| View Poll Results: Is the chattering engine sound normal when accelerating in 2nd gear at 1500-2000rpm? | |||
| Yes, the sound is normal. (please explain what the sound is) |
19 | 44.19% |
| No, you should slip the clutch a bit |
11 | 25.58% |
None of the above. (tell me what is right below )
13 | 30.23% |
| Voters: 43. You may not vote on this poll | |||
#71 |
Oh great my car is broke.
| The Following User Says Thank You to Tcoat For This Useful Post: | Koa (06-17-2015) |
#72 |
fabulous
Psssh, I'm ready to tear mine apart just to remove it. I hate that thing.
#73 |
Would love to see the reaction if I took my car in for service and said "oh by the way I can shift into first at pretty much any speed". The red flags that would go up would look like a Chinese, Peoples Day parade.
#74 |
Hisnamewasrobertpaulson
Drives: 2017 Golf R
I disagree entirely with this, the car is perfectly happy between 1500-3000 rpm for daily driving. In traffic i can even leave the car in second, 0 input on the gas and i'll just roll around at about 8mph at 800 rpm. my car spends the majority of her time cruising around between 2000-3000 rpm and see's about 4-5 wot redline runs per day. when you're in the lower rpm you just can't stomp on the gas and expect it to go, you need to roll on the gas as you climb the rpm range.
This is your life and it's ending one minute at a time.
| The Following User Says Thank You to RobertPaulson For This Useful Post: | Ultramaroon (06-12-2015) |
#75 | |
fabulous
So, I guess when I say "can't get it into gear above a walking speed" I mean I can't do it without going beyond my comfort level. The lockout/restrictor can be defeated but at what cost? I'll stick with being gentle and save the aggressive shifts for the occasional track day.
#76 | |
fabulous
| The Following User Says Thank You to Ultramaroon For This Useful Post: | RobertPaulson (06-12-2015) |
#77 | |
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
| The Following User Says Thank You to Talus1 For This Useful Post: | Tcoat (06-12-2015) |
#78 | |||
#79 | ||||||
fabulous
I use my fingertips to shift. At 5 MPH the force required to downshift into first is about twice that of any other single-gear downshift. Any more force I would consider to be in the range of hamfisting the gearbox. Quote:
Well, you kind of did by flinging some poo at him. I chose a different approach.
#80 |
Drives: GTS86
ok I found a video from another topic but it has the sound I'm talking about. [ame="https://www.youtube.com/watch?v=xUGoW08Xd6o"]Knocking Sound near rear of FR-S - YouTube[/ame]
You can hear it when he accelerates at 00:03-00:04 Is that sound normal because I can't avoid it in 2nd gear especially when turning slowly and carefully during rain but not slow enough to downshift to first...or in crappy traffic sometimes. |
| The Following User Says Thank You to awhatzable For This Useful Post: | Error (06-17-2015) |
#81 |
fabulous
The main message of this thread is that there are many options.
It's ok to feather the throttle and accelerate out of idle, just not uphill...It's NOT ok to drag the clutch as a standard practice. It's NOT ok to take a big stab at the throttle right out of idle but occasional gearbox chatter is no big deal.
#82 |
Drives: 2015 FR-S 6MT
If you are over 900-1100 rpm in second, you will be fine as long as you aren't slamming on the gas. That is around 7-8mph and if you need power, you should be able to easily shift into first. It shouldn't lug in second unless you are at like 600 RPM and are hammering the gas.
The only time I "slip" the clutch for more than a second or so is in reverse inside my tiny parking garage. Also, if you are in second and even at 2000-3000 RPM, you most certainly aren't going too fast to shift into first - it'll be hard on the synchros if you don't blip the throttle before sliding it into first, but it should go silky smooth if you are even remotely close to the correct RPMs. 1st at redline is about 35mph... |
#83 |
Why do you need to "jam" it into first at all? It should be butter smooth if you bring up your RPMs before trying to slide it from N to 1.
As long as you are matching the shaft speeds before slotting into gear, you should be able to get into first way up in the powerband - how else would the car handle extra low speed turns on the track or in autox if you had to stay in 2nd down to 10mph? |
#84 | |
Sweeper
MINUTIAE! LOVE IT |
| The Following User Says Thank You to Koa For This Useful Post: | Toyarzee (06-17-2015) |
| 2nd gear grind while slowing down NO clutch | Muskokan | Issues | Warranty | Recalls / TSB | 12 | 07-18-2017 02:35 PM |
| What's this clunk sound coming from 2nd gear after letting go of the clutch ? | awhatzable | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 04-30-2015 03:14 AM |
| Limited Slip diff oil Motul GEAR 300 LS 75W-90 | FRSToyota86 | Canada Classifieds | 12 | 08-22-2014 01:47 PM |
| clutch/gear box getting softer | zERoTu | Issues | Warranty | Recalls / TSB | 3 | 06-05-2014 09:18 AM |
| Display current gear without clutch engaged? | cfusionpm | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-26-2013 05:08 PM |
