFC Race pads. Our tires are pretty used up, so times didn't improve overall. But by looking at the time comparison, you can see the transient behavior of the car is noticeably improved.
Here's a look at the braking performance. This is the first braking zone on into Rattlesnake, decelerating from about 102 mph down to 55 mph. The traces have been shifted slightly (about 20' or so) to line up the exact moment brakes were applied, but you can see the PFC Race pads (blue trace) require less pedal pressure to get a faster deceleration rate. More importantly, that behavior was maintained throughout the session.
Unfortunately, I didn't get video from this session since I pulled the memory card out too soon. We'll be going out again tomorrow morning, this time with more camber.
Summary
Configuration: RCE Tarmac 2 Coilovers, PFC Race Pads, Whiteline 22mm/16mm ARBs
Best Lap: 1:26.4
Race pads are better, anti-roll bars are stiffer.
The Following 2 Users Say Thank You to GSpeed For This Useful Post:
Jonsey (09-03-2015), solidONE (09-04-2015)
Old 09-03-2015, 03:13 PM   #123
philooo
interesting , which PFC pads number are you using ? I used to have the PFC01 on my previous car and really liked them for HPDE.
Old 09-03-2015, 04:37 PM   #124
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
We're running PFC08 front, and PFC13 rear. They recommended that pad combination based off a series in Japan that requires stock rotors. Seems to be a great setup so far.
Old 09-03-2015, 08:51 PM   #125
Lee
Drives: GT86
Did you find that the car was too oversteery with the 22/18mm bars? Feel better now with the 16? (I've 22/18 but not tracked with bars yet, only been out on stock up until now)
Lee is offline   Reply With Quote
Old 09-03-2015, 10:16 PM   #126
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Yes, it was a little too tail-happy mid corner. Transitions were great, obviously, but steady-state corners were all over the place. Could be a good setup for autocross or a really tight, technical track, but on our medium-speed track, we need better steady-state.
The Following 3 Users Say Thank You to GSpeed For This Useful Post:
Bramick (09-03-2015), Lee (09-04-2015), Tristor (08-30-2018)
North East Track/AX - what did you sign up for? dp1 NY / NJ / CT / PA 42 10-18-2016 12:51 AM
Ohio Track Day - Nelson's Ledges 2015 mcquarrieg Great Lakes 24 08-04-2015 04:43 PM
Bar & Track - 2015 Subaru WRX Review FT-86 SpeedFactory FR-S / BRZ vs.... 71 05-26-2014 01:08 AM
