| View Poll Results: Is the chattering engine sound normal when accelerating in 2nd gear at 1500-2000rpm? | |||
| Yes, the sound is normal. (please explain what the sound is) |
19 | 44.19% |
| No, you should slip the clutch a bit |
11 | 25.58% |
None of the above. (tell me what is right below )
13 | 30.23% |
| Voters: 43. You may not vote on this poll | |||
#43 | |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
Perhaps I'm misinterpreting people's description of noises because I'm assuming everyone's being dramatic with sounds these days. You can hear the motor work differently at all stages of stress. |
| The Following User Says Thank You to Toyarzee For This Useful Post: | Ultramaroon (06-11-2015) |
#44 | |
fabulous
To your point though, this car is super chatty but that's a great thing. Lots of opportunity to hone those M/T skills. OP questioned going uphill with passengers in second at low speed. That's definitely first gear territory. I detest having to come to a full stop just to get into first. Double-clutching is just another option. Options are good.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Toyarzee (06-11-2015) |
#45 | |
Drives: frs
Also dont look much your mirrors if you have ppl behind you. Dont pay attention when they honk at you for driving slow (happen to me in shitty roads) and pay attention on what you are doing. Keep calm and live mas |
| The Following User Says Thank You to Teseo For This Useful Post: | Ultramaroon (06-12-2015) |
#46 |
OP, post mileage when you need a new clutch.
| The Following User Says Thank You to Tromatic For This Useful Post: | Tcoat (06-11-2015) |
#47 |
Well, if you are at 2K in second and lugging, shifting to first would put you at approx 3200. Shift the thing, that's why the lever is there. The source of this issue is you, nothing else. Why abuse the drivetrain when you don't have to?
| The Following User Says Thank You to Tromatic For This Useful Post: | JohnJuan (06-11-2015) |
#48 |
fabulous
Don't make me bust out my A/T jokes.
#49 |
Drives: GTS86
You can't down shift from 2>1 at 2000 rpm in 2nd gear.
#50 | |
Drives: GTS86
#51 | |
fabulous
And to be clear, I'm not talking about some F&F showoff move. It's just a blip to spin up the input shaft before engagement. Not too much or you end up pressing the gearshift against the syncro waiting for it to spool back down. That ends up being tough on the syncro. You'll get the feel for it.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | awhatzable (06-12-2015), JohnJuan (06-11-2015) |
#52 |
#53 |
fabulous
#54 |
Drives: JAWS
From what I've gathered slipping the clutch briefly and especially at low rpms isn't going to have any ill effect on your car. Clutches aren't a perfectly "ON/OFF" mechanism for a reason. Even if it does cause slight wear over the lifetime of your car..the clutch is a wear item.
| The Following User Says Thank You to JB86'd For This Useful Post: | Ultramaroon (06-12-2015) |
#55 | |
#56 |
fabulous
No, Trom. It's impossible to shift into first gear above 4-ish MPH without double-clutching into it. But you wouldn't know that because you have the auto.
| 2nd gear grind while slowing down NO clutch | Muskokan | Issues | Warranty | Recalls / TSB | 12 | 07-18-2017 02:35 PM |
| What's this clunk sound coming from 2nd gear after letting go of the clutch ? | awhatzable | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 04-30-2015 03:14 AM |
| Limited Slip diff oil Motul GEAR 300 LS 75W-90 | FRSToyota86 | Canada Classifieds | 12 | 08-22-2014 01:47 PM |
| clutch/gear box getting softer | zERoTu | Issues | Warranty | Recalls / TSB | 3 | 06-05-2014 09:18 AM |
| Display current gear without clutch engaged? | cfusionpm | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-26-2013 05:08 PM |
