Old 08-01-2017, 06:49 PM   #911
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Originally Posted by ShadowReaper View Post
Can anybody give me a description of the difference in sound from the precision and garrett turbos? To be more specific the spooling sound. Does it sound like a jet? cow? chicken?
Some perspective on the Garrett GTX2860R Gen2
[ame="https://www.youtube.com/watch?v=ywvkNMflTlY"]Turbo Subaru BRZ at Charlotte Motor Speedway 7/29/17 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=8A6OnAaydgw"]Subaru BRZ shooting flames under the lights at Charlotte Motor Speedway - YouTube[/ame]
Sounds like a jet, IMO.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Hicklinc (01-25-2020), ShadowReaper (08-03-2017)
Old 08-01-2017, 07:04 PM   #912
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Jesus man, giving that 370 a run for its money.
Alltezza is offline   Reply With Quote
Old 08-02-2017, 04:55 AM   #913
DarthThinmints
DarthThinmints's Avatar
Drives: scion fr-s raven
Did anyone oem fans melt from being too close to the turbo kit?
I also have DEI Titanium Turbo Shield for it.
DarthThinmints is offline   Reply With Quote
Old 08-03-2017, 05:46 PM   #914
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Sounds absolutely fantastic man. Great racing video too.
I dont know if you or anybody reading this has any experience with other garrett turbos. Out of the 3 turbo options that the JDL kit has, I m looking at the first Garrett turbo. I would imagine it wont have the same sound as the GTX but would you say similar, still like a jet?
Instagram: 86_Maul
ShadowReaper is offline   Reply With Quote
Old 08-03-2017, 06:19 PM   #915
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Thanks.
I think you're overthinking the sound from the different turbo options. The base journal bearing Precision 4831 and even the optional dual ball bearing Garrett GT2860RS will both sound basically the same, similar to my car when it spools up.
Don't choose a turbo because you think it will sound different/better than another. They're all basically the same. Choose a turbo based on your power goals and budget. The base Precision turbo is capable of 380whp on ethanol and 280-300whp on pump gas. The Garrett GT option will touch 400whp on ethanol and the Garret GTX turbos will go even higher to the point where you'll destroy the stock transmission before the motor lets go (assuming you don't build it with stronger internals first).
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
CxG (08-07-2017), Hicklinc (01-25-2020), ShadowReaper (08-04-2017), x808drifter (08-03-2017)
Old 08-04-2017, 12:05 AM   #916
Amputechture
Drives: 2014 BRZ
I have the PTE48 and it sounds comparable to a twin I've ridden in that had a GT2871R. If you don't recirculate your wastegate you won't hear a god damn thing but GGGGGTARTAARRRRRRRRRRRAAOOOOOOOOOOAAAARRRRRRRRRRRG GGGGGGGGGGGG after 4 thousand RPMs.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 08-04-2017, 05:06 AM   #917
ShadowReaper
Indulgent Tormenter
Thanks.
This isn't the case here. I'm already set on the Garrett GT option. I'm just curious if that sound is a Garrett thing, but since GTX is a bigger turbo, I would assume that sound is more dominant. Ive seen some problems with the precision here and there, but nothing with Garrett. I'm not interested in spending about +1000 on the GTX either, I'm not trying to build so much.
Instagram: 86_Maul
Old 08-04-2017, 09:58 AM   #918
armstrom
Drives: none
Not really. Yes, different turbine and compressor wheels will sound different but the biggest component of the "turbo sound" is the fact that you have a pair metal wheels spinning at ~100,000 RPM moving air. High rotational speed gives you the high pitch. The layout of the intake plumbing and air filter before the turbo controls the volume and the profile/size of the wheels themselves change the "color" of the sound.
The reason it sounds like a jet is basically because it is. At least it has all the major components of a jet engine, just with external combustion rather than internal. Here's a video of a turbocharger that has been converted into a jet engine. [ame="https://www.youtube.com/watch?v=R0phVKg57dM"]GR-7 DIY Turbojet Engine Performance Testing - YouTube[/ame]
-Matt
armstrom is offline   Reply With Quote
The Following 2 Users Say Thank You to armstrom For This Useful Post:
ATL BRZ (08-04-2017), ShadowReaper (08-05-2017)
Old 08-07-2017, 05:05 AM   #919
grichardt
grichardt's Avatar
[ame="https://www.youtube.com/watch?v=G9ODCDvYIoo"]JDL TURBO KIT drive along BRZ Open Dump - YouTube[/ame]
A bit of a shitty video, but gives a little bit of sound for the JDL kit with an open dump tube.
grichardt is offline   Reply With Quote
Old 09-04-2017, 02:13 PM   #920
jplake
Drives: 2016 Subaru BRZ - Limited
Can someone provide me with clarification. I have a new JDL "non cut" version. I'm currently stuck on install because of the MAF placement. Was I suppose to receive a harness extension with my kit, or do I need to extend the wires on the factory harness?
I can't get in touch with JDL due to the holiday weekend.
jplake is offline   Reply With Quote
Old 09-04-2017, 03:02 PM   #921
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Funnily enough, I had a buddy of mine extend them before I realized they have an extension as part of the kit.
You should have one.
Rybot is offline   Reply With Quote
Old 09-08-2017, 11:26 AM   #922
ATL BRZ
Driving Coach
ATL BRZ's Avatar
https://www.instagram.com/p/BYwhgsBn...en-by=86senpai
Thinking about getting an EBCS and running more than just the 9.4 psi spring...
The Following User Says Thank You to ATL BRZ For This Useful Post:
Old 09-08-2017, 12:09 PM   #923
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
this is what sold me on the jdl kit. waiting for some funds to get a used motor to swap out my blown one... and then getting this! thanks for sharing!!
pgranberg11 is offline   Reply With Quote
Old 09-09-2017, 01:38 PM   #924
Amputechture
Drives: 2014 BRZ
Do it! Even if you want to stay at or near your current boost levels, I have a 'wastegate' map that has the target set to my wastegate spring level, it lowers the boost threshold by about 300 rpm. They are so affordable, no reason not to. I'd recommend against the Grimspeed EBCS, the barbs on them are tiny. Switched to an Infamous Performance EBCS and the difference can be seen logging manifold pressure. Nothing dramatic, but every bit helps when you are fighting to keep your transient up.
The Following User Says Thank You to Amputechture For This Useful Post:
ATL BRZ (09-13-2017)
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 09:03 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
