#15 |
Drives: Toyota GTS 86
I've confirmed this.
The Oil Pressure Switch is a 1/8" BSPT (tapered 28 threads per inch fitting). NPT is 27 threads per inch. I had to measure it with a thread gauge 10 times before I was certain it was 28TPI as they are so close it was very hard to tell. Given I could barely tell the difference I'd reckon you could probably jam a 1/8 NPT 27TPI fitting in there and it would seal. However it is definitely a 28TPI BSPT fitting. |
#16 |
Drives: 2015 BRZ
I can vouch for the vs BSPT vs NPT thing. I originally threaded a 1/8" NPT fitting in there, started the engine, and sprayed oil all over the place. Lost probably a half-quart before I shut it down.
#17 |
Drives: Ocho-Seis
Can anyone confirm the thread size of the oil temp sensor? It is bigger than the oil pressure sensor's 1/8PT.
Is it M12*1.5 or 1/4PT or? |
#18 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Note to self, buy a oil filter stacking setup for this.
#19 | |
Oil Temp is M10 x 1.25, but you don't want to Tee and take oil temps there. The better route is to get a Pan Drain Bolt Adapter. This will give you much better penetration into the oil vs a Tee that would be in stagnant oil. We do offer a dual 1/8PT of you're looking to add oil pressure and retain the OEM pressure switch. It's made from billet Stainless and far stronger than a brass Tee. [IMG]https://killerbmotorsports.sharepoint.com/:i:/g/EW8iyA88185Fn9bQkSs-eRkBkeMmT***1r8kDdUPcAsb0w?e=2CGSlN[/IMG] We do have a drain plug adapter for the 2022+ BRZ/GR with 1/8 PT for oil temp sensors. Last edited by KillerBMotorsport; 08-19-2022 at 05:01 PM. |
| The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | ballsdeep (08-11-2022), raisingAnarchy (08-11-2022) |
#20 | |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
https://www.killerbmotorsport.net/m1...t-adapter.html |
#21 | |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | villainous_frx (08-20-2022) |
#22 |
Drives: Halo
| OpenFlash Tablet: Tire pressure/Temp display? | Shiv@Openflash | Software Tuning | 52 | 03-09-2018 02:26 AM |
| Oil Pressure and Temp Gauge Install | BokChoiTV | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 12-29-2015 07:19 PM |
| Installing oil pressure/temp probes | xwd | Engine, Exhaust, Transmission | 12 | 03-14-2015 01:07 AM |
| Anyone run Tyredog pressure/temp monitors? | Thorpedo | Tracking / Autocross / HPDE / Drifting | 11 | 01-23-2015 02:51 AM |
| Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 05:54 PM |
