Old 05-01-2015, 12:22 PM   #15
8R6
8R6's Avatar
Drives: FRS
Originally Posted by FR-Shred View Post
You criticize but do not offer a suggestion. I am not looking for a track set up, its a daily driver and I hope to keep as much of the stock handling in tact while also adding to the overall look of the car. I said from the research I found cheap coilovers are going to hurt the handling more than help and be worse than just a set of springs. I only mentioned the ones I was looking at so people can get an idea of price range, reviews if they have used them or a friend has used them, somethings along those lines.
i understand you're not looking for a track set up or some racecar-level type of stuff. my bad for not offering a suggestion... but by the time i read this thread you had already just gotten a set of springs so i figured theres no point in trying to suggest other springs yet.
if you want adjustable coilovers later down the road, i highly recommend ST. they're around 800-900 depending on vendor and thats usually including shipping costs too. rides "better" than stock imo, but still allows you to go lower than a set of 1" drop springs and handles great too since it allows you to adjust camber a little up front. Tein Flex Z's should also be available in a few months and those seem to be a great alternative too.
8R6 is offline   Reply With Quote
Old 05-01-2015, 12:55 PM   #16
Vroomin86
Drives: 2015 Fire
Where do most people get the Koni yellows ?
Vroomin86 is offline   Reply With Quote
Old 05-01-2015, 01:05 PM   #17
redlined600
redlined600's Avatar
Drives: Fr-s
ftspeedfactory.com is the cheapest I've found. Make sure you get full struts and not inserts(unless that's what you really want), some sites are not always clear aside from the actual part numbers.
Old 05-01-2015, 02:02 PM   #18
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
Go with fortune autos for 1.1 from ft86sf
904FRSlow is offline   Reply With Quote
Old 05-01-2015, 02:19 PM   #19
Vroomin86
Drives: 2015 Fire
thanks man, so those have adjustable dampening? I want the full struts
Old 05-01-2015, 02:50 PM   #20
wparsons
wparsons's Avatar
Koni yellows are rebound adjustable, not compression.
flickr
suspension question... FloridaBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-17-2014 01:37 PM
Suspension Question TONYpepperon1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-12-2013 09:57 AM
Question for you suspension Guru's invzabomaster Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-13-2013 06:26 PM
suspension question Bruninho8 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-14-2012 06:03 PM
BRZ vs. FRS suspension question smbrm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-12-2012 10:55 AM
