#1038 |
Drives: Scion FR-S
Just ordered my kit this week... planning on doing the install early August!
#1039 |
Drives: 2013 Subaru BRZ
#1040 | |
Drives: Scion FR-S
JDL turbo kit owners thread
I was told 3 1/2 weeks. They said all parts for the v2 were in stock, it would just take 3 weeks to get the turbo in, make the uel manifold, and half a week to do all the coating. Did you order online or over the phone? Sent from my iPhone using Tapatalk |
#1041 | |
나의 SM-G955U 의 Tapatalk에서 보냄 |
#1042 |
Driving Coach
How is your AOS routed? Are you still using the turbo as a vacuum source for the AOS, meaning you have one of the hoses connected to the fitting on the pre-turbo inlet pipe? Doing that overwhelmed my AOS, so now I have that fitting capped off and I run my AOS vented to atmosphere.
#1043 | |
Drives: Scion FR-S
I went with the gtx2860r, what about you? Sent from my iPhone using Tapatalk |
#1044 | |
#1045 | |
Drives: Scion FR-S
Awesome! I can’t wait for mine... I went just recirc, no cut IC, and a mishimoto setup for my radiator/fan shroud. Hopefully there are no fitment issues. Sent from my iPhone using Tapatalk |
#1046 | |
#1047 |
Drives: scion frs
Hey guys, just installed my JDL kit this weekend. Can't wait for my tune this week from delicious (e-tune). Never done the etune before.
#1048 |
PhoneFlash by EcuTeK
Hey Guys,
Just wanted to pop in and let all of you know that Phase 10 RaceROM is finally here for all model years and all regions of the world (Not just the initial 2013-2014 and 2017-2018 release), from 2013-2018 models on USDM, European, Asian, JDM (Yes it's different), and Gulf spec ECU's. Our entire tune library has been updated to accommodate the new software, and we are now rolling out these tunes to new and existing customers. A lot of our customers running JDL kits have been asking about this update, so I wanted you all to be among the first to know that our Delicious tunes are all built up and vetted out for the new software. The latest version is denoted as V25.00. Though RaceROM 10 is really a complete and utter overhaul of the way we do tuning on these cars, some of the more important changes are as follows: - Improved tip in throttle response throughout entire rev range - Completely overhauled closed loop correction outside of factory closed loop scenarios - Completely overhauled boost control on turbo systems, implementing a variety of fail safe and target compensations to correct for and protect against overheating oil/coolant, poor quality fuel, AVCS being inactive, and more. We also have a lot more adjustment room to have features like boost by gear, ethanol content, map-switch mode, and more working in tandem with one another. - Completely overhauled Flex Fuel implementation. Ethanol content, ethanol ignition advance, and more are now all dedicated parameters in EcuTek. The way Flex Fuel is programmed is also far superior in RaceROM 10, and allows much tighter integration into the tune. What this means for the end user is a smoother transition between fuel types, and a smoother ramp in power delivery as ethanol content increases or decreases. - Dedicated custom map to warn you when your AVCS system has failed to activate in a timely manner, letting you know before you push the car and risk potential damage. - Vastly improved control over fueling in medium to full load areas. - Improved transition from low load MAF calculation to high load VE calculation. - Improved drivability across all versions. - Addressed a particular bug where some vehicles would experience a hesitation in high gear, partial (20-40%) throttle pulls. This was typically experienced when trying to pass on the highway, for example. If you have any questions about this update, feel free to contact me via email at sales@delicioustuning.com.com. This update takes what is already a great turbo kit, and improves it more than we previously thought possible. Last edited by DeliciousTuning; 07-05-2018 at 04:41 PM. Reason: Clarity |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | Hicklinc (01-25-2020) |
#1049 |
Cant wait to get this installed!!!!
![]() ![]() 나의 SM-G955U 의 Tapatalk에서 보냄 |
| The Following User Says Thank You to dkstylezz For This Useful Post: | Hicklinc (01-25-2020) |
#1050 |
Drives: JDL Turbo BRZ
Is anybody here running a JDL oil cooler with the "no-cut" kit? I've had both installed for a while, however, there isn't much air getting to the oil cooler at all. it's also in kind of an awkward position where the pipe covers some of the front of the core. I'm just reaching out to see what some of you guys have done. I'm looking to create my own air channel and duct using my 3d printer .. possibly even take the foglight out. I was seeing oil temps up to 270F on the track which had me worried. It was hot as balls out though, 90F + and sunny.
| The Following User Says Thank You to Jesse36m3 For This Useful Post: | Lakitu (07-20-2018) |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 09:03 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 03:31 AM |
| To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 08:33 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 01:58 PM |
| P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 07:27 PM |
