86WORX
Old 06-16-2019, 01:09 PM   #1163
trinidadj
Drives: '16 FRS-MT Ablaze Red
Hey guys,
If you have an open dump waste gate but want a recirculated wastegate instead then what are your options? Does JDL offer a replacement downpipe?
trinidadj is offline   Reply With Quote
Old 06-26-2019, 10:21 PM   #1164
Conman
Conman's Avatar
Drives: Red FRS
I'm guessing you could send it back and they could modify it for you? ... So the kit is in; I got the Misimoto radiator and slim fans. The turbo blanket is touching the fan; is there any more adjustment possible?
Also I'm wondering Do I need a flex joint in my exhaust? I have a 2.5 over pipe-straight pipe to Tanabe cat-back but there isn't any flex joints?
How about heat wrap for the electrical connections? Oil line under the manifold?Anything else I should be thinking about doing at this point? Thanks!
Conman is offline   Reply With Quote
Old 06-27-2019, 02:24 AM   #1165
James Russels
Drives: 2013 FRS
I was doing some research on oil and came across this statement at the end of the first post located here:
Originally Posted by solidsnake11 View Post
Turbo guys relocate the turbo feed from top of block your taking oil away from your rods, tee from oil pressure fitting make sure it doesn't protrude in the block any further than the stock oil pressure sensor
Is this a legitimate concern? Is there a better place to get oil for the turbo?
James Russels is offline   Reply With Quote
Old 07-04-2019, 05:11 PM   #1166
Marks Boosted
Marks Boosted's Avatar
Drives: Innovate SC, Wilwood Kit, Limited
Patiently waiting for my kit to arrive! Went with a GTX3076r 700hp IC also got 1050x injectors and south bend stage 3 clutch, might be buying a short block from IAG soon as well
Anyone got any recommendations on where they got their built blocks from and what Compression ratio’s you chose?
JDL GTX3076R Turbo Kit, 700hp Intercooler, ID1050x Injectors, South Bend Stage 3 Endurance Clutch, Willwood Brake Kit, Mtec Shift Springs, Perrin OP FP and exhaust, Delicious Flex Fuel Kit,Whiteline Transmission and Rear End Bushings, TRD Chassis Supports, Perrin Front and Rear Sway Bars, Perring End Links
Marks Boosted is offline   Reply With Quote
The Following User Says Thank You to Marks Boosted For This Useful Post:
Conman (07-04-2019)
Old 07-05-2019, 03:03 AM   #1167
GerrelleZeppeli
Drives: Toyota 86
Interested about buying this kit in the future but just curious, does the UEL manifold in the turbo give the car that signature Subie rumble?
GerrelleZeppeli is offline   Reply With Quote
Old 07-05-2019, 03:12 PM   #1168
WC-BRZ
Drives: Black BRZ
It sure does!
WC-BRZ is offline   Reply With Quote
Old 07-08-2019, 05:21 PM   #1169
Amputechture
Drives: 2014 BRZ
Originally Posted by trinidadj View Post
Hey guys,
Find a good exhaust shop local to you and talk to them.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 07-09-2019, 01:07 PM   #1170
James Russels
Drives: 2013 FRS
Does anyone know the torque specs for the turbo housings (GTX2860R) or the connection between the downpipe and turbo, or where I can find these?
Old 07-20-2019, 06:12 PM   #1171
Conman
Conman's Avatar
Drives: Red FRS
Well my shop started the car for the first time and it’s getting tons of oil burning through the exhaust. The o2 sensor and down pipe are completely coated in oil. Huge thick clouds of smoke completely filling the shop and neighborhood. I told them the AOS needs to be vented to atmosphere ,but it wasn’t installed that way. Is that what’s causing the smoke.? Are the oil lines correct? Or is it the AOS pulling oil into the intake? What else did we just ruin by doing this? Spark plugs, o2 sensor?
Old 07-20-2019, 06:19 PM   #1172
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
@Conman Did you install the oil restrictor in the oil supply line to the turbo?
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 07-20-2019, 06:31 PM   #1173
Conman
Conman's Avatar
Drives: Red FRS
Yup they said they did.
Old 07-20-2019, 07:29 PM   #1174
Conman
Conman's Avatar
Drives: Red FRS
You dont think the AoS being not vented to atmosphere would have caused this?
That's what people on facebook are saying
Old 07-20-2019, 07:53 PM   #1175
Tonrogs
check the outlet of the turbo/charge pipes and see if there is oil. Right now we only know there is oil in the exhaust.
How much oil are we talking about exactly?
Old 07-20-2019, 07:58 PM   #1176
Conman
Conman's Avatar
Drives: Red FRS
by the amount of smoke we sent out I would be surprised if there is any left
Search this Thread:
Advanced Search
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 09:03 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
