#253 | |
SLO NO MO
Some states include a visual inspection of the OEM emissions gear. In that case, they'll see the aftermarket replacements and fail it. Other states perform a sniffer test, depending on the equipment used and the tune involved, you may or may not pass. |
#254 |
Drives: GT86-ACE-JRZ-RPF1-Essex
If you disable the DTC, the readiness will stay to 0. Or do you have a way to set it to 1 ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
#255 |
#256 |
Was just a question, just curious
![]() Edit : you don't want to work with french tuners
| The Following User Says Thank You to MaximeT For This Useful Post: | Jrdad (10-13-2017) |
#257 |
Drives: '23 BRZ Limited
| The Following 3 Users Say Thank You to OkieSnuffBox For This Useful Post: |
#258 |
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
You all need to move to Florida. Inspections? Emission testing? CARB? 91 octane? What are those?
| The Following 3 Users Say Thank You to Freude am Fahren For This Useful Post: |
#259 | |
Drives: 2015 Brz Blue Series Pearl White
Lol people in California love to over react . It's not too bad to replace the headers before testing and reflashing back to stock. Just wait for carb (it's coming to you) and what is 91 I'm on e85 😋 |
| The Following User Says Thank You to AlexBinJackson For This Useful Post: | Coheed (07-28-2015) |
#260 |
#261 | |
Drives: DGM BRZ Limited
If you don't have CARB now, you might be ok for a while. Where I'm at, CARB isn't a requirement, but it may end up being so in a couple years. |
#262 | |
Drives: WRB JR BRZED
#263 |
If you still have one cat and 14,7 AFR, you should be fine with a warm engine.
#264 |
Frosty Carrot
Drives: The Atomic Carrot
I'm far from an expert, but my understanding is that O2 sensors read the partial pressure of oxygen in the exhaust stream, when compared to a reference air sample.
The partial pressure gets translated into a metric of combustion completeness (lambda - the normalized AFR). The ECU begins with a target ideal AFR and "learns" the best AFR for your fuel, based on a recursive algorithm. Although you want to be near complete combustion, most ECUs try to cycle between lean and rich operation to keep the catalyst operating efficiently. The ECU spits out a target AFR at this point. By combining the learned AFR of your fuel and the measured lambda, you get an estimate of actual AFR. The ECU compares the actual and target AFRs, which is useful feedback for the next combustion event. Correction is usually on the injector pulsewidth (since it's fast), but you can adjust the throttle or VVTI angles to manipulate the air flow (LOAD). Regarding catalysts, the catalyst flow, health, and efficiency are modelled. Flow is simple enough, it's a fixed volume, with some flow restriction. 1st order system w. small time delay in the sensors. From a health and efficiency perspective, they estimate temperature and oxygen storage states. If you're actively storing and releasing large amounts of oxygen, the catalyst can be 90%+ efficient. With an efficiency estimate and a time estimate... you can follow a volume of exhaust from the UEGO (upstream linear O2 sensor) to the HEGO (downstream switching-type O2). The metric for catalyst health isn't something I know much about... but going through the readiness cycle (lots of different driving situations) will help to guarantee that the models used to generate the health metric are accurate.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | churchx (07-30-2015) |
#265 |
Drives: 2014 GT86
Thanks for actually writing info instead of having fun at my expense. It doesn't say much though how those aftermarket sensor spacers manipulate/affect readings for secondary placement or how PTuning's headers can claim no CELs when it looks normal bungs in yet another catless header, or how to affect readings to fool ecu in more precise manner.
#266 | |
The truth is some people might not trigger it and some will depending on luck mods and tune and fuel. The ecu will be looking for specific reading from both front and rear 02 sensors and apply some weird algorythm to the reaing over time, if the reading fall outside what the ecu algoythm is looking for over time then bingo you get cel. its same with o2 spacers sometimes they work sometimes they dont, sometimes they just extend the time it takes cel to appear. Ask both those manufactures if they will give you your money back if it trigger cel without disabling codes ect in tune and i doubt they will say yeah sure we will do full refund |
| Tags |
| nsfwseriouslythisisporn |
| [REQ]BRZ Independent Fog Lights | 1stGenBRZ86 | DIY (Do-It-Yourself) Guides | 3 | 04-17-2016 07:34 PM |
| What do I need for an independent tuner.. | Shady195 | Software Tuning | 2 | 07-23-2014 10:04 PM |
| Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East | JPxM0Dz | BRZ Photos, Videos, Wallpapers, Gallery Forum | 13 | 05-08-2014 09:06 PM |
| Vortech Finale Review Video | Track Testing | Part 4 of 4 | Dezoris | Forced Induction | 75 | 04-12-2014 01:45 PM |
| The Independent Review: Toyota GT86 | Boxer-4 | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-09-2012 07:22 PM |
