#141 | |
Road-hole
Drives: 2013 Whiteout FR-S
because comparing stock entry level sports cars is like....
Yeah because comparing two stock entry level sports cars is like comparing stater bros non-fat milk to albertsons non-fat milk. One may taste slightly better, but they're still both non-fat milk and taste like shitty, milky white water. If you could turn one of them into 2%, then you can say one is better than the other. Right now, you can turn the twins into 2% or even whole milk, the miata, not so much. Jaden |
#142 | |
Drives: 2014 FR-S 6MT
Stupid argument is stupid. |
| The Following User Says Thank You to ChrisV For This Useful Post: | strat61caster (06-03-2015) |
#143 | ||||
Drives: 2013 DZE/01 (sold for MX5 ND1)
Anyway, which one was slightly faster is pretty irrelevant in this context. The point of the comparison was simply that the ND can hang with the BRZ on the track, and it's fun. The GTI beat both of them in lap times, braking test, and figure 8. Yet, they wrote this about the GTI: Quote:
#144 |
Off Topic
That's because it's a brand new car. Of course there's not going to be any aftermarket yet. However, there's already a large and well-established aftermarket for the Miata in general, so it won't take them very much time at all to pick up the new version and see what fits and what works best. As opposed to our car, whose aftermarket community was built literally from scratch when the car came out. I would bet that in three years' time, the aftermarket for the new Miata will be a lot bigger than ours is now.
#145 | |
So elite I'm 1338
Drives: WRB Subaru BRZ
As far as aftermarket that fits in the engine bay.. Lets not get carried away. That 2.0l skyactive has been around a while.
-Jack Burton |
| The Following User Says Thank You to tahdizzle For This Useful Post: | Jaden (06-03-2015) |
#146 | |
Off Topic
Either way, comparing the aftermarket for a car that's been around for three years to one for a car that's only just barely coming out is an invalid comparison. Of course one will be bigger than the other. |
#147 | |||||
Drives: 2022 BRZ Limited
cool meme, oh and screen name ![]() Quote:
I owned and modified one, my best friend and his brother also have one with the Kraftwerks kit so we get a chance to compare both cars, I know what it takes to install mods, drive at the street and track, get datalogs, have tons of empirical data to support my claims ..so unless you didn't get a chance to do the same, I would advise you to read more (ahem from people who can).. and you're one of the few who look at these cars and compare the 0-60 mph, times ![]() Quote:
![]() ![]() Quote:
AGAIN MIATAS are great cars and the new Miata will be even better same cannot be said for the aftermarket/vendor support.. there are only a few Vendors or makers for the Miatas and they solely work on the older Miatas, do you know how many FI alternatives exist for NC miata? The car on the left is my Miata (exhaust, roll bars ..etc)
| The Following User Says Thank You to glamcem For This Useful Post: | strat61caster (06-03-2015) |
#148 | |
| The Following User Says Thank You to glamcem For This Useful Post: | DAEMANO (06-03-2015) |
#149 | |
Claiming superiority based on your anonymous experience to anonymous people on the internet doesn't win you any favor, I'll play along with you in this discussion because I think you have valid points and the claims in this post are believable, but your tone is a huge turnoff. A. You claim the motor is shit compared to the old one, I countered with the most basic measurable metric commonly used, 0-60 times for an idea of how viable this motor is stock. I don't see a problem with this, can you explain yours? By no means am I judging the whole car/engine based on 0-60, as I clearly state, numbers does not a car or engine make. I'd be happy to hear your experience or readings about the 2.0L Skyactiv G in the ND. B. As far as I can tell nobody knows what it takes to put FI on a Skyactiv G, so no, and likely neither do you. C. I'm curious if that's a laugh in agreement or disagreement for the peak hp = shoe size in terms of profiling a motor. D. Nope, never researched heavily into the NC aftermarket, assumed it was similar in strength to the NA, I wouldn't mind hearing you elaborate. I know there's at least a kraftwerks kit now :P Edit: E. So how much time savings are in 10 lbs. and a brake kit that doesn't fade over one ~1:30 flying lap?
| The Following User Says Thank You to strat61caster For This Useful Post: | glamcem (06-03-2015) |
#150 |
Drives: AP2 S2000, S14 240sx
You said the Miata has no aftermarket. That's flat out wrong. The aftermarket isn't 240sx or BRZ/FR-S big, but it's not far off. Probably about the same as the S2000, RX7, etc.... It is very popular for autocross, and there are companies like Exomotive building full tube frame chassis for the NA/NB. It's a pretty big aftermarket compared to a lot of cars.
#151 |
So elite I'm 1338
this Skyactive engine is not new.
Go to the mazda3 forums and I'm pretty sure you can find out what it takes to turbo this engine :p 10lbs can make a world of difference in the hands of someone like pobst though.
-Jack Burton |
#152 |
It's almost impossible to tell what contributes to the overall lap times and what amount even after doing before and after tests because there's a lateral relationship on the data, let's say you shave 10 lbs from rotational mass which is HUGE for a car that weighs only 2300 lbs and more importantly has only 155hp , we still wouldn't be able to tell if we improved our times due to real advantage of the mod or the driver confidence , because one affects the other..unless of course you're a hot shoe like Randy Pobst
I would advise potential buyers to spend more time on searching and reading about the Miata because it may not be ideal for everyone, grass is always greener on the other side.. That being said I can even consider getting one for myself but that decision won't be based on a magazine article or internet hypes or ECHO , Imo Miata is a great second car , especially for those who are not planing to mod their cars and like Lago mentioned in his previous article ( see I'm not that far behind the magazine articles lol) , " one is a drivers tool other is a driver toy"
#153 | |
In no way am I bashing the MX-5 here either, I just hate some of these magazine comparisons and the final results. Even bringing the GTI into the mix makes little sense. It just felt like an afterthought. Hey, let's bring this F-150 into the mix too and see how it hangs with these lightweight sport coupes? |
| The Following User Says Thank You to thill For This Useful Post: | DAEMANO (06-03-2015) |
#154 | ||||||
many things that look good on paper don't really work on real world scenarios, well at least that the case for me and many other track junkies that I had a chance to interact withQuote:
| 4th gen ND Mazda MX-5 Miata | Dark | Other Vehicles & General Automotive Discussions | 1393 | 12-16-2021 02:09 PM |
| Twins vs 2016 Miata (ND body style) will be revealed in 15 minutes | glamcem | FR-S / BRZ vs.... | 56 | 09-13-2014 07:11 PM |
| 2016 mazda miata (MX5) reveal 9 PM EST | Ernie L | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-03-2014 09:41 PM |
| Motor Trend Car of the Year... | Dorb | BRZ First-Gen (2012+) -- General Topics | 1 | 11-13-2012 08:33 AM |
