CANADA Canada
Old 05-28-2015, 10:30 PM   #29
Bergen23
Drives: '15 Halo FR-S
Tempted to get the @Mishimoto kit. Not that I need it, but the bling factor is off the charts.
Bergen23 is offline   Reply With Quote
Old 05-28-2015, 10:31 PM   #30
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
@RFB and the Stark performed excellent too????
drewbot is offline   Reply With Quote
Old 05-28-2015, 10:54 PM   #31
RFB
RFB's Avatar
Drives: FRS
Absolutely ! A big rad also.
This time a new ENEOUS flush and refill instead of drain and top up. Tried both auto and paddles, both excellent all day, no bad effects like my last Mosport big track, but smooth, fast gear changes, and rev matching.
I am confident I can do the yearly drain and top up from now on.The savings in fluids will pay for both kits.
Both kits stupid simple to install (just grunt work).
RFB is offline   Reply With Quote
The Following 2 Users Say Thank You to RFB For This Useful Post:
drewbot (05-29-2015), Stark Performance (05-30-2015)
Old 05-28-2015, 11:15 PM   #32
toraider
Drives: Subaru
Originally Posted by wbradley View Post
Anyone have experience with the CX Racing? It looks to be about $550.00 CDN$ including shipping and appears to be a 19 row. I dont mind assembling the hoses to save $300!
I spent about $590 CDN for a 19 Row Series 6 Setrab Core and T-Stat Mocal Sandwich Plate shipped to Niagara Falls, NY. As an alternative a 15 Row Series 9 Setrab core was available as well.
I don't have any experience with CX Racing and I have no idea whether this is a great kit or not, but the 2 questions to consider is who makes the 19 Row core and what Sandwich Plate (T-Stat or not) is being offered.
toraider is offline   Reply With Quote
Old 05-29-2015, 12:00 AM   #33
wbradley
Sarcastic SOB
wbradley's Avatar
That sounds like a good deal. The intercooler they installed today is a fair bit bigger than the standard one that comes with my HKS system. I need to figure out what size and where I will locate the oil radiator when I get my car. I don't mind setting up a temp mailbox in Niagara Falls. Just have to unbox everything and put it in the spare tire storage to avoid 13%. Where did you buy your cooler from?
Old 05-29-2015, 12:47 AM   #34
toraider
Drives: Subaru
Bought through Maximal Performance - http://www.ft86club.com/forums/showp...17&postcount=5
I use these guys for my deliveries. http://kuhnsstorage.com/
They aren't the most flexible in hours or operations, but they are affordable and I've never had a bad experience with them. Best part is I can usually get over the boarder and back in 15-20 mins
The Following User Says Thank You to toraider For This Useful Post:
wbradley (05-29-2015)
Old 05-30-2015, 10:58 AM   #35
Skurj
Drives: SOLD...
Originally Posted by RFB View Post
The Mishi leaks after install and needs re-tightening when stacking tolerances, heat expansion cycles, etc, etc, happens, like lug nuts.
But Mish warns to check for seepage periodically iff'n you WOT ALOT, just in case.
Is this to be expected regardless of the manufacturer? I don't want to have to be pulling the bumper cover after every lapping day if I can help it...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 05-30-2015, 04:51 PM   #36
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Just add some Teflon tape and put your mind at ease. The AN fittings are very good, they may need reltght ending once after the first heat cycle but that should be it.
TRAKRAVN is offline   Reply With Quote
Old 05-30-2015, 07:54 PM   #37
RFB
RFB's Avatar
Drives: FRS
ALL need checking after install, and re-tighten. Then look at the fittings under the oil filter, DO NOT remove the bumper, just lift the hood, you are looking for seepage UNDER THE OIL FILTER, AND FITTINGS.
My central bolt and the sandwich plate fittings had to be re-torqued after about 50 miles.
To check for rad seepage, look through the grill and you can clearly see the oil rad and fittings. The rad fittings were tightened with a torque bar, we did not retighten, and it did not seep.
I ran a hot day, all day Formula I track, checked at every pit stop and all fittings were fine.
Teflon tape is controversial, we used NO sealant of any kind and all is good.
Old 05-30-2015, 08:22 PM   #38
Skurj
Drives: SOLD...
Going to be running the GP track at Mosport July 4 and 5.. don't have a cooler yet and its unlikely I will have one before then, but its on my must have list... Like to have someone install it and stand behind it...
Paid for Mar 2018
Old 05-31-2015, 01:14 AM   #39
wparsons
wparsons's Avatar
I'd call iGarage or CanJam, both should stand behind the install.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
FRSCanuck (06-02-2015)
Old 05-31-2015, 12:20 PM   #40
RFB
RFB's Avatar
Drives: FRS
Any idea what they would charge ?
Old 05-31-2015, 12:30 PM   #41
Koa
Sweeper
Koa's Avatar
CX Racing's cooling options, at least the fabled NASIOC Ebay radiator (to which CX Racing is a main importer of) are one of the few "budget" critical systems components I would consider. Note I do NOT have first or third-hand knowledge about their oil coolers, so this is an incomplete testimony.
Here's a very detailed thread about their radiators. One big thing to note is the required mod most will say: Teflon tape the damn drain plug
Have had the same radiator in my WRX, boosted to 18psi on a TD04 running E85 and 93oct, for years. NO leaks. All aluminum tank. Was $150 new on the bay
http://forums.nasioc.com/forums/show....php?t=1173261
(CX Racing convo starts on page 3)
The Following User Says Thank You to Koa For This Useful Post:
wbradley (05-31-2015)
Old 05-31-2015, 12:47 PM   #42
wparsons
wparsons's Avatar
No clue, sorry!
flickr
Search this Thread:
Advanced Search
Robi-Cooler Install....Oil Temps under 180??? Deep Six Engine, Exhaust, Transmission 28 08-07-2014 01:30 PM
Perrin Oil Cooler Install & Snorkel Mod BC-Boy Engine, Exhaust, Transmission 4 05-14-2014 12:06 PM
Help! Oil Cooler Install brillo Tracking / Autocross / HPDE / Drifting 13 07-17-2013 05:55 PM
Perrin Oil cooler install review LeeMaster Engine, Exhaust, Transmission 3 03-14-2013 11:41 PM
Any Portlanders bored tonight? Help install oil cooler? stockysnail Northwest 2 03-14-2013 01:15 AM
