86WORX
Old 06-28-2016, 12:05 AM   #29
DarkSunrise
DarkSunrise's Avatar
Originally Posted by zc06_kisstherain View Post
i was browsing and brought this up from old thread.
i always torqued to 80 lb and had no issue.
I was at the track a couple of weeks ago and was helping someone change out his brake pads. He had been using 70 lbs-ft for his lug nuts and they were SCARY loose. There's probably a fairly wide range of safe values, just don't go too low (or high).
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Tristor (04-16-2018)
Old 06-28-2016, 08:00 AM   #30
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I know bit also heard some people breaking stud torquing 89 ft lb.
Old 06-28-2016, 08:34 AM   #31
DarkSunrise
Yeah I think the studs on these cars are just a weak point. I've been ok so far using 90 lbs-ft, but will probably change studs at the end of the year.
2022 BRZ Build
2013 FR-S Build
Old 06-28-2016, 10:54 AM   #32
zc06_kisstherain
Drives: SWP BRZ
i re-tightened lug nuts to 85 ft /lb haha but when i torquing, it already set it to 85 lol
Old 06-28-2016, 11:12 AM   #33
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
No issues using Muteki lugs to 85 ft lbs for a year and change here.
I ran the same lugs and torque values on my 05 Forester XT for 4 years/80k miles before switching to ARP hardware, because I figured it was time.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 06-28-2016, 03:51 PM   #34
Ayoitszritchie
Ayoitszritchie's Avatar
Drives: '14 DGM BRZ Limited 6MT
Extended muteki lugs snapped on two studs on my passenger front hub and then snapped one stud on the front driver hub. Replaced stock studs to APRs and hadn't had a issue since. Stock studs are garbage.
Ayoitszritchie is offline   Reply With Quote
The Following User Says Thank You to Ayoitszritchie For This Useful Post:
Old 06-28-2016, 04:20 PM   #35
JazzleSAURUS
So the stock studs failed, you happened to be using Muteki lugs, and since switching to ARP you've been golden, right?
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Old 09-04-2016, 04:39 PM   #36
kpamir
Drives: 2015 halo white fr-s
I cant seem to find the info on these.
https://www.rallysportdirect.com/par...s-35mm-12x1-25
Anyone know if they have are rated to something other than stock ft-lbs?
kpamir is offline   Reply With Quote
Old 09-06-2016, 04:15 PM   #37
8R6
8R6's Avatar
Drives: FRS
its not the lug nuts that are "rated". it's what the stock studs should be able to take according to spec.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
p1l0t (09-29-2018)
Old 09-06-2016, 09:39 PM   #38
kpamir
Ok so whatever the manual says should be good then?
The FRS torque curve smbrm Scion FR-S / Toyota 86 GT86 General Forum 29 06-30-2016 05:10 PM
Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com Josh@FullyBolted.com Wheels and Tires 1 06-25-2012 03:04 PM
What's the reason for Torque dip in BRZ Dyno ? yuli8466 Engine, Exhaust, Transmission 82 06-23-2012 08:06 PM
Calling all wheel nuts. Staticfrost AUSTRALIA 90 06-13-2012 10:33 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 01:22 AM
