Old 11-14-2016, 12:27 PM   #337
acpstunts
Drives: 2013 FRS
Any update on how the new oil pan performed? Any correction to the oil pressure concern? Also how much oil exactly did it add to the capacity? Thanks!
Build Thread:http://www.ft86club.com/forums/showthread.php?t=109277
IG: acpstunts
PSN: e46drvr
acpstunts is offline   Reply With Quote
Old 11-14-2016, 12:35 PM   #338
Jonsey
Jonsey's Avatar
Originally Posted by GSpeed View Post
I can't find the numbers now, but I was happier with the brake bias numbers I was seeing with the Endurance kit when paired with slicks with a higher coefficient of friction. We also want the brake duct capabilities we'll get with the endurance kit since the car will be racing competitively with a supercharger.
Very interested to see what you come up with for brake ducting. I played with trying to duct my endurance kit a bit but couldn't come up with a path I liked with the large hose. Also interested to hear what you think of the pads.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 11-14-2016, 02:02 PM   #339
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
It didn't fit. It hit the OEM exhaust manifold in a few places, so we never ran it. Not happy about that, but looking at how the drains were identical to OEM, I doubt we'd see any improvements in oil pressure.
I corrected my previous post, the pad information was wrong. We're running Ferodo DS1.11s in the front, and the same PFC 13s in the rear. Going to try and get PFC to make/sell us some pads for these calipers in 13s, I think. I'll let you know what we find for duct routing. May wind up making something off the fog light housings, since we don't need window washers anymore.
Jake
GSpeed is offline   Reply With Quote
Old 11-14-2016, 04:33 PM   #340
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
The driver is complaining that the car feels very "jittery" over disturbances in the track. Naturally, I'd guess that's due to the fact that the Tarmac 2s don't have a high-speed blow-off, or digressive valving, or however you want to phrase it. Basically, the damping curve is approximately linear. Higher-end shocks actually lower the rate at which damping force rises at higher speeds, which means the car is able to absorb high speed impacts (curbs, bumps, etc) without upsetting the chassis.
So, let's see how that looks in the data. Here's a plot from the MXL2 in the BRZ, showing left rear shock position (on top) and velocity (on bottom).
And, for comparison's sake, here's the left rear shock of a Viper GTS with Penske 8765s traversing the exact same disturbance on the track:
Both graphs are scaled the same in the Y axis, and the X axis lines are 0.5s on both graphs. So you can see the Viper shock gets the oscillation under control much faster and smoother.
Not trying to say the answer is a set of $15,000 shocks, but this is a great example of why digressive valving is so important on a track car.
The Following 6 Users Say Thank You to GSpeed For This Useful Post:
BigFatFlip (11-15-2016), DarkSunrise (11-17-2016), Jonsey (11-14-2016), Lonewolf (11-16-2016), MaximeT (11-15-2016), Tristor (08-30-2018)
Old 11-15-2016, 05:58 AM   #341
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Thank you, I want a shock sensor now :/
Great work.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
The Following User Says Thank You to MaximeT For This Useful Post:
GSpeed (11-15-2016)
Old 11-17-2016, 11:57 AM   #342
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Here's some temperature plots from our sessions last Friday. As you can see, differential temperature is rapidly approaching unsafe levels. Most evident in the longer, first session it ended the 20 minute session at 275°F, after starting at about 110°F.
Considering we're still at stock power levels, this is pretty concerning. We'll need to do something about that.
This is also great evidence of why data systems and good sensors are important. Considering this is a lightly modified car, on a cool day, and differential fluid is still reaching 275°F, I'd bet money most people without rear end coolers are toasting their fluid and not even realizing it. It's too soon to say, but it could have something to do with the axle failure issues if the diff is overheating on a regular basis.
The Following 11 Users Say Thank You to GSpeed For This Useful Post:
BatStig (11-17-2016), DarkSunrise (11-17-2016), DocWalt (11-17-2016), Guff (11-17-2016), ichitaka05 (11-17-2016), Jonsey (11-17-2016), lamawithonel (11-17-2016), MaximeT (11-18-2016), new2subaru (11-17-2016), TofuJoe (11-21-2016), Tristor (08-30-2018)
Old 11-17-2016, 02:02 PM   #343
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Quite concerning. Do you think a high capacity dif cover could solve the issue or are we going to need to go all out with a cooler kit?
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 11-17-2016, 02:22 PM   #344
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Thanks for the data. Now, I know why all Super Taikyu & other 86/BRZ race in Japan uses dif cooler in ALL of em.
Old 11-17-2016, 04:33 PM   #345
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
A larger fluid capacity, for any system, just slows the temperature rise by increasing the thermal mass. As you increase the heat input (more power) or duration (longer sessions) the temps will climb faster. So, yes, higher capacity diff covers help, but they're not addressing the root cause of more heat being generated than the system can dissipate. With a proper cooler system, you can run indefinitely without overheating since all the heat generated can be rejected. I know that's a long answer to a short question, but hopefully it helps.
Yep. We're going to try and find a way to do a mechanical pump. Electric pumps aren't all that reliable in comparison.
The Following User Says Thank You to GSpeed For This Useful Post:
BatStig (11-18-2016)
Old 11-17-2016, 04:41 PM   #346
ichitaka05
Site Moderator
ichitaka05's Avatar
CS-v3 have one too... but not sure it's mechanical or electric pump.
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
BatStig (11-18-2016), GSpeed (11-18-2016)
Old 11-18-2016, 02:44 PM   #347
Takumi788
JHerbert Racing
Takumi788's Avatar
Sorry if I am taking away from your build thread but you seem like the people to ask. I have done some research on the diff matter and found myself with a few questions.
1) At what fluid temperature can damage to the diff occur?
2) What is the optimal operating temperature for 75w-90?
I was only able to find this data on Motul 300 75w-90 which leads me to believe any higher that 212 degrees Fahrenheit starts getting dangerous. Is that an accurate statement?
PROPERTIES
Viscosity grade SAE J306 75W-90
Density at 20°C (68°F) ASTM D1298 0.897
Viscosity at 40°C (104°F) ASTM D445 72.6 mm²/s
Viscosity at 100°C (212°F) ASTM D445 15.2 mm²/s
Viscosity index ASTM D2270 222
Flash point ASTM D92 200°C / 392°F
Pour point ASTM D97 -60°C / -76°F
Old 11-18-2016, 03:49 PM   #348
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
PROPERTIES
No problem! I wouldn't say 212°F is a dangerous threshold, no. Generally you'd consider that an operational minimum, since at temperatures above that water that's collected in the oil (through condensation, for example) will boil off.
Generally the gear manufacturer will provide the operational limits if there are any specific ones. For example, Emco lists a maximum temperature of 330° for 15 minutes, or something close to that (going off memory). Anything above, or longer, than that will alter the case hardening of the gears and can cause permanent damage. Granted, that's an Emco and it's abnormally durable.
If our diff never got above 275°, I would be a happy camper. But from the data posted above, I don't think that's going to happen.
Old 11-18-2016, 04:00 PM   #349
Pat
Pat's Avatar
Drives: 2023 BRZ
So basically if a normally aspirated BRZ never runs more than 20 minute sessions we shouldn't be too concerned, right? But if we go longer than that it we should consider a cooler?
The Following 2 Users Say Thank You to Pat For This Useful Post:
BatStig (11-18-2016), Takumi788 (11-18-2016)
Old 11-18-2016, 04:23 PM   #350
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Yes, that's the gist of it. There are lots of variables like tires, power, outside temp, etc. but generally yes.
The Following 4 Users Say Thank You to GSpeed For This Useful Post:
BatStig (11-18-2016), Pat (11-18-2016), Takumi788 (11-18-2016), Tristor (08-30-2018)
North East Track/AX - what did you sign up for? dp1 NY / NJ / CT / PA 42 10-18-2016 12:51 AM
Ohio Track Day - Nelson's Ledges 2015 mcquarrieg Great Lakes 24 08-04-2015 04:43 PM
Bar & Track - 2015 Subaru WRX Review FT-86 SpeedFactory FR-S / BRZ vs.... 71 05-26-2014 01:08 AM
