Old 06-12-2015, 10:57 AM   #15
Fender0122
Drives: 2013 BRZ Limited SWP 6MT
I second the use of a GLock. I actually just flip my belt buckle 180 or 360-degrees and pull it tight and that locks it pretty good. Don't really have any issues at autocross.
OVR-SCCA Course Design and SSSI
Fender0122 is offline   Reply With Quote
Old 06-12-2015, 11:23 AM   #16
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
Originally Posted by ZNAE86 View Post
Sounds to me like you might just have bad posture that you may need to work on
Maybe, either way I want to change the harness, so I think I'll just jump to rallye 3.
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 06-12-2015, 11:24 AM   #17
Filipino Royale
Got Rice?
Drives: 37J BRZ-L
I'll do that next time.
Old 06-12-2015, 11:43 AM   #18
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
DO NOT use ANY harness with the OEM seats.
ALWAYS have a HANS device or equivalent if using a harness.
can you use a hans device with oem seat belts or not a good idea?
ExxelDistributions is offline   Reply With Quote
Old 06-12-2015, 11:57 AM   #19
gramicci101
Off Topic
If you're using a harness with two shoulder straps, you can use a HANS device. Even if you're just sitting on your couch. It's the shoulder belts of the harness that keep the HANS located on your shoulders.
edit Also, I completely missed the word "belts" in your post. You need both shoulder belts coming back to front straight over your shoulders though, so an OEM seat belt wouldn't work properly
The Following User Says Thank You to gramicci101 For This Useful Post:
CSG Mike (06-12-2015)
Old 06-12-2015, 12:14 PM   #20
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
adjusted my seating position. works better.. I'll be getting rid of my harness bar soon for a roll bar with harness bar welded.
Kuri is offline   Reply With Quote
Old 06-12-2015, 01:44 PM   #21
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Once you've seen an actual HANS device, the answer is clear.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
wparsons (06-12-2015)
Old 06-12-2015, 02:06 PM   #22
OkieSnuffBox
Drives: '23 BRZ Limited
Custom or ?
The few that are available are ridiculously priced for a bolt-in 4 point bar.
Old 06-12-2015, 02:15 PM   #23
Kuri
Kuri's Avatar
Probably custom. We have a few local shops willing to do it
#TrackDayBro
Old 06-12-2015, 02:56 PM   #24
gramicci101
Off Topic
When you have it built, keep in mind head clearance. It's one thing to bash a helmet against a rollbar; it's another thing entirely to bash an unprotected head against it. And the little foam pads do very little.
Old 06-12-2015, 02:57 PM   #25
Kuri
Kuri's Avatar
Roll bar, not cage. This is my daily
#TrackDayBro
Old 06-12-2015, 02:58 PM   #26
gramicci101
Off Topic
Yes, and if it goes up the B pillar and across the roof at that point as a lot of rollbars do, the potential exists. I know my head is very close to that area, so I wouldn't be able to use one.
Kuri (06-12-2015)
Old 06-12-2015, 03:00 PM   #27
You *can*, but it would serve no purpose, and possibly injure you worse in the case of an incident.
ExxelDistributions (06-12-2015)
Old 06-12-2015, 03:28 PM   #28
wparsons
wparsons's Avatar
There is no point at all. A HANS device is to prevent basal skull fractures when you're running 4+ point harnesses. With stock belts your torso rotates off the seat in a crash, so the helmet isn't trying to rip your head off your neck.
If you're running Scrothe belts with the tear away patch, it's also not needed. With 5 or 6 point belts you're going to want a seat designed to work with them (likely fixed back), as well as a rollbar and a HANS.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Search this Thread:
Advanced Search
Anyone using a 4-pt harness with stock seats? empower-auto Tracking / Autocross / HPDE / Drifting 40 04-16-2015 01:51 AM
Edmonton FS: FIA Corbeau Seats + Mounts + 6Pt Luke Harness driver71 Canada Classifieds 5 06-24-2014 06:02 AM
Bride/Cusco seats, Essex Harness Bar, Beatrush - All In Stock @ RallySportDirect.com! RallySport Direct Interior Parts (Incl. Lighting) 16 11-19-2013 04:33 PM
FS: red recaro seats and scrotch/sparco 4pt harness Vten Interior Parts (Incl. Lighting) 7 05-15-2013 03:39 PM
Race Harness with stock seats Sccabrz192 Tracking / Autocross / HPDE / Drifting 20 04-06-2013 04:25 PM
