Old 08-27-2015, 11:06 AM   #295
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
we wait a couple months between DIY days due to people obviously need $ to collect parts and then we can get started but.. it should be close to another DIY day.
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
The Following User Says Thank You to BRZtoni For This Useful Post:
V_86 (08-27-2015)
Old 08-27-2015, 10:39 PM   #296
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
I need to paint and install some bayson r rear spats that has fitment issues, wrap my dash, install my dashcam, and splice and dice my hids into my spec d head lights.... everything came on the same day and i don't know where to start lol
Vincenttam is offline   Reply With Quote
Old 08-28-2015, 11:42 PM   #297
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Let's wrap at AU! I'm going to wrap my sub and interior trim soon.
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
The Following User Says Thank You to LXXXV1 For This Useful Post:
Vincenttam (08-29-2015)
Old 08-29-2015, 07:47 PM   #298
Vincenttam
WtsTofu
Vincenttam's Avatar
Well that didnt last...
Old 08-30-2015, 09:58 PM   #299
VIC_BRZ
VIC_BRZ's Avatar
Drives: 2015 Subaru BRZ
Anybody have any tips for fixing an exhaust leak? I've tried to reposition the pipes but it's still there. Might need to show up to the next meetup to get that fixed.
VIC_BRZ is offline   Reply With Quote
Old 08-30-2015, 11:19 PM   #300
LXXXV1
LXXXV1's Avatar
Did you use new gaskets and/or torque everything down correctly?
φφκα
Old 08-31-2015, 02:25 AM   #301
VIC_BRZ
VIC_BRZ's Avatar
Used new gaskets, I torqued everything down but couldn't fit my torque wrench to do the front pipe to over pipe. I tightened it down until it was snug.
Old 08-31-2015, 10:46 AM   #302
LXXXV1
LXXXV1's Avatar
Can you isolate the source of the leak? Like which pipe/end?
φφκα
Old 08-31-2015, 11:52 AM   #303
VIC_BRZ
VIC_BRZ's Avatar
It sounds like it's the front pipe to over pipe connection. I installed a header last week and one side of the gasket (op to fp) was black. If it helps all the pipes are aftermarket except for the over pipe.
Old 08-31-2015, 01:19 PM   #304
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Before loosening and repositioning the front pipe, which would mean getting a new gasket, try to confirm it's the OP/FP connection with the bubble test? If the leak is obvious, this procedure is not necessary.
When exhaust is cool to touch, brush/spray some soap/water mix onto the connection and start up the car. Bubbles = bad.
If it is the OP/FP connection, I would guess either the FP/OP flanges aren't flat or the FP wasn't aligned just right. If the flanges are flat, try snugging up the OP/FP bolts first, before the FP/midpipe, then the FP hanger?
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
VIC_BRZ (08-31-2015)
Old 08-31-2015, 01:34 PM   #305
VIC_BRZ
VIC_BRZ's Avatar
Thanks I'll try the test after class today. If the flanges aren't flat would a thicker gasket help or would I have to take them to an exhaust shop to align?
Old 08-31-2015, 01:50 PM   #306
aegisdrgn
aegisdrgn's Avatar
If they aren't flat, depending on how bent they are, you might be able to get away with a different gasket, but it'll probably be less of a headache to get it straightened by the shop.
The Following 2 Users Say Thank You to aegisdrgn For This Useful Post:
LXXXV1 (08-31-2015), VIC_BRZ (08-31-2015)
Old 09-01-2015, 04:14 PM   #307
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
So I'm installing exhaust in the next couple weeks (used TRD). I ordered a new midpipe to to muffler OEM gasket, and I'll be reusing the front to midpipe donut gasket. Anything I'm missing?
Also, I know the front to midpipe should be torqued to 14.3, but what is the specs for the midpipe to muffler?
V_86 is offline   Reply With Quote
Old 09-01-2015, 05:49 PM   #308
LXXXV1
LXXXV1's Avatar
http://www.trdsparks.com/install/PTR03-18131inst.pdf
Make sure it comes with the 3 bolts/nuts. Removing the exhaust brackets may be a pain in the ass if you don't have the tool, unless you have strong fore arms. Also, fitting a torque wrench for midpipe to muffler will be difficult due to poor design.
Good luck. Pretty straight forward bolt on/off. I reused both my OEM gaskets, but I only had 1500 miles before I swapped. No leaks so far.
φφκα
Search this Thread:
Advanced Search
