Old 04-21-2015, 05:34 PM   #43
Joshwahhhs
Joshwahhhs's Avatar
Drives: 2013 Asphalt FRS M/T
Originally Posted by Teseo View Post
I drive with one hand its more easy to countersteer. When i take the curves the car dont drift nor grip.
Some folks call me God Hand
Brb gonna duct tape my hand to my steering wheel
Joshwahhhs is offline   Reply With Quote
Old 04-21-2015, 05:47 PM   #44
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by Vroomin86 View Post
Just because your friends lay their hands on it and nothing has gone wrong doesn't mean physics doesn't apply here. The transmission gives off a natural vibration on the stick shift. Your hand being on it, wether rested or forced believe it or not is a force against those natural occurring movements therefor wearing out the items described in the LONG TERM. Nothing you'll notice at 17K miles.
...or 170K miles!
billwot is offline   Reply With Quote
Old 04-21-2015, 05:51 PM   #45
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by Packofcrows View Post
yesterday I noticed I have a habit of now resting my right hand on the e-break and clicking in n out the knob? aka button.
When I FIRST got the car I found myself playing around with the reverse lockout a lot.
After I caught myself ONE TIME shifitng into reverse while still moving forward I STOPPED DOING THAT!
I realized what I was doing before I let the clutch out but it was close.
The Following 2 Users Say Thank You to stugray For This Useful Post:
Bonburner (04-22-2015), ToySub1946 (04-21-2015)
Old 04-21-2015, 06:02 PM   #46
Philly758
Drives: GMC
Will resting your hand on the shifter void your warranty?
Philly758 is offline   Reply With Quote
The Following 2 Users Say Thank You to Philly758 For This Useful Post:
Error (04-21-2015), JoeC (04-22-2015)
Old 04-21-2015, 06:11 PM   #47
billwot
Originally Posted by Joshwahhhs View Post
Do you guys usually rest your hand on the shifter? I heard the extra weight is bad for the transmission.
And if the weight is bad for the transmission, what about a weighted shift knob?
The shifter is actually well behind the gearbox itself, and connects to the shift forks by means of linkage rods. You could stand on the shifter and it would not apply any load to the tranny internals.
Early automotive gearboxes were "top loaders, with the shifter mounted on a plate on top of the tranny, and connected to the shifter forks directly.
Every modern gearbox that I know of is actually "controlled' by a series of linkages connected to a "remote mounted" shifter, like our cars.
Here is a pic of the Aisin gearbox as used in the twins. Note the rear-mounted shifter.
Old 04-21-2015, 07:42 PM   #48
Ultramaroon
fabulous
Ultramaroon's Avatar
Won't start popping out of gear until well after that point.
Driving like an asshat with a stone cold engine won't void the warranty either.
Old 04-21-2015, 07:52 PM   #49
chas3wba0
chas3wba0's Avatar
Drives: Yes
Every modern gearbox that I know of is actually "controlled by a series of linkages connected to a "remote mounted" shifter, like our cars.
Good reference pic, but I think the paranoia comes from the hand pressing down on the shifter while it is in gear (angled), which would hypothetically create friction between the fork/sleeve interface, no?
Anyway, I can see how it's not the perfect way to operate this piece of machinery, but I'm also not really worried that "resting" my almost weightless hand (I have an armrest that I actually lean most of my weight on) is doing any damage. There's plenty of feedback from the shifter to let you know when you're actually causing friction.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 04-21-2015, 09:05 PM   #50
billwot
...and if you look closely at the shifter area of my pic, you will note that there are actually mechanical stops that limit the forward and reverse travel of the shifter. Even if you did pull on the shifter while traveling, the force would be applied to the mechanical stop, not the shifter forks.
I suspect all linkage-operated shifters have stops. I know both of my MR2s did.
Old 04-21-2015, 09:25 PM   #51
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Buying an A/T was great. Saved me money on an armrest too
If just puttering around in traffic I find it quite comfortable to rest my palm on the shifter. It all comes down to how far forward or back you sit. I sit 2 or three clicks (on the seat rails) from the back and can't seem to find any other comfortable place for my arm. Even if I were to have an arm rest installed. Two hands on the wheel, unless in attack mode, is just not comfortable in general cruising.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 04-21-2015, 10:47 PM   #52
ic-racer
Drives: frs 1.0
The only thing I have noticed is how cold the shifter is. The other front engine cars I have had from the 70s and 80s heat up the shifter shaft and knob pretty well.
ic-racer is offline   Reply With Quote
Old 04-21-2015, 11:54 PM   #53
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
This assumes that you are not putting any side thrust on the shifter, which is what actually causes the wear. Due to the position of the shifter relative to your arm/shoulder you almost cannot avoid putting a thrust load on it.
Caspeed is offline   Reply With Quote
Old 04-22-2015, 01:24 AM   #54
Vroomin86
Drives: 2015 Fire
I am pretty sure if you tugged on the shift knob while it is in gear like we are talking about it would do a lot more damage than just applying force to this mechanical stop. You mean to tell me unless we press the clutch you can't get the car out of gear even if we stood on it ?
Vroomin86 is offline   Reply With Quote
Old 04-22-2015, 03:41 AM   #55
fitcious
two ways to solve this while resting your hand/arm...buy an automatic or buy the freak'n arm rest
fitcious is offline   Reply With Quote
Old 04-22-2015, 09:39 AM   #56
billwot
Look at the pic! There is no way moving the shifter from side-to-side transmits any force or motion to the linkage that actually moves the shifter forks. The linkage rods ONLY move forward and backward, never from side-to-side.
Search this Thread:
Advanced Search
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 09:20 PM
Shifter springs/bushings/shifter performance Darnold Engine, Exhaust, Transmission 10 10-23-2014 12:49 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 02:24 AM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 03:27 PM
