#1219 |
Drives: 2014 BRZ
I would highly, highly, implore you to spend the few extra hundred dollars and use ECUTEK as your engine management solution. And believe me, this is coming from someone who is in no way shape or form a "parts /company snob" if you will. The ability for your tuner to create custom maps affords them the ability to properly cut boost/ignition timing in the event that a read value (from a knock sensor/ O2 sensor/oil temp or pressure any input really) exceeds a desired threshold is absolutely priceless and has likely saved my motor countless times for all I know. To my knowledge, this cannot exactly be accomplished in ROMRaider....hence the reason you see basically every single person except for one that tunes these cars commercially/professionally using Ecutek over RomRaider even when it likely cuts into their bottom line with the hefty cost of licensing.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
#1220 |
Whats next?
Drives: '13 Asphalt FRS MT
Is it absolutely necessary to get 700cc injectors for e85? I will be using the delicious tuning flex fuel kit. Just wanting to be in the 300whp range on e85.
Life is too short to drive a boring car...
Instagram: @angelb_af |
#1221 |
Driving Coach
Yes, stock injectors can't deliver the volume of fuel required for E85 + boost.
#1222 |
Whats next?
Thanks man, a E85 pump just opened up a near my house so I thought it's be fun to go e85 lol Can the stock fuel pump keep up or should I just upgrade that too?
#1223 | |
Driving Coach
| The Following User Says Thank You to ATL BRZ For This Useful Post: | FRS_FIEND (11-04-2019) |
#1224 | |
Whats next?
I will most definitely be asking questions on this thread during my install. Still a bit confused where my coolant lines for my GTX go and my boost controller everything else I've watched and researched a million times over so I'm confident
#1225 | |
Drives: 2013 Brz Limited
Was in the same situation as you, but this forum and the facebook page are great resources. I even messaged Ian a couple of times to double check everything and he was always there. |
| The Following User Says Thank You to retepK For This Useful Post: | ATL BRZ (11-05-2019) |
#1226 |
Drives: 2014 BRZ
If you'd like I can take a video of how I've got my coolant and solenoid lines setup.
#1227 |
Drives: Bone stock
Do it!! Please and thank you.
Sent from my SM-N960U using Tapatalk |
#1228 | |
Whats next?
Yes I've read alot of info from the forum and yt videos even though I'm read up on the install I just tripple check my double checks, this car is my baby and want to do everything perfect. I'm hoping to come here to just get quick tips during installing.
Instagram: @angelb_af Last edited by FRS_FIEND; 11-07-2019 at 03:39 PM. Reason: Also, Meant for retepk sorry at work |
#1229 | |
Drives: 2014 BRZ
#1230 | |
Whats next?
#1231 |
Driving Coach
That was my video and my recommended setup, regardless of use case. No point in heating the throttle body with coolant unless you live in the Arctic Circle. Less potential points of leakage and a straight shot to the turbo.
| The Following User Says Thank You to ATL BRZ For This Useful Post: | FRS_FIEND (11-09-2019) |
#1232 |
Whats next?
Nice to meet you haha great videos btw 🤙 yeah I'm definitely not there I'm in socal hahaha. Thanks man I will need to check in with you when I get there , tomorrow I'm doing the dreadful spark plug change and swapping in my sti engine mounts. So close to doing my install, which I need to hurry and do cause I'm pretty sure the wife's tired of all the boxes in the garage lmao
| HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 09:03 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 03:31 AM |
| To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 08:33 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 01:58 PM |
| P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 07:27 PM |
