Old 10-28-2017, 11:26 AM   #743
SteveT
Drives: 2016 BRZ Limited
Stock pully. Headers etc. extremely quick!
SteveT is offline   Reply With Quote
Old 10-28-2017, 11:31 AM   #744
Kylebrz
Kylebrz's Avatar
Drives: 2013 subaru brz
It's weird it's like every charger is a little different in performance my buddy's was making 8.5 psi and his failed mine fAiled at 20k kilometres but I was able to fix it. And now it's working great fingers crossed lol I will be going to a 90mm pulley and I will see how that goes...
Kylebrz is offline   Reply With Quote
Old 11-02-2017, 01:07 PM   #745
Andew727
Drives: Scion FR-S
Originally Posted by define198 View Post
Hi, i do not own a subaru/toyota.
I own a Honda S2000, with the hks supercharger kit. My supercharger failed in what looks to be a similar manner to you guys, i have not taken it to pieces to confirm.
How many cases total are their of failures? on the S2000 side their is mine, and my friends that i know of.
Did anything come of the upgraded piece?
Not sure if any of you guys had this problem, but the provided BOV did not work with my car. When i came off throttle i would get a constant steam train flutter, i had this issue for 6 months until i upgraded the bov to a Tial, not sure if any of you guys had similar? and not sure if this contributed to the chargers demise. Im just worried that this will happen again with another charger.
It lasted 14 months, Roughly 5.5k miles.
I was basically forced into buying a second kit at half price or i could have waited 10 weeks for a supercharger to be inspected and repaired under warranty (not very convenient). I should have bought a turbo kit at this point.
At least the customer service was there. Now I have to communicate with someone in japan directly. they will probably send me through the same process. its just a shame. i spent a lot of money through HKS and it has been rough time chasing my ass only to find out the supercharger is failing again. I will agree the performance is there for sure when working properly... but that performance needs reliability which this kit lacks completely.
-Andrew
Andew727 is offline   Reply With Quote
Old 11-06-2017, 10:35 AM   #746
Andew727
Drives: Scion FR-S
*Update* I located the issue after going back over everything. a small sliver was in the recirculating valve rubber nipple. i replaced the recirc valve with one from the previous kit. Vacuum is back to -23 at idle and the car runs fine again.
THANK GOD!
The Following User Says Thank You to Andew727 For This Useful Post:
zeal86 (11-06-2017)
Old 11-14-2017, 02:31 PM   #747
tomerino1
Drives: N/A
https://www.instagram.com/p/6CwwOKAa...zunorimiyagawa
https://www.instagram.com/p/5JR3VMga...zunorimiyagawa
Has anyone here tried or thought about it? I love their intakes haha
tomerino1 is offline   Reply With Quote
Old 11-15-2017, 12:30 PM   #748
Andew727
Drives: Scion FR-S
I make 15 psi on a 90mm pulley unrestricted.
Old 11-16-2017, 11:06 AM   #749
Kylebrz
Kylebrz's Avatar
I am putting the Perrin intake on with the hks charger
Old 11-16-2017, 11:07 AM   #750
Kylebrz
Kylebrz's Avatar
Who ever had that intake on there car ... the belt they are using will last a week lol
Old 11-16-2017, 08:32 PM   #751
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
basically, boost differ from altitude & IAT even with same kit.
but in HKS v2 kit, major factor is restrictor inlet diameter.
Without restrictor ( 48mm ID of intake Pipe ) it makes 13~15psi max boost
https://datazap.me/u/yobiwan/sc-dw45...zoom=1959-2146
With 43.5mm it makes 11.x psi max but flat boost.
https://datazap.me/u/yobiwan/new-435...zoom=6094-6422
both log from same altitude.
Stock ID of restrictor was 39mm and it makes about 8~9 PSI max@6000 and decreased to 7~8psi 7400.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 12-16-2017, 03:44 PM   #752
wbradley
Sarcastic SOB
wbradley's Avatar
Hey everybody, it's been a while but I just received a new 7040L. As much as I'd love to pop it in and test it now I am going to wait until spring, maybe a week before the car goes back on the road again. This way the unit won't run for the first time in cold temps where there is additional stress internally.
I will be using the summer (high temp) traction fluid so again it's best to install when in the correct temp range.
I hope everyone has been enjoying their cars.
Mine will end up being a classic, I am quite sure after 5 1/2 years ownership and only 55,000kms (35000 miles).
Kyle, what's up with yours? Anything I can help with, pm me if so. And merry Xmas!
Old 12-19-2017, 07:22 PM   #753
JadeBRZ
#ProjectBRZ
JadeBRZ's Avatar
Drives: SWP BRZ
I just wanted to add I got the V3 kit put on feb. 2016. About June of this year I started to notice a decline in power. After I stopped driving it in Aug. and got another car, the next time I drove it, I realized the supercharger wasn't doing anything and it was slower then stock. The place that installed it blamed me not changing the supercharger oil, even though HKS says in the instructions it does not have to be changed. So now I have a $4000 paperweight......
I should have went turbo, or nothing at all.
Fuck HKS
JadeBRZ is offline   Reply With Quote
The Following User Says Thank You to JadeBRZ For This Useful Post:
Efferalgan (12-20-2017)
Old 01-05-2018, 04:58 PM   #754
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
i am really new to this, but is there a way to find out if the kit fitted in the car is V2 or V3, like is it written anywhere. just curious.
killsafkat is offline   Reply With Quote
Old 01-09-2018, 10:39 AM   #755
Efferalgan
Drives: Toyota GT 86
Drop a picture here. The mounting bracket and pipe diameters are the key visual difference.
Efferalgan is offline   Reply With Quote
Old 01-17-2018, 07:05 AM   #756
Turtle rush
Drives: Fr-s
Average numbers for v3 kit on 91?
Turtle rush is offline   Reply With Quote
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4305 01-08-2024 07:54 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
