#99 |
Drives: 2013 Firestorm FR-S
I know at least some other manufacturers are on the grid too; SACHS to name one.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#100 |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
Ferrari I think uses Sachs, McLaren had always used Bilstein or Koni.
#101 | |
Drives: S60R/Corvette
http://www.cam.ac.uk/research/news/s...erter-revealed
Ryan M.
Strange Engineering Director of Suspension Development |
#102 | |
http://m.crash.net/f1/news/57466/1/m...koni-deal.html
#103 | |
Sorry to threadjack though. Back to the Penske discussion!
#104 | |
Mechanical inerters require a ball screw which is part of why its so expensive. We're working on a fluid inerter which would be a lot cheaper, so it can get banned at the lower levels of racing too.
Ryan M.
| The Following 5 Users Say Thank You to RBbugBITme For This Useful Post: | civicdrivr (06-24-2015), drewbot (06-24-2015), Hyper4mance2k (08-17-2015), Turdinator (06-24-2015), wparsons (06-24-2015) |
#105 |
Junior
Drives: a car
Ofcourse. Get ready to put that kindey up on med-ebay.
#106 |
Junior
Drives: a car
So all this time i see ferrari has electromagnetic dampers and the new z/28 rolls around with them quoting thousands of ajustments every second. Whats stopping someone from asking you guys to build one of those Ryan? Apart from the possible required materials.
Side note: For some reason i keep seeing this gps enabled suspension system, having a digital map of the course in its mind, taking into acount the corners, entrance and exit speed and lateral grip thus adjusting accordingly, being a very interestingly potent thing. Sounds expensive but thats not what we're here for either lol
#107 |
They're garbage. Developed them with an F1 team first back in the day and found it wasn't worth it. The metal in the fluid tears everything apart so the shocks don't last and the fluid is too expensive to rebuild every week. They're also reactionary. They quote how fast they react because they can't predict the bump your about to hit, they can just respond to the input after its too late. There is an inherent flaw in that.
Ryan M.
#108 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
@cdrazic93 while that sounds cool, I don't think a GPS with even the best of the best refresh rate could measure the nuances of track elevation changes, not to mention other things that race conditions (wet/dry and temps), tire compound temps, tire pressure, etc
-fellow engineer |
| The Following User Says Thank You to drewbot For This Useful Post: | cdrazic93 (06-25-2015) |
#109 |
Drives: '13 Denali, '15 Volt, soon a BRZ?
Although originally legal when your product was first released, they have been banned since at least 2013 season as per rule 14.11.4. and 14.11.11.
In any event, I'm excited about the news of these products coming to market for the BRZ/FRS/GT86! |
#110 |
http://www.indycar.com/Fan-Info/INDY...Specifications
Rule 14.11.1 Dampers are an open development component, provided they otherwise comply with these Rules. 14.11.4 No front or rear third dampers, inerters or any other device are permitted nor any modification to the manufacturer supplied parts. 14.11.11. No independent inerters or mass dampers are permitted. Basically by the time they wanted to ban them we sold so many too many teams would have had expensive piles of scrap so the corner damper/inerter hybrid is legal because corner dampers are open for development.
Ryan M.
| The Following User Says Thank You to RBbugBITme For This Useful Post: | Decay107 (06-24-2015) |
#111 |
Well I'll be.
Why didn't IndyCar just ammend 14.11.3 to say "Each corner must have one damper and one spring. Helper springs, bump rubbers and packers, as well as inerters are permitted..."
#112 |
Probably because they wanted to make sure everything from an inerter was contained inside the damper body.
Ryan M.
| Ultimate Racing Turbo Kit | sweetfrs | Forced Induction | 34 | 12-17-2015 12:25 PM |
| More info on Penske shocks | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 156 | 04-28-2015 11:22 AM |
| Ultimate Racing Turbo Kit | ganz954 | Forced Induction | 19 | 11-13-2014 11:34 PM |
| Ultimate Racing Exhaust help | psyclone07 | Engine, Exhaust, Transmission | 0 | 07-07-2014 12:05 AM |
| Ultimate Racing, quality? | rhythmM | Engine, Exhaust, Transmission | 5 | 11-30-2013 06:46 PM |
