| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: brz
"Wherestheweed420"
#16 | |
Embarrassed Doge
Drives: Shibaru BRZ
#17 |
Drives: 2015 Asphalt FR-S
Does the 0805 or 0806 need to be wired? Can you just download to your computer later on/when you want to clear memory space?
#18 |
Drives: 2013 FR-S, HKS V2 S/C
The HKS DMR has front & rear cameras, records/saves files to a SD card, records audio, has GPS, and a G-force meter. Files are saved as standard MP4s so you can play them back on anything, but if you play them back through the HKS viewer software you can monitor speed, location through Google Maps, and G-forces with the videos.
[ame="https://www.youtube.com/watch?v=hQ5N_jP69fc"]R35 FSW ストレート HKS DMR - YouTube[/ame] http://www.hksusa.com/dmr-version-2-multi-recorder/ |
#19 |
The Stig's African Cousin
Drives: 2014 wrb brz
The 0805 and 0806 can be charged using a simple usb car charger it automatically starts when you turn your car on. And it uses a memory card or it's built in memory.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#20 |
#21 | |
also, the power is connected to the mount instead of the camera. so you can just slide the camera out of the mount if you need to upload files to your computer or show the video to someone else. no need to unplug the wires or anything like that. however, the internal battery is small so you'll probably only get like 5 or 10 minutes of usage before it dies.
#22 | |
#23 |
it comes with a car charger so you can plug it into your glove box socket. then just run the wire out of the glovebox into the a-pillar and up into the head liner. then drop it out above the rear-view and into the mount. or you can hardwire it with an add-a-circuit into an accessory fuse.
#24 |
Drives: brz
#25 |
Drives: brz
ok next time no punctuation
#26 |
Drives: brz
and thank you for all your reply i gonna check that later
#27 |
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
It's really alright, it's a car forum, it appears some folks are at the wrong place and looking to scrap. I just bought a cheap one off of HSN couple days ago and will waiting for it to come in. Cyclops 1080P I believe it was called for I think $59. Not expecting much, but thought would give it a try after I was ran off the road the other day with a guy changing lanes pulling a trailer, he never noticed I was next to his trailer in the fast lane, but he came on over anyway. |
#28 |
Drives: 2017 BRZ
OP needs a proper parking mode if it's to work with the car powdered off. It has to be hard wired, not using the accessory plugs, which have no power with the vehicle off.
There are only a handful that do this well. A low battery cutoff is also recommended so the battery doesn't drain too much. If its only for while driving, lots more options. If its G-sensor and super sensitive to movement and records at least 5 seconds before movement that might work too. C |
| What's in your camera bag when you do a car shoot? | ducky369 | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 01-26-2015 04:39 PM |
| Dashboard Camera? | DarrenDriven | Electronics | Audio | NAV | Infotainment | 26 | 03-09-2014 05:28 PM |
| OEM Back up Camera | Perihelion | Electronics | Audio | NAV | Infotainment | 11 | 03-25-2013 05:49 PM |
| Backup Camera Help | husker741 | Electronics | Audio | NAV | Infotainment | 2 | 02-13-2013 02:04 AM |
| In car black box camera | cgrey | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 08-26-2012 08:35 PM |
