Old 05-19-2015, 07:51 PM   #1
Ludacrits
Ludacrits's Avatar
Drives: 2007 Porsche Cayman S MT
Top mount intercooler?
Would a wrx or sti intercooler be viable? Would it even fit under a hood like this:
http://www.carid.com/rksport/ram-air...zfAaAn1u8P8HAQ
Ludacrits is offline   Reply With Quote
Old 05-19-2015, 08:06 PM   #2
gramicci101
Off Topic
Not really. The throttle body on the WRX and STi faces to the rear, so the intercooler can dump straight into it. You'd have to do some inspired pipe work to route the airflow around to the front.
Old 05-19-2015, 08:18 PM   #3
swarb
no comment
Old 05-19-2015, 08:38 PM   #4
Ludacrits
Ludacrits's Avatar
Thanks!
Old 05-19-2015, 09:26 PM   #5
Ashikabi
Ashikabi's Avatar
Liquid cooled intercooler. Problem solved
Old 05-19-2015, 11:21 PM   #6
kbogarto
Drives: 2013 BRZ limited WRB
Don't a lot of WRXs relocate their intercoolers to the front for better cooling? Why put it on top?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 05-19-2015, 11:26 PM   #7
gramicci101
Off Topic
They change it to a FMIC because a TMIC will heat soak after a while and it's limited on volume.
Old 10-16-2019, 11:29 AM   #8
MichaelBrown86
MichaelBrown86's Avatar
Drives: 2015 Subaru BRZ Limited
Sorry for reviving such an old thread, but I am on a quest to figure out a TMIC turbo setup for the BRZ/FRS/86. There's a lot of moving parts that need to come together... but I think I have a setup that might just work:
So... IBR makes a kit for the 2015+ WRX, inwhich they have some spacers/adaptors to run a BRZ intake manifold (our manifolds offer better flow, and they can utilize the front-facing throttle body for simpler FMIC pipe routing).
https://www.ibuildracecars.com/store...t-brz-manifold
I want to do the opposite. I want to either utilize a WRX manifold (not sure how i'll get back the port injection), or make an adaptor that'll simply flip our manifold around, while possibly utilize the WRX mounting brackets + TMIC.
Meanwhile, we can utilize either the Works Stage 1 Turbo-kit or the PTuning Turbo-Kit (minus their piping) to get the rear mounted turbo setup that would offer an efficient route to the intercooler.
https://www.ft86speedfactory.com/wor...3-ft86-mt.html
https://www.ptuning.com/ptuning-fr-s...p-tbk-15000-v2
The only other issue is a hood, but I think that's the least of our worries at this point.
Build Thread:
https://www.ft86club.com/forums/showthread.php?t=133150
MichaelBrown86 is offline   Reply With Quote
Old 10-16-2019, 11:40 AM   #9
ka-t_240
Would a traditional OEM Fit TMIC even fit in these bays? They can be tight fitting in the wrx/sti and our engine sits was further back.
ka-t_240 is offline   Reply With Quote
AVO Turbo Front Mount Intercooler (BRAND NEW) tamsau Engine, Exhaust, Bolt-Ons 1 06-18-2014 11:53 PM
Anyone use Kenu Airframe vent mount for phones? Or any other mount? jhh3000 Electronics | Audio | NAV | Infotainment 2 03-12-2014 12:44 AM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 02:37 AM
How bad is turbo without intercooler? mid_life_crisis Forced Induction 50 06-23-2013 01:57 PM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 11:58 AM
