#99 | |||
Drives: 2013 Black FR-S
According to your graph you posted, your setup makes 25 more whp on 92. The ace combo makes 34 more whp on 91 ACN. Do you have a FP? Do you know of any results of OFH + FP? Quote:
#100 | |
For reference: JRSC (w/ HKS, which DO showed to show no gain on FI) vs HKS vs Stock at DO CSG's JRSC dyno (all 5th gear) ![]() Regardless, a totally unscientific comparison between your OFH + 92 vs ACE + ACN 91.
#101 |
Drives: Raven FR-S 6M
Are CSG's dyno pulls all done in 5th gear? It may also be a huge factor if comparing to other dynos done in 4th gear.
“The World is Flat”
[||•]=(86)=[•||] |
| The Following User Says Thank You to Apoc For This Useful Post: | Jrdad (10-13-2017) |
#102 | |
Alignment and tires also play a huge factor on dynojet readings as well, hence why we opt for the Dynapack to perform the measurements. Side note: This engine loves octane... Last edited by CSG David; 06-09-2015 at 02:52 PM. |
| The Following 2 Users Say Thank You to CSG David For This Useful Post: | BRZChix (06-09-2015), driftking96 (02-09-2017) |
#103 |
Strictly technically speaking, the gear doesn't matter on a dynapack. The ramp rate/pull duration does. But yes, our ramp rates are such that we're roughly equivalent to a 4th gear pull on a dynojet, and the pulls are performed in 4th gear.
| The Following User Says Thank You to CSG Mike For This Useful Post: | BRZChix (06-09-2015) |
#104 |
StreetKart
Drives: 2014 Scion FR-S Monogram
so
much want not to be a stickler but you'll def have a difference in parasitic drag in different gears. 1st gear is going to eat far more power than 5th gear. much like going from a 4.10 to a 4.66 or whatever, i'd expect 5hp loss. the dyno cant get rid of friction upstream...
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
| The Following User Says Thank You to Roadcone For This Useful Post: | CSG Mike (06-09-2015) |
#105 | |
Drives: Subaru BRZ 2013
#106 |
Drives: Subaru BRZ
Do we have pictures of the tested headers?
#107 | |
The stock tune set IAM initial to 0.7 whereas most tuned cars will have IAM set to one and keep it their if tune is good for 91. The IAM will get to one on untuned cars if its running 93 fuel but pretty unlikely on 91, however a couple of partial throttle low load runs can often get your iam close to 1 on 91 fuel. I have seen cars on stock tune with iam less than 0.5 on lower grade fuels on stock tune, depending on how they are driven ie high load at lower rpm causes knock reducing iam and hence power. Throw a car on the dyno with iam at 0.3 as oposed to one with iam at say 1 and you will get about 5 hp or more difference due reduction in timing. If your on 93 fuel the iam on stock tune is pretty soilid at 1. and your running full timing in the maps. if you reset the ecu on a stock tune you get iam =0.7 as oposed to most tuned cars where iam will go to 1 after reset. On a stock tune you can only get iam to 1 by driving arround and getting minimal knock . |
#108 |
Drives: 2015 Brz Blue Series Pearl White
| The Following 3 Users Say Thank You to AlexBinJackson For This Useful Post: | CladMonitor (06-10-2015), CSG David (06-10-2015) |
#109 |
Drives: 2013 fr-s, sr20 180sx
#110 |
| The Following User Says Thank You to AlexBinJackson For This Useful Post: | CSG Mike (06-10-2015) |
#111 |
My dream setup right there! So ready for the dyno results!
#112 |
StreetKart
i know its the miracle header and all so far but has anyone mentioned what size the tubing is? also is it 2.5 or 3" collector?
| The Following User Says Thank You to Roadcone For This Useful Post: | raven1231 (06-10-2015) |
| Tags |
| nsfwseriouslythisisporn |
| [REQ]BRZ Independent Fog Lights | 1stGenBRZ86 | DIY (Do-It-Yourself) Guides | 3 | 04-17-2016 07:34 PM |
| What do I need for an independent tuner.. | Shady195 | Software Tuning | 2 | 07-23-2014 10:04 PM |
| Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East | JPxM0Dz | BRZ Photos, Videos, Wallpapers, Gallery Forum | 13 | 05-08-2014 09:06 PM |
| Vortech Finale Review Video | Track Testing | Part 4 of 4 | Dezoris | Forced Induction | 75 | 04-12-2014 01:45 PM |
| The Independent Review: Toyota GT86 | Boxer-4 | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-09-2012 07:22 PM |
