#225 | |
Drives: 2015 BRZ
We're using 1.75" x 0.095" DOM. It's stiffer than 1.5" x 0.120" tubing for a given length, although it is slightly heavier. The main reason, though, is common tooling. This will allow us to make cages for heavier cars (over the 3200lb limit) out of 1.75" tubing using the same bender tooling, which is very expensive. So in short, it's for ease of production down the road. Thanks for the tip on the zip ties. Those look slick. Jake |
#226 |
Drives: 2015 BRZ
#227 | |
Drives: Still deciding
The question remains.... Did they solve the hear soak issue that we see with most FI systems (think Texas heat) or find a solution that would be good enough.... |
#228 |
Drives: Asphalt 2015 FRS
Subbed. Love the details of this build. Even though I don't have plans to go full racecar, I still enjoy the data on the parts you do use to know what I should be looking for as I continue to add to my car.
Thank you for the time you have taken to compile all this information, and know it is very much appreciated! |
#229 |
Drives: 2015 BRZ
| The Following User Says Thank You to GSpeed For This Useful Post: | stoked_on_spool (11-24-2015) |
#230 |
Favourite thread on forum. I'm nerding out so hard on all the data. Sub'd.
#231 |
Drives: 1980 corvette, 2014 Subaru BRZ
also nerding out on the data, and that they are near me!
#232 |
Drives: 2015 BRZ
Thanks for the kind words, guys. Feel free to stop by the shop and check us out any time!
We got a little more work done on the cage design. The basic beam structure is pretty much there. ![]() We also did some torsional analysis, which is detailed in the cage thread in the HPDE section. ![]() http://www.ft86club.com/forums/showthread.php?t=97715 |
| The Following User Says Thank You to GSpeed For This Useful Post: | solidONE (11-20-2015) |
#233 |
Drives: FR-S Whiteout
No 4130 tubing for the shop car?
Intent > Content
cowardice is the mother of cruelty. |
#235 |
Drives: 2018 Subaru BRZ
Sub'd! Love the R&D
On my fourth 86... and everything in between
| The Following User Says Thank You to Scracho For This Useful Post: | GSpeed (11-23-2015) |
#236 |
Drives: 2015 BRZ
Quick teaser before the holiday weekend.
| The Following 6 Users Say Thank You to GSpeed For This Useful Post: | civicdrivr (11-29-2015), DocWalt (12-27-2015), mrk1 (11-25-2015), philooo (11-25-2015), stoked_on_spool (11-25-2015), Tristor (08-30-2018) |
#237 |
Drives: 13' Scion FRS Track car
now that you are talking about seats
![]() I just mounted a passenger seat today in my car... what a pain, I used the Planted plate to attach the seat to the OEM bolting point. And I also did not use slider to keep them as low as possible, but then the seat is too far to the front. What are you going to use to mount the seats ![]() The head clearance prohibit using sliders if you are above 6 feet tall. Looking forward to your seat mounting options
2013 Scion Frs Track Car - Sold.
#238 | |
Drives:
| North East Track/AX - what did you sign up for? | dp1 | NY / NJ / CT / PA | 42 | 10-18-2016 12:51 AM |
| Ohio Track Day - Nelson's Ledges 2015 | mcquarrieg | Great Lakes | 24 | 08-04-2015 04:43 PM |
| Bar & Track - 2015 Subaru WRX Review | FT-86 SpeedFactory | FR-S / BRZ vs.... | 71 | 05-26-2014 01:08 AM |
