| View Poll Results: Are you in??? | |||
| Yeehaah! Pack the Antihistamines, I'm there like a bear! |
10 | 71.43% |
| I'm a Grinch and its too cold. |
3 | 21.43% |
| I'm sending a donation with a fellow Hachi, 'cos thats how we roll! |
1 | 7.14% |
| Voters: 14. You may not vote on this poll | |||
#127 |
Platinum Member
Drives: Toyota 86 Vortech SC
I wish. When I get it right, it's at about 100m, wrong in that vid was at about 80m.
As I said above, try to spot the bonnet dipping - that's when the brakes go on, not when I lift off the throttle.
#128 | |
Drives: Toyota 86 Supercharged
The only downside is that there are very few landmarks, especially with it being so flat, so finding your way round first couple of times is tricky. But I got over that. |
#129 | |
Drives: Toyota 86 - Charcoal Grey
I'm not that worried about understeer, because it is not dramatic. You straighten out, get on the brakes, and hopefully you have enough road left to make the corner on a wider line. I'm worried about snap oversteer, especially with the elevation changes. As the weight of the car lifts over a crest and settles again, you can get some interesting results. Also, a tiny bit of oversteer at speed scares the shit out of me, because you can't really ride it into a drift, and grip can come back suddenly enough to violently snap the car around. So this post makes me sound like I worry a lot . I'm just saying that I will definitely approach Zwartkops with a fair amount of caution lodged in my mind, whereas at Red Star I really gave it a good go even for my first time.To show what I mean, check Sabine Schmitz save this tank slapper at the ring while driving a customer's car (incident just after
): [ame]http://youtu.be/uaaD_bSDaIQ?t=8m15s[/ame] Last edited by LostSalad; 07-29-2015 at 11:24 AM. Reason: Add video |
| The Following User Says Thank You to LostSalad For This Useful Post: | Dammod (08-04-2015) |
#130 |
Drives: Toyota 86 RED!
Hey Everyone,
Thank-You ALL for joining us and making P4P a huge success. It would have sucked without all the 86's! You guys rock! We made just over R20 000 for our charity, and they are absolutely ecstatic, and so, so grateful. Good news is that we're starting on next year's event so long, hope we see you there! |
| The Following 5 Users Say Thank You to JouMaSeHoes For This Useful Post: | Alang (07-29-2015), Dammod (07-31-2015), Fish Eagle (07-29-2015), FT_86_SM_GP (07-29-2015), sav (08-01-2015) |
#131 | |
Drives: 2013 Toyota 86 2.0 Std.
Without SC, not quite as much speed so tried at the 50m and took @Guseman for a farming trip!
Adding power makes you faster on the straights, subtracting weight makes you faster everywhere - Colin Chapman
| The Following User Says Thank You to Alang For This Useful Post: | Fish Eagle (07-29-2015) |
#132 |
I noticed another set of tyre tracks in the grass
| The Following 2 Users Say Thank You to CWP68 For This Useful Post: | Alang (07-29-2015), Fish Eagle (07-29-2015) |
#133 | |
Platinum Member
Switch your traction control fully off at Red Star, Midvaal (once you know the track), and on the skidpan. These places are where you can relatively safely practice managing oversteer, drifting, and improve your oversteer recovery skills. Leave your nannies fully on at Zwartkops and Kyalami whether wet or dry and don't succumb to peer pressure. You can do quite fast laps with them on. I can run in the 1m18s with a passenger on board at Zwartkops with the nannies fully on and without triggering them. As you know, it's very obvious when they interfere. That tells you that you're asking your car to do something it can't do. Have them on, but try to never cause them to kick in. Driving just within your car's capabilty is what you want to learn. Only once you get much better will you gain time by switching them off, but obviously you'll have more risk. Take another look at Jacques' Red Star video. You won't see him drifting or sliding around. Smooth = quick, and sliding isn't smooth. Having said that, the nannies are just an aid. There is no cure for defying the laws of physics. If you go into a corner at a speed that your car is incapable of handling, nannies or not, you're going off - QED. But they might or are even likely to catch some silly mistakes and allow you to learn from that without breaking the bank. I'm susceptible to distraction, especially when chatting to a passenger, and it takes very little distraction to make a big mistake. I will always keep my nannies on when I've got a passenger on board. During the past year they've saved me twice when I've had a passenger and made a stupid mistake. In one instance especially, I would probably have hook spun into the wall on T9 at Midvaal, and thrown my car away. I'm very glad that didn't happen. YMMV
| The Following 2 Users Say Thank You to Fish Eagle For This Useful Post: | JouMaSeHoes (07-30-2015), LostSalad (07-30-2015) |
#134 |
Drives: PEARL WHITE GT86 TRD
That is how I felt as well. I tried a lot of risky maneuvers at RSR. I mowed the lawn, sowed the seeds and watered the fields and my car came out without a scratch.
| The Following User Says Thank You to Freedom For This Useful Post: | Dammod (08-04-2015) |
#135 | |
Platinum Member
You were obviously having a ball ![]() Exactly what I was trying to say - play in the garden, not in street.
#136 | |
My brake fluid needs changing however, and I am considering changing transmission and differential fluid while I'm at it.I've read here Motul gear 300 can be used for both transmission and LSD fluid and most likely Motul 660 for brake fluid. |
#137 |
Drives: Lawn moweR
Also going to try to change Transmission fluid, after the track day my gear box does not feel the same, feels much sticker/rough when changing gears at low rpm's
| The Following User Says Thank You to FT_86_SM_GP For This Useful Post: | LostSalad (07-30-2015) |
#138 | |
![]() With @Freedom mentioning changing transmission fluid - my gears feel slightly stiffer ever since the track day o.O. Does this even make sense? Same with the oil. I could be imagining things, but the 5w30 they put in feels "thicker" somehow. Like I have to work the car slightly harder to cruise. I had 0w20 before. It doesn't say so on the bottle, but that's what they told me it is *shrug*. |
#139 |
| The Following User Says Thank You to LostSalad For This Useful Post: | FT_86_SM_GP (07-30-2015) |
#140 | |
My gears have always been hard / knotchy especially when cold that's why I want to try a new transmission fluid, I've read it can make a big difference. I want to change LSD fluid just to clear some of the gunk out from wear and tear. If you do a lot if skidpan / ghymkanas you need to do this. |
| 7/25 Grange Track day - Hosted by Slide Factory | bryanttttttta | Southern California | 7 | 07-24-2015 01:28 PM |
| 2015 Boxerfest April 25th NOVA Cruise | limitedblkwrx | Mid-Atlantic | 27 | 04-20-2015 12:18 AM |
| 86 Nights ~ July 25th 2014 | Drift-Office | Northwest | 38 | 08-01-2014 01:09 AM |
| $110 Track Day@Buttonwillow Raceway- July 20-21 in Socal | Louie | Southern California | 3 | 07-15-2013 03:40 AM |
| $135 Track Day @ ButtonWillow Raceway-July 10th in Socal | Louie | Southern California | 2 | 06-27-2011 04:14 AM |
