86WORX
Old 06-13-2017, 05:24 AM   #659
Apex-Apex
Apex-Apex's Avatar
Official HKS USA just opened again.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 06-15-2017, 01:44 AM   #660
Evil Rocky
Drives: FRS
I wonder what they are going to do with damaged super chargers. I am still on the fence on getting this. I am like 1200 away from this or the SBD kit since the service and support is phenomenal!!
Evil Rocky is offline   Reply With Quote
Old 06-16-2017, 03:43 PM   #661
Kylebrz
Kylebrz's Avatar
Drives: 2013 subaru brz
All the gts7040l chargers will fail eventually. I am have a prevention fix and also working on a redesigned end cap made out of heat treated and thicker material so it doesn't jump threads . I will have the first one done this week and I will show pictures to compare .
Kylebrz is offline   Reply With Quote
The Following 6 Users Say Thank You to Kylebrz For This Useful Post:
CxG (06-19-2017), Efferalgan (06-30-2017), Evil Rocky (06-16-2017), makinen (06-20-2017), Yobiwan (06-18-2017), zeal86 (06-16-2017)
Old 06-16-2017, 05:08 PM   #662
Evil Rocky
Drives: FRS
^^^ KyleBRZ that is awesome!!! So is that the serial number that is failing? The gts7040I?? Or think all HKS superchargers?
Old 06-17-2017, 05:52 PM   #663
wbradley
Sarcastic SOB
wbradley's Avatar
Well, I hate to say it but here I am back, the originator of this thread.
My blower appears to have just failed. It was a replacement which I paid for and received in Jan 2016 after waiting 6 months for it to arrive from Japan.
I was getting zero boost so removed and checked the blower. It is in exactly the same state as others I saw on this thread that failed in Russia. The annulus has separated at the threads. I bought this from HKS North America's recommended dealer at the time.
I am massively disappointed and moreover if HKS denies fault for the same failure seen multiple times here now I will make a lot of noise. Plus the 6 month screw around i had last time actually getting the part was ridiculously unacceptable. How can they sell these and carry zero backup? People's cars are down when these things fail.
The unit has ~7000 miles on It, stock pulley always. Stock fuel and custom tune with 7000 rpm fuel cutoff. There is nothing I could have done to have caused this.
I will report my results here yet again.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
Efferalgan (06-30-2017), Metabrz (05-18-2018)
Old 06-19-2017, 04:10 PM   #664
Kylebrz
Kylebrz's Avatar
That's shitty news man I will put up a post of my permanent fix for this issue as soon as it's done being tested!
Old 06-19-2017, 04:11 PM   #665
Kylebrz
Kylebrz's Avatar
So far it's just been the blowers that run in reverse to the belt rotation
Old 06-19-2017, 05:37 PM   #666
WRX4ME
Drives: 2016 BRZ HyperBlue, 2015 WRX Red
Can you elaborate on that a little? Trying to understand what is occurring.
Thanks
WRX4ME is offline   Reply With Quote
Old 06-19-2017, 05:45 PM   #667
Kylebrz
Kylebrz's Avatar
Thanks
Yea so the charger system is a 3 piece drive it has a drive stub that has the dowels for the oil pump and it threads into a cap that threads to the outer casing that spins the proprietary system .....
so if you look up at the pics I have posted before the cap is stripped off of the drive part of the charger ......it just spins without actually spinning the proprietary system.
They used very thin material which allows it to expand and contract which is never good with threads so I have a piece that is much thicker where the threads are so it doesn't expand and it will be heat treated to avoid that as much as possible and it's also dynamic balanced so it won't vibrate!
The Following 4 Users Say Thank You to Kylebrz For This Useful Post:
makinen (06-20-2017), WRX4ME (06-19-2017), Yobiwan (06-21-2017), zeal86 (06-19-2017)
Old 06-19-2017, 06:01 PM   #668
WRX4ME
Thank you for that clarification. As to your earlier comment about it just being the blowers running opposite to the belt rotation, are you saying it's partially due to how the unit is oriented in the BRZ/FRS? The reason I ask is because I've been nosing around in the Honda forums for threads related to the same HKS unit and haven't run across similar difficulties. If I completely misunderstood your comment (which is entirely possible), I apologize.
The Following User Says Thank You to WRX4ME For This Useful Post:
Kylebrz (06-19-2017)
Old 06-19-2017, 06:03 PM   #669
Kylebrz
Kylebrz's Avatar
I will take a lot of pictures when I'm done to show exactly where hks made a giant mistake lol and how it's gonna be fixed
The Following 3 Users Say Thank You to Kylebrz For This Useful Post:
Evil Rocky (06-19-2017), WRX4ME (06-19-2017), zeal86 (06-19-2017)
Old 06-20-2017, 05:55 PM   #670
wbradley
Sarcastic SOB
wbradley's Avatar
All left drive cars have the blower spinning opposite to the belt direction. That is why the L in 7040L, it blows to the left. The fault internally has nothing to do with spin direction. Look up rotrex drive unit and you will find clear pictures of the annulus. This part has a seam which is opening, detaching the internal drive unit from the input. Result, free spinning input shaft, traction fluid keeps pumping, zero compressor drive.
Old 06-21-2017, 02:55 PM   #671
WRX4ME
I understand that in the past, HKS utilized a Rotrex unit for their Supercharger systems. With the 7040 unit, this is something that HKS has developed over a period of time, however it utilizes the Traction Drive system which according to Rotrex technical documents is a patented setup. So, does Rotrex still play any role at all in the manufacture/development of the HKS supercharger unit?
Old 06-21-2017, 03:28 PM   #672
Kylebrz
Kylebrz's Avatar
I meant hks L style charger it's not because of it being left hand drive cars cause my old rotrex was right hand rotation and it was mounted on the front of the belt like the hks. The reason why the gts7040l rotates to the left is to utilize the factory air box and minimize the amount of intercooler piping. Keeps the cost down by a bit... and the rotrex is totally different from the hks.... rotrex had nothing to do with this charger.
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4305 01-08-2024 07:54 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
