| View Poll Results: Is the chattering engine sound normal when accelerating in 2nd gear at 1500-2000rpm? | |||
| Yes, the sound is normal. (please explain what the sound is) |
19 | 44.19% |
| No, you should slip the clutch a bit |
11 | 25.58% |
None of the above. (tell me what is right below )
13 | 30.23% |
| Voters: 43. You may not vote on this poll | |||
#29 | |
There are so many variables that to say "do this" or "don't do that" is almost impossible really. Not to mention how hard it can be to put an action into a written format. I read back my first couple of replies and confused myself.
#30 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
The chatter people are describing can depend entirely on driving conditions. Could be vibrations in driveline and flywheel, or if the motor is about to stall you can more easily hear the valve train struggle. As most have noted, throttle for control, clutch feathering just for smooth transition and engagement. Friction based components were designed such that you will eventually replace it.
Nbd |
| The Following User Says Thank You to Toyarzee For This Useful Post: | awhatzable (06-10-2015) |
#31 |
Drives: frs
Just use the clutch for changing gears
| The Following User Says Thank You to Teseo For This Useful Post: | Ultramaroon (06-12-2015) |
#32 | |
Drives: GTS86
#33 |
Drives: GTS86
#34 |
You thought you were confused before? I think you are about to be totally baffled by the contradictory responses your poll will generate!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | awhatzable (06-10-2015), Toyarzee (06-10-2015) |
#35 |
Shibby!
Quite possibly along with some clutch components. I replaced a toyota 2rz motor's 25 lb. flywheel with a 11 lb billet aluminum one, and it chatters like a mo fugga below 3k rpms. No harm no foul tho, it's on the track bitch car.
#36 |
Drives: frs
#37 | |
Drives: GTS86
Does your car make noise from 1500-2000 in 2nd gear when feathering the gas ? If so, Do you drive it with the noise or do you slip your clutch ? |
#38 |
Drives: 2022 BRZ
What is your guys definition of slipping the clutch? And when does this normally happen in driving conditions?
And what is your technique on going third gear and coming on to a turn that needs to be taken at 12-18 MPH? |
#39 | |
Drives: GTS86
I don't take 3rd gear in that speed. I'd be in 2nd and my technique to accelerate after rpm drops below 2k is to slip my clutch. But now i'm starting to think its unnecessary because people are saying that the noise coming from the low rpm is normal and not damaging.
#40 | |
fabulous
Are you ruining your engine? Not exactly. Not right away, at least. I've become more comfortable operating at stupid low RPM because this engine still makes pretty good oil pressure down low. So, what's happening? At low RPM the engine does not rotate smoothly. It's much worse when asking it for any real power. The little pulses feed into the transmission where, although only one pair of gears is coupled to the output shaft at any one time, they all rotate all the time. The rest of the gears all have a little backlash so they chatter. I drive in shitty rush hour traffic every day. The first gear lockout is really aggressive. It is impossible to downshift into first above maybe 5 Km/h - walking speed. So, what do we do? 1. In second gear, from 1000-2000 RPM, very gently ask the engine to accelerate. I'm comfortable with stomping on it above 2K. 2. Get into first but never force it. Especially if you are going uphill, get into first. Learn to double-clutch. Fuck the naysayers. Learn to double clutch.
Last edited by Ultramaroon; 06-11-2015 at 03:24 AM. Reason: Ok, not many... "some" people's responses... |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | awhatzable (06-11-2015) |
#41 | |
hey you, yeah you <3
Drives: 2014 37J FR-S
haha the workaround is using your fat toe to accelerate. Use top portion of your foot, then whole foot once you are going. Double clutch wears your clutch quicker... 200k single clutching miles vs 76k double clutching or so on my Celi.
#42 |
fabulous
Bullshit. My firsthand evidence says otherwise. I'm 50. Not ragging on you but it must have something to do with your technique. It's possible to rev match into engagement so there's practically zero stress on the clutch.
| 2nd gear grind while slowing down NO clutch | Muskokan | Issues | Warranty | Recalls / TSB | 12 | 07-18-2017 02:35 PM |
| What's this clunk sound coming from 2nd gear after letting go of the clutch ? | awhatzable | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 04-30-2015 03:14 AM |
| Limited Slip diff oil Motul GEAR 300 LS 75W-90 | FRSToyota86 | Canada Classifieds | 12 | 08-22-2014 01:47 PM |
| clutch/gear box getting softer | zERoTu | Issues | Warranty | Recalls / TSB | 3 | 06-05-2014 09:18 AM |
| Display current gear without clutch engaged? | cfusionpm | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-26-2013 05:08 PM |
