| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 2013 BRZ Limited
I was more than impressed with the factory Kicker. Easy and clean install, didn't need to do any wiring or buy a new amp, and it sounds awesome. It should come as a standard feature because it makes such a big difference in overall sound quality. I looked into the OEM+ system and the JL Stealthbox but after its all said and done those were almost double the price and to me it wasn't worth the extra $
#16 | |
Drives: 2015 BRZ Premium
#17 | |
You're welcome! While there is no adjustment on the sub itself there is still adjustment through the equalizer in the head unit. The bass can be a loud when the volume is really low but I don't have the limiter so I can't speak to the difference it makes. For $8 it should be worth a try. You can always unplug the limiter if you don't like it. |
#18 | |
| The Following User Says Thank You to Slong For This Useful Post: | afohlin (06-22-2015) |
#19 |
I have the factory Kicker subwoofer. The sub + wires weigh maybe 15 lbs, if you care about the weight, which is why I bought it.
I have noticed the sub sounds pretty good if you are mainly into hiphop. It's good for some electronic music, but some songs don't sound quite as good as I like. This is probably due to the fact that this is a 10" sub and some electronic music sounds better with a tighter 8" sub. I noticed an overall clarity improvement of the factory setup since the front door speakers aren't trying to reproduce all the mids and lows. You will notice that the OEM+ audio guys said the same thing when they made their own sub. There is no rattling at the front anymore either with the sub. I also haven't noticed any trunk or body panel rattling on the outside of the car either. Overall, this is probably the easiest sound upgrade you can do for this car. Yes, you can get a cheaper sub + box and some wire, but honestly, it won't be as clean of a setup as the factory Kicker, and I hate gaudy sub boxes taking up room in this truck. This is nicely tucked away in the corner, and leaves your trunk usable. You can also remove it in 30 seconds if you want to take it out. The OEM+ setup is better, but it's also a lot more money. You probably won't regret getting the Kicker. |
#20 | |
The Fail Boat
Drives: CWP S.B.
750 for Reference CF?? that's like less then half price!!! You lucky XXXXXXXXXx /rage ![]() ALL JELLO |
#21 |
Drives: 2015 Series.Blue
I think the speakers took some time to break in as my stereo sounded terrible when I first bought it and now it's halfway decent. Still want an OEM+ system though...
#23 |
Drive From Home
Drives: BRZ STI Performance
| The Following User Says Thank You to krayzie For This Useful Post: | chaoskaze (06-30-2015) |
#24 |
I love my series blue brz
Drives: 2010 335d
more reviews for oem kicker? i just want a bit more bass. I think spending 1500 onto the stereo into this econo sports car is excessive, especially it came with loud road and engine noise. I could use the difference of price to get my self a set of perrin exhaust
#25 | |
The Fail Boat
Drives: CWP S.B.
Damn you, why post stuff I want when I just brought a set of used OEM+! 😱 |
#26 |
Drives: Red 2015 BRZ Ltd
Try this EQ setting. Someone else told me about it and it helps a lot
09 A4 3.2 S-Line Sent from my iPhone using Tapatalk |
| 2015 wrx vs 2015 gti vs ford focus st best all around dd and autocross | jflogerzi | Other Vehicles & General Automotive Discussions | 13 | 05-25-2015 09:33 PM |
| 2015 Formula Drift Tech Day - 3/28/2015 | yospeed | Southern California | 1 | 03-05-2015 04:10 PM |
| Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo | dssence | Electronics | Audio | NAV | Infotainment | 0 | 01-27-2015 07:43 PM |
| Aside from 2015 Acura NSX and Toyota Supra, what else in 2015? | stockysnail | Northwest | 7 | 01-13-2015 03:30 AM |
| Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC | mav1178 | Other Vehicles & General Automotive Discussions | 1 | 05-23-2014 11:47 PM |
