Old 04-21-2015, 01:23 AM   #449
艾洛
艾洛's Avatar
Drives: Raven
Originally Posted by DarrenDriven View Post
Hi Darren, I preheated and left the headlight in the oven for a good 15 minutes but I've been struggling to get the two halves apart. Any other tips besides getting a good gap from the pointy end of the light and taking them apart by hand?
艾洛 is offline   Reply With Quote
Old 04-24-2015, 01:22 AM   #450
Jav
Drives: 2014 Stormtrooper FR-S
I used a screwdriver to slightly wedge around where the two halves meet then pulled apart from the pointy end.. hopefully that helps
Jav is offline   Reply With Quote
Old 06-11-2015, 05:25 PM   #451
rainmonkey
Drives: BRZ - Dark Grey
when you replace the 10mm bolts, are there torque specs to consider?
Thanks!
rainmonkey is offline   Reply With Quote
Old 06-11-2015, 05:36 PM   #452
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Thanks!
As tight as I could get it by hand with a screwdriver...
Old 08-19-2015, 08:32 AM   #453
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Regarding Winjet headlights
If anyone is thinking of doing this to Winjet headlights, you don't have to bake them to get them apart.
Yes you have to remove about 6 perimeter screws and there are the same tabs and hooks, however Winjet uses a molded rubber gasket and not goop to seal the two halves.
Yes heating it makes it more flexible, but I skipped heating the second unit and it came apart without drama in a couple minutes of careful prying.
Putting it back toget was dead easy on both units.
So skip step 17
Also, the high beam solenoid wires are brown/brown (stupid!) and the end connector is different than the Morimoti D2S retrofit projectors. I spliced the Morimoto connector onto the Winjet harness to make it cleaner.
Just a heads up
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
The Following User Says Thank You to FRS_Ken For This Useful Post:
Pbrown (08-19-2015)
Old 09-16-2015, 07:10 PM   #454
YvesSaintLudwig
Drives: 2015 Firestorm 6MT
Who knows a shop around LA/North Hollywood area that can do this? Im kinda scared to do it myself lol
YvesSaintLudwig is offline   Reply With Quote
Old 09-23-2015, 02:39 AM   #455
dirtyy
Drives: Whiteout 2013 FRS
Appreciate the write-up. Seals are holding up fine as of a week now.
dirtyy is offline   Reply With Quote
Old 10-14-2015, 03:53 PM   #456
S84kam
S84kam's Avatar
Drives: FBRZS
Would you guys recommend using plastidip in the housing?
S84kam is offline   Reply With Quote
Old 10-15-2015, 03:46 AM   #457
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Absolutely no. Get something with high temp
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 11-02-2015, 01:00 PM   #458
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I bought an FRS with this mod done. However, I have moisture inside the headlight
Any specific sealer to use when re-sealing them? I am going to take them apart and try to repair when I install my Perrin CAI.
Thanks!
justinco is offline   Reply With Quote
Old 11-03-2015, 12:46 PM   #459
ragequitfail
Drives: 2015 FR-S
Thanks!
Butyl Tape is what you need. I'm pretty sure it is the same stuff that was originally on the the headlight.
Found a youtube video using the stuff. Should give you an idea of what it looks like and how to use it.
[ame="https://www.youtube.com/watch?v=MbZn__zf8hU"]Lexus GS 430 fix cracked condensing headlight - YouTube[/ame]
ragequitfail is offline   Reply With Quote
The Following 2 Users Say Thank You to ragequitfail For This Useful Post:
hmong337 (11-03-2015), justinco (11-03-2015)
Old 11-03-2015, 01:19 PM   #460
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Thanks, that looks like it! Found this as well:
http://www.theretrofitsource.com/acc...glue-50254.htm
Old 01-09-2016, 12:28 AM   #461
ERIC86
ERIC86's Avatar
Drives: '16 Halo Fr-s
Originally Posted by ck-GT86 View Post
Updated my black-out last month, here's the latest edition: yellow inner reflectors for the high beam/DRL's. Blacked out the turn signals too
.ck
Attachment 69094
Sent from my HTC One using Tapatalk
Old thread, but what paint did you use for the yellow reflector??
ERIC86 is offline   Reply With Quote
Old 01-26-2016, 11:21 PM   #462
PresiO.
Drives: 2013 Scion Fr-s
This thread lead me to do my headlights and they came out perfect! I used the butyl tape that @ragequitfail said to use and it worked great. I wanted to paint the high beam reflectors yellow but couldn't figure out what paint to use so decided that I would just buy yellow lights later on.
PresiO. is offline   Reply With Quote
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 11:13 AM
Is Anyone Else Tired of SOA Information Blackout geb2391 BRZ First-Gen (2012+) -- General Topics 23 04-21-2012 10:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 03:45 AM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 03:24 AM
TRS headlight mod RRnold Other Vehicles & General Automotive Discussions 0 12-24-2011 05:20 PM
