#15 |
Overthinking it
Drives: BRZ in CS
Jack of all trades, master of none
| The Following User Says Thank You to mla163 For This Useful Post: | strat61caster (06-01-2015) |
#16 |
It's not a hypothetical, I've experienced it, the brake pad thread is 9 pages long, it's noted in professional reviews for crying out loud. All-around implies it can complete the basics of what's being evaluated, and stock, this car can't. When the ordinary mom gives up before she gets her panties off and goes to bed after 5 minutes when you made time for 30 it's time for a divorce, luckily it's a fixable problem, but only if you're willing to fix it.
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Teseo (06-01-2015), Ultramaroon (06-01-2015) |
#17 | |
Drives: frs
Im amuse how this car become a track menace with the rights tun, and perfect donor for an engine transplant. This is good entry car period no matter what path go. |
| The Following User Says Thank You to Teseo For This Useful Post: | Ultramaroon (06-01-2015) |
#18 | |
Drives: '23 BRZ Limited
What person that has any kind of track experience would think the OEM brakes, and by that I'm assuming you mean stock fluid/pads, would hold up to any kind of serious track work? These aren't Carbon ceramic brakes. However, I suspect for the vast majority of people good pads/fluids will be fine. Granted I haven't been able to track this car yet, all my experience is from Miata's and sport bikes. |
| The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | CSG Mike (06-01-2015), strat61caster (06-01-2015) |
#19 | |
Get the rear sway only, and adjust to taste. *However*, if you're aligning it to the 95%, then you want to be at around -.75 front camber and about -1.25 rear camber, with 1/16" toe-in front and rear. |
#20 | |
Drives: Toyobaruion
Hopefully a rear sway even at softest settings I won't be at an oversteer bias. Guess we'll see. |
#21 | |
Edit: My OEM brakes served me well my first ever track day, faded on my second and I replaced the pads and fluid for the third, aside from needing a bleed after the first day with new fluid they've been golden ever since. From what I've seen, all it takes is $300-$500 in pads and fluid to track prep this car, thrash on it all day and drive it home. The other stuff I listed above just makes it easier in the long run, easy weak points to address on a budget. Last edited by strat61caster; 06-01-2015 at 06:39 PM. |
| Center Cap Trades? My Scion caps for your Subaru caps? | ubersoph | Wheels and Tires | 0 | 07-10-2013 01:28 PM |
| Great Shark Fin pre painted factory color great price | marinjim | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 12-04-2012 12:49 AM |
| Where ti jack car up at? | skatery1989 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-13-2012 02:53 AM |
