#85 | |
Drives: '14 981CS, '99 NB1
#86 | |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Its also easy to trim the JDM panels under the fuel tank if need be, they are ABS plastic and can be cut with a knife or sharp scissors just like a fender liner. |
#87 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
Diff covers bolt to the same points on the rear of the fuel tank as the JDM covers. They basically follow the contour the fuel tank on the rear side. I'll work on getting some better photos but it's difficult without a lift. |
| The Following User Says Thank You to VerusEric For This Useful Post: | Rosticles (06-08-2015) |
#88 |
Drives: 13' Scion FRS Track car
yes please update us on the under JDM panels, I think most people who are looking into better under carriage aero will be looking into the JDM panels as well.
If someone as the JDM panels and the read diffuser I think that would really help ... sales
2013 Scion Frs Track Car - Sold.
#89 | |
I believe a few of the first people trying this out will try to install these with the JDM panels. Hopefully they will be able to chime in. The diff/suspension covers reduce drag quite a bit more than the JDM panels as the body itself is fairly flat; where the diff covers cover a large open area that causes turbulence. |
| The Following User Says Thank You to VerusEric For This Useful Post: | cslntuee (06-14-2015) |
#90 | |
#91 |
Junior
Drives: a car
that exhaust is beautiful.
#92 |
Drives: 2014 Raven Scion FRS 6MT
#93 |
#94 |
#95 |
So uh.... @NotEric6... I don't think im giving you the prototype back =x I went on a "spirited" drive yesterday (~250 miles through the hills) and after 10 days of borrowing it... oh man. This fucker makes a substantial difference. Not only do I no longer have that fearful rear lift under acceleration but I can actually turn at high speed and the car feels fairly planted. I wasn't expecting such a big difference with a simple piece of aluminum. I knew it would make a difference as I remember the difference of me removing my muffler but still... hah. That and the fuel economy bump i got vs running w/o a muffler practically makes this part pay for its self with anyone that has an aggressive exhaust setup. I need to install that splitter now asap :P
Oh and I finally managed to trip on a fin. it took a lot of work and involved me actually rubbing against my car... HAHA can we has the rest of your under panel setup now?! Somehow I haven't managed to break this piece yet... It gets my stamp of approval. (I break fucking everything!)
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following 8 Users Say Thank You to nelsmar For This Useful Post: | BatStig (06-15-2015), civicdrivr (06-15-2015), DAEMANO (06-15-2015), GT86_PRAGUE (06-15-2015), johan (06-16-2015), Takumi788 (06-15-2015), VerusEric (06-15-2015), wparsons (07-06-2015) |
#96 | |
Thanks, Eric |
| The Following 2 Users Say Thank You to VerusEric For This Useful Post: | johan (06-16-2015), Kostamojen (06-15-2015) |
#97 |
@NotEric6
what about some information about adding more cooling to the differential ? I don't see the point of selling a special plate. But considering you have all the computer models, I'd love to hear your opinion on where a differential cooler or additional cooling could be had. Either adding differential cooler in the muffler area, tons of space there. or simply adding some ducting/opening in the current setup, to actually direct more airflow to the diff'. Phil.
#98 | |
If you want or need differential cooling, you'll need to go to an external cooler in our mind. A cast iron diff doesn't shed heat very easily and the aluminum cover on the rear doesn't offer itself to nice airflow either. Our current "diff covers" do not cover the diff though and air can still hit the differential quite easily. I'm sure airflow is slightly reduced but not to the point we're worried about it. |
| Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory | naikaidriver | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 02-28-2017 03:48 PM |
| Single-Exit Exhaust Diffuser/Hole Problem... Solution! | Anthony | Cosmetic Modification (Interior/Exterior/Lighting) | 75 | 10-13-2016 08:40 PM |
| Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 09-22-2016 02:41 AM |
| DriveWay Labs Rear Diffuser - FT-86 SpeedFactory | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 435 | 01-15-2015 08:20 AM |
