Old 07-22-2015, 02:01 AM   #211
shellslinger
Drives: Whiteout FRS
Not sure if this has been answered yet, will this throw a CEL? It seems like it will most likely since there's not cat.
If it does throw CEL, anyway to remedy?
Thanks all.
shellslinger is offline   Reply With Quote
Old 07-22-2015, 02:15 AM   #212
steve99
Thanks all.
Your wasting money buying this (or most other headers) without getting a tune to suit. you will likely only see about 1\3 of the possible gain without a tune.
even most aftermarket catted headers will thow a cel eventually
02 spacer on second 02 sensor may work but its an expensive header and would be wasted without proper tunning
in the tune they will disable cel code P0420 cat efficiency
The Following 2 Users Say Thank You to steve99 For This Useful Post:
CSG Mike (07-22-2015), shellslinger (07-22-2015)
Old 07-22-2015, 02:31 AM   #213
shellslinger
Got it thanks, was the answer I was looking for!
Old 07-22-2015, 03:56 AM   #214
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
I will add that if you run a device that increase airflow without a tune, AFR will get too lean and damage the engine.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 07-22-2015, 04:40 AM   #215
steve99
the ecu will detect a difference in measured afr (by 02 sensor) and commanded afr (what the ECU is asking for) in closed loop operation and alter the LTFT compensation to bring these values closer together. while compensations may not be ideal they will then be applied in open loop operation to correct afr differences.
your more likely to run into issues changing an intake than changing header.
you not going to get much advantage from header unless you alter intake and exhaust cam timing to take advantage of the different flow characteristics of the header and lack of catylitic converter.
The stock tune runs very rich afr targeting (commanded AFR) of about 10.7 afr at higher rpm unlikely your going to get it to run lean enough to do damage on stock tune by running a header alone. Leaning it out a bit gives more power.
most tuner target about 11.5 to 12.5 on petrol NA
CSG Mike (07-22-2015), MaximeT (07-22-2015)
Old 07-22-2015, 04:43 AM   #216
MaximeT
MaximeT's Avatar
Damn, 10.7 that's a lot of fuel.
Old 07-22-2015, 05:00 AM   #217
steve99
yes get a stock rom and open it in romraider :-)
Old 07-22-2015, 05:04 AM   #218
MaximeT
MaximeT's Avatar
Thx for the screen shot.
Does the stock engine goes to 1,4 load at 7400 rpm ? Sounds like a lot of power to me (if not lost by rich AFR).
Old 07-22-2015, 05:24 AM   #219
Tim Radley
Drives: GT86, SQ5, RS3
Why on earth would they make it run that rich?
Tim Radley is offline   Reply With Quote
Old 07-22-2015, 05:27 AM   #220
MaximeT
MaximeT's Avatar
Looks like they are the last few points of the map where you're not supposed to go. They are calibrated to keep the engine safe, just in case you go there for some reasons.
That's my 2cnts
Old 07-22-2015, 05:30 AM   #221
steve99
I can only assume its for knock resistance on rubbish fuel like in south africa where you can only get 95 ron fuel, and just being safe
all the stock roms run same fuel table any country
Old 07-22-2015, 05:35 AM   #222
steve99
on stock car stock tune you generally wont see loads much over than 1.2
Old 07-22-2015, 05:36 AM   #223
MaximeT
MaximeT's Avatar
Thanks.
Old 07-22-2015, 05:40 AM   #224
Tim Radley
Wow. That's pretty bad then. Surely with lambda and knock built in it can deal with fuel changes. 10.7 is the road to bore wash on an NA engine.
Dyno chart for my bone stock 86 attached. UK car with 100 miles on it.
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 07:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 10:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 09:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 01:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 07:22 PM
