#57 |
Shadetree Project Ratchet
Drives: series.Blue
From everything I have read, there is no stock limiter. The car is drag limited to 136 MPH at stock power. With my areo mods, stock ECU and bolt ons I have in theory, once or twice, may or may not have, on occasion, off public highways, in the middle of the desert, hypothetically, gone 137mph and the car was still pulling.
Header, catback, & K&N.
The Shadetree Project: I turn wrenches
#58 |
Panda Trueno
Drives: No twin now.
#59 |
Drives: 2013 BRZ Limited
Any gains in mileage seen at cruising speeds will be mostly offset by increased effort of taking off. Those that have gone with lower gears say they only lost 1-2 mpg at most IIRC. The bigger benefit of lower RPMs at cruising speed would be less exhaust noise while cruising.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
#60 |
Drives: 2014 GT86
Selling point of these cars is handling. NOT top speed, NOT cruise comfort or good sound insulation. Increasing something that is not their strength & purpose at expense of severely hurting THE purpose/strength of them makes me think that wrong car was bought. Even for twins MSRP there are faster ones, there are more comfortable/quieter ones. It's hard to find better handling ones at this price range (except Miata of course, but i doubt it's top speed or comfort being very high on list too).
#61 |
Drives: waiting on a 2021...
The beauty of these cars is they're cheap enough that they can be modded however somebody want to mod them. AutoX? Yep. Drag racer? Yep. Bonneville flats salt liner? Sure, why not. Rocket Bunny cambered out parking lot crawler, yes sir. It kills me that some people think you can only build these cars a certain way, and only use parts that cost a certain amount.... Come on, I'm a hot rodder. Improvise, adapt, haul asss! 😃
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
| The Following 3 Users Say Thank You to zooki For This Useful Post: |
#62 |
The way these cars are tuned from the factory make it very hard to achieve high top speed. Although there is no outright top speed limiter, the ecu starts to close the throttle as higher speeds are achieved. The following link is to testing I did last year on this very issue. You will notice in the data logs how the throttle physically closes.
http://www.ft86club.com/forums/showthread.php?t=58835
2013 Lightning Red - 6MT Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler |
| The Following 2 Users Say Thank You to brn12345 For This Useful Post: | flippy (04-30-2015), Turdinator (05-01-2015) |
#63 |
Drives: 2013 GBS BRZ Limited
After my comment above I pulled out RomRaider and looked at a stock ROM.
Amaya was 100% correct: The soft limiter is set at 137 & 140. |
| The Following 2 Users Say Thank You to stugray For This Useful Post: | Amaya (04-30-2015), Hyper4mance2k (04-30-2015) |
#64 | |
Panda Trueno
#65 | |
Drives: '23 BRZ Limited
And the lower revs would require more throttle input to maintain the same speed. It's really not that big of a difference either way. Turn your stereo up, or put a nice exhaust on the car. |
#66 |
Panda Trueno
Because in sixth maintaining cruise at 70-75 requires a ton of throttle input right?
You're right, it really isn't that big of a deal, I was saying in an ideal situation. I haven't even seen rear gears available besides higher ratios, and no trans gearing changes. It seems to me a lower ratio rear with as many turbo vehicles are out there would be almost common. |
#67 |
Drives: series.Blue
So what is a soft limiter, spark cut? Normally that's what soft limiters are referred to as.
#68 |
Drives: 2014 GT86
Imho spark cut would result to too quirky 'cut' at that speed. And why would one use it, if throttle is drive by wire, and ECU simply may set it to position it needs to not go over limit? Think of it as high-speed cruise control, lol
#69 | |
Throttle "limiter" set to close throttle plate partially in at 140mph ie close throttle till 137 mph then allows throttle to open futher again Fuel cut limiting at over 200mph , unlikely to ever hit that one stock RPM limiter stock at 7400 unlikely to hit that in top gear on stock car. all can be adjusted via tune tables. |
| The Following User Says Thank You to steve99 For This Useful Post: | stugray (04-30-2015) |
#70 |
Drives: series.Blue
That was my point. Soft limiters are spark cut. So it sound's like we're ECU limited to 140 with the stock tune.
| The Following User Says Thank You to Hyper4mance2k For This Useful Post: | etherdude (04-30-2015) |
| Coilover options capable of slightly increasing ride height. | Mechazawa | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-31-2014 02:23 PM |
| Decreasing Wheel diameter while increasing the width | BlackMagicSir | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-01-2013 10:58 AM |
| Damn 86 increasing in price in Taiwan next year... | tnkw | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 10-16-2012 05:59 PM |
| Increasing torque with out forced induction | BigFatFlip | Engine, Exhaust, Transmission | 54 | 05-17-2012 09:03 PM |
