Southern California SoCal
Old 06-15-2015, 12:43 AM   #1
Darkparadox911
Drives: 2015 Subaru BRZ Pearl White 6MT
PERRIN 3" BIG MAF CAI
Hey guys, had anyone installed the big 3" cold air intake on their 86, which requires a tune( rescaling the MAF) to be precise. I'm not familiar with tuning and whatnot and have been getting great help from the forum members on how to rescale this. I ordered the OFT From Vishnu and am awaiting that now. As soon as I receive it, I will install my 3" CAI, then Plug my OFT and read it to my ECU, then use my laptop to adjust the scaling given by Perrin. Then Write it using the proper stage of course, which in my case would be EL header stage 2. Does this seem about right or am I missing something? Should I read my ECU Before or after I install my 3" CAI?
Darkparadox911 is offline   Reply With Quote
Old 06-15-2015, 12:50 AM   #2
steve99
With the oft reading the stock rom file is how you marry the oft to your car. Your just reading the stock tune into the oft which can be written back any time you like. Any variable parameters like learned fuel trims or knock correction IAM values are set back to default\cleared each time you flash a tune or reset ecu, eg disconnect battery..
The perrin 3" maf definitly requires the custom scaling supploed by perrin else car will drive like crap and may run lean at high rpm.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Darkparadox911 (06-15-2015), Drakiv (06-15-2015)
Old 06-15-2015, 12:56 AM   #3
Darkparadox911
Thank you so much brother. So I will read my stock tune and then change my scaling and write the new tune
The Following User Says Thank You to Darkparadox911 For This Useful Post:
Drakiv (06-15-2015)
Old 06-15-2015, 10:22 PM   #4
Darkparadox911
Ok and last ?, if I tuned my car to Stage 2 EL headers and didn't install my 3" Perrin yet can I always do that later and just scale the MAF to handle the 3"?
Old 01-28-2017, 03:16 PM   #5
Jakevincent
Drives: Black frs
Perrin intake on OFT
I also have this intake and need the codes from Perrin! Could you share these codes for the tuning?
Jakevincent is offline   Reply With Quote
Old 01-29-2017, 09:51 PM   #6
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
its on their website
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 01-29-2017, 09:53 PM   #7
1GiantTurtle
Space for Rent
yup, if you need help i can plug in the number for you
Instagram: 86turtle
Instagram: 86turtle
3" Perrin Resonated Cat-back w/ 3" Nameless Catted Downpipe Kevstra Engine, Exhaust, Transmission 28 05-20-2016 08:38 PM
FS: Perrin CAI, & Perrin 2.5" resonated exhaust (NC) sonnydelight Engine, Exhaust, Bolt-Ons 9 06-08-2015 11:09 AM
DIY "Grimspeed/Perrin" license plate relocation BMHumanic Cosmetic Modification (Interior/Exterior/Lighting) 3 02-05-2015 12:44 PM
Perrin intake tube "worth it"? ANTLAY Engine, Exhaust, Transmission 60 10-11-2014 06:41 PM
