#15 | |
much slow
Drives: 13 Raven FRS, 05 Rio Yellow S2000
Follow steps 1-2 on http://www.ft86club.com/forums/showt...terior+removal Once you get all the covers off, you'll see the bolt holding in the stock seat belt mounting point, you want to reuse that one with the rallye 3 |
#16 | |
Drives: FRS?
#17 |
@klittl06 @BAMF86 thanks gents, any advice on how to manage the white popclips in part 2? Potentially losing them and creating a rattle in the rear has me a bit concerned.
Also, did you guys re-use the OEM bolts or the one included in the kit?
#18 | |
much slow
OEM bolt works fine for the mounting point, just don't have a passenger use the rear seatbelt while the harness is in use |
| The Following User Says Thank You to BAMF86 For This Useful Post: | 1Cor10:23 (06-05-2015) |
#19 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
I lost one of those pop clips in the chassis somewhere
![]() My only recommendation is to buy extras and be cautious. |
#20 |
Drives: 2013 brz limited
How about DD? Comfortable if u use OEM seat belts?
#21 |
@BAMF86 @Kostamojen to clarify, should the white clips remain on the frame or on the trim piece itself.
Also, is removing the trunk liner (2 black pop clips) in step 2 necessary for this? Thanks! Edit: or is it the large trim piece below the triangle piece (around the seatbelt mount) that can get loose / apply pressure to this?
#22 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
They can be pushed out of the way easy also the rear attachment has a disconnect that can be used to allow the belt to lay down to the sides should you feel the need.
#23 | |
#24 |
| The Following User Says Thank You to Kostamojen For This Useful Post: | ZHoward (06-06-2015) |
#25 |
Drives: '14 FRS TT5
Here are the torque specs for the bolts that you need to remove for install and re-torque:
Front seat belt receiver (attached to the seat): 31 ft-lb Front seat outer belt assembly (both the top bolt and bottom bolt on the B pillar): 22 ft-lb Front seat bolts (to the floor): 39 ft-lb Rear seat outer belt assembly (both bolts on bracket on D pillar): 22 ft-lb It took forever to search through the crude FSM's that are available so I thought I would share this info! |
| The Following 4 Users Say Thank You to TMF For This Useful Post: |
#26 | |
Drives: 2015 Brz Blue Series
Even with warning, I also dropped a clip during re-install of cover. Clips easily slips out of cover due to slot. Hindsight would be to place small piece of tape over slot in cover to prevent clip from sliding out. |
#27 |
Drives: 2017 BRZ
Hey guys, bringing this back but I'm having trouble with the rear driverside passenger seat belt bolt. I can thread the bolt loose or tight. I'm able to turn it quite easily both directions but when I try to tighten the bolt back in its having touble finding the threads. This is with and without the schroth belt bracket. Alll I can think about is that the bolt isn't lining up in the hole but it's not working. Any tips?
#28 |
Drives: 17 BRZ Series.Yellow
Wondering if this set up is actually approved by Schroth? I can't find the approval anywhere.....
Sent from my Pixel 3 using Tapatalk |
| Schroth Rallye 3 4-point ASM Harness (Black) | smbstyle | Interior Parts (Incl. Lighting) | 5 | 03-09-2015 01:09 AM |
| Making My Own Harness Pad(s) Pictures Inside | FRS_FIEND | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-28-2014 09:20 AM |
| **JAPAN TOM'S LED Tail Light for FRS / 86/ BRZ - INSTALLED PICTURES INSIDE!! | nigel-jdmparts | Exterior Parts - Lighting | 88 | 04-10-2014 07:49 PM |
