| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#15 |
Drives: 2015 FRS 6MT
I agree looks like a kit car and no AC WTF... not a chance in Hot FLA..........
| The Following User Says Thank You to snow For This Useful Post: | Dadhawk (06-17-2015) |
#16 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I actually like the 818C better than their GTM supercar, which is a frigg'n land missile on wheels (Corvette power with ~700lbs less weight...). But I like the custom work this guy has done with his GTM: [ame="https://www.youtube.com/watch?v=IB9R8rmiJtY"]GTM Supercar at Shelton Car Show 2015 - YouTube[/ame]
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#17 |
Drives: '06 AM V8V Coupe
No AC is possibly survivable here in Norcal if the ventilation system works properly and doesn't heat up the air coming in.
The bodywork however is uglier than the soft top one and I still don't like the WRX drivetrain (unless it's easy to get a newer motor in there). |
#18 | |
1st86 Driver!
My issue with them for me is these are immediately identifiable as that type of car, which both of FFR cars in this thread are, regardless of performance. Just not my thing I suppose, but I certainly appreciate them for what they are.
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#19 | |||
Drives: 2015 Series.Blue
It's a kit car, add it ![]() Totally different cars and not based off the same donor car. Quote:
If you do all the work yourself, probably. Quote:
I think it looks better than their older version. That gap between the front fender and door is there for aero. Overall fit and finish has always been an issue with kit cars though... Quote:
That roof scoop appears functional, so it's going to be sucking fresh air in quite well at speed. Why the WRX hate? You're shaving so much weight off, you could leave the engine stock and it would still be a rocket. |
#20 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
#21 |
Site Moderator
Drives: Stuff
While possible, it's not easy to do it nicely integrated into the dash like it should be. They should just make it an option and make some money on cheap molded plastic.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#22 |
They should have made it look like a 90s honda civic.
#23 | |
As with everything, the amount of time spent in doing proper finish work with sanding and priming and sanding and priming and paint determines your end result. Some cars at the show if you looked closely, you could see the join lines in the fiberglass and some you couldn't. I figured that with having to buy an engine and transmission and finish the car would put it well over $40 grand. Of course most of the kits have 'options' which also drives the cost, such as front suspension, rear ends, brakes etc., etc. The first 2 pictures are the beginning of the 818, next picture is of one of their MK4 cars (Cobra copy) with all the join lines unfinished but the body has been painted as they all come out red from the molds. The last 3 are of the most beautiful MK4 I saw there. If you notice all the striping goes under the hood and across the dash. This car was gorgeous. Again, what effort you put into a kit is what your end result will be. Factory Five also offers a 3 day build class in Michigan where you go and actually build one of the cars. Believe it is $799 and you get a $250 credit towards buying your own kit. Classes are limited to 15 students. (Their annual open house was last weekend 6/13 at FFR) and the year I went there were reps there from Ford with good deals on engine/transmission packages. Last edited by White64Goat; 06-18-2015 at 09:20 PM. |
| The Following User Says Thank You to White64Goat For This Useful Post: | Dadhawk (06-18-2015) |
#24 | ||
Maybe I was too short, these are entirely different levels of kitcar. The Exocet is basically a rebody of a Miata. It can be built very fast because of this. This borrows some pieces from the WRX, but because of so few parts being used from the donor car, it could be pieced together from simple parts from a WRX from what I've seen. Not to mention making it into a 2WD MR car from an AWD front mounted engine car. The amount of work is going to be a hell of a lot higher. Quote:
Looking at their dash, it looks like there's plenty of real estate to install whatever you want. Wouldn't be hard to piece together something that works and looks good with Vintage Air parts and some custom lines and fittings. Big issue is that the engine is under glass, but it's not isolated from the rest of the cabin. Fully isolating it and feeding the intercooler could be an issue though. Then again, a setup like this could work well with an A2W intercooler... Never enough time or money for this stuff... |
#25 | |
Drives: 2019 MX-5 RF GT-S, 2002 Miata LS
#26 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
The more I look at this car, the more I wanna just sell everything and build one of these cars. I would want a nice plush interior and lots of sound deadening so I think $25k would be a good range in what I would spend to complete one of these. I really love the coupe look. I can only imagine that in real life that it looks much more exotic.
| The Following User Says Thank You to hmong337 For This Useful Post: | f0rge (06-22-2015) |
#27 |
| nice set of tires | Fabron757 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 04-06-2013 06:02 PM |
| NICE FOTOS | coyot | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 01-15-2013 11:21 PM |
| A Not So Nice Review | Dezoris | Scion FR-S / Toyota 86 GT86 General Forum | 90 | 11-06-2012 09:20 AM |
| Nice Decals | CBR600RR | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 09-28-2012 10:48 AM |
| nice jdm site | paraguin | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-17-2012 11:12 AM |
