#128 |
Touge worship
Drives: Forester STi SG9
#129 |
Drives: Scion FR-S
v2 must come with a smaller pulley stock. im only pushing 9-10 psi, a 95-90mm pulley will put me at 14 "they say". Thats where i want to be. i still would love to know what the recommendations are "FROM HKS" for the restrictor plate boring and removing. my fuel supporting mods will more than handle the extra FI. i also plan to engineer a new bracket to relocate the SC and reduce piping like evasive has done on their race car.
#130 | |
Drives: Toyota GT 86
| The Following User Says Thank You to Efferalgan For This Useful Post: | CxG (09-11-2015) |
#131 |
Drives: 2013 FRS
any idea on how much power the V1 maxed out at 14 PSI will make w. suporting mods?
I'm trying to decide what clutch to go with |
#132 | |
Touge worship
Piping also plays a role in smoothing the air delivery, and the intake side goes back to using stock airbox with an HKS filter. As of how much whp , well all depends on your tuner ... on a dynapack dyno, it could score from 280 - 300 (they read low, a stock car returns about 145-150 whp) As for the clutch, HKS LA clutch is great, the flywheel offers extra re-activity. |
#133 | |
Drives: Scion FR-S
#134 | |
Touge worship
Without the V2 intercooler, I don't wanna see your intake temps ... chances are you don't really have that much power after the original intercooler is heatsaocked. Also, easily over 300whp ok , how much was the car stock on the same dyno ? ![]() Again, mechanicaly, you can go 14 psi ... on a V1 and a stock motor, but I don't recommend that to anyone, and yes I know many will disagree, untill they blow something and call it on the HKS. Trust me I know what that kit can deliver, in my case we are talking adding 220whp over the stock number ! So on E85 i would probably add 300whp to the 145 stock whp ... But I would not do that without certain precautions
| The Following User Says Thank You to HaDDeS For This Useful Post: | CxG (03-17-2016) |
#135 |
Drives: 2013 FR-S, HKS V2 S/C
I'm happy to finally be able to let the cat out of the bag. The V3 has been released!
| The Following 2 Users Say Thank You to Scott@HKSUSA For This Useful Post: | craigpitts7 (09-26-2015), Egyptn (09-27-2015) |
#136 |
Drives: 2013 firestorm fr-s
so no more restriction plate I see but larger pulley does that mean boost is still the same as the ver2?
| The Following User Says Thank You to brady86 For This Useful Post: | Egyptn (09-27-2015) |
#137 |
Same boost pressure (~7-8 psi), but with cooler, higher density air for increased efficiency and more power.
This is due to the larger intercooler, larger intercooler piping, the lack of an inlet restrictor, and a larger diameter pulley to reduce the compressor speed. |
| The Following User Says Thank You to Scott@HKSUSA For This Useful Post: | Egyptn (09-27-2015) |
#138 |
Drives: TIE interceptor; BRZ13
Is it easier to install? No cutting to place the supercharger?
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
#139 |
You don't have to cut anything to mount the blower itself but HKS does recommend trimming the core support for the UICP and you do have to drill a couple holes in the crash beam to mount the intercooler.
If you're comfortable and/or experienced with installing bolt-ons, follow HKS' extremely detailed instructions and you'll be done in 6-8 hours. |
#140 |
Not right. You have to cut off the top platic pulley (right under the alternator pulley) to istall the kit - the blower is located right there. To return back to NA, you have to get a new part of the engine which you altered.
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4305 | 01-08-2024 07:54 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 03:31 AM |
| Five Axis Edition FR-S Owners Thread | digital_assassin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 563 | 07-08-2015 10:22 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 01:58 PM |
| Supra Owners Build Thread | BoostJunkie | Other Vehicles & General Automotive Discussions | 164 | 03-12-2012 10:37 AM |
