#29 |
Drives: 2015 FRS
This happens to me too only when the engine is cold. As soon as it gets to its operating temperatures I can't replicate it.
#30 |
Drives: 2014 Whiteout FR-S MT
I get it when I drive on 5+ hour trips. It's exactly what you guys say it is, like a gear whine. If I'm on the throttle then there is a whine. If I apply more throttle it gets louder. It's quite annoying on long trips, but I think my head just tones it out. No mods whatsoever.
#31 |
- It seems most noticeable in 6th and 4th, but it's also there in 5th , just quieter. Makes make think that it's present in all gears, but you really notice it when your speed is steady.
- Noise is gone when taking it out of gear on the hwy at 60-70 mph and revving the engine. - I have an aftermarket intake and the soundtube is disconnected from the intake and the opening sealed with an aluminum foil, so definitely not the source - I had my steering wheel replaced at the dealer in the week the noise started, but I can't possibly see the connection. - the noise is louder, different pitch and affects much broader rev range than the diff whine. I got the Whiteline inserts on the rear subframe and there's very subtle diff whine at 65-70mph in 6th gear. |
#32 |
Drives: 2013 Raven FR-S
did you buy your car used? perhaps the previous owner installed whistle tips. might want to check. in case you aren't familiar...
[ame="https://www.youtube.com/watch?v=eSOSJ68xOBA"]Whistle Tips with Bub Rub - YouTube[/ame] |
#33 |
Drives: 2014 Whiteout FRS
Anyone ever figure out what makes this noise?
It is so loud at exactly 80MPH, if I accelerate to 81-82MPH its much more quiet or decelerate below 80MPH. Also, the noise is much more apparent when looking out the windshield versus turning my head to the left or right while sitting in the driver seat. I am contemplating just replacing all the bushings with much firmer ones, if the car is already this loud I might as well get some performance gains from stiffer ones. My daily commute is 40 miles on an interstate, so I am constantly at the 75-80MPH range. I don't know how much more I can take. |
#34 | |
Drives: 2015 BRZ Limited
Edit:Here's the right thread. Mine happens around 69-70mph, and I can also hear it a bit at 35mph. It seems like it's toward the rear of the car, and the pitch does NOT seem to vary with speed (and over the 2mph range I can hear it it should cover ~10JNDs of pitch). My current theory is a harmonic of the wheel spokes driving a high-Q resonance somewhere, but I haven't gotten a clean measurement of the tone frequency or done the math on the spoke frequency. Can you hear yours at 40 at all? Last edited by inio; 07-14-2015 at 12:13 AM. |
#35 | |
Drives: Whiteout
#36 |
Stuck like Glue
Drives: WRB BRZ Limited
I too recently heard this sound on my car while driving on the interstate. I've heard this noise only a couple of times in my car but this is what I noticed:
- Happens only when the vehicle is in the 6th gear - Happens only when I'm on throttle, it goes away when I let off throttle - Have heard the noise only above 3,000-3,500 rpm It sounds more like a gear whine, but maybe called a whistling noise too. When I heard this noise the first time I really thought one of my windows was not fully closed (if this gives you an idea as to how the noise sounds). The other thing was I recently cracked my front windshield above the rear view mirror mounting point and I thought that may be the source of the wind noise, but nope, then it should happen in all gears. The whine is a faint high pitched tone. It's making me think it's a gear related issue. I don't think this is an 'issue', it's just something that we may have to live with. Anything else you guys suggest I should check other than the ones mentioned in this thread? FYI, I'm running a Perrin Catback exhaust as my only mod (other than tires and brake pads). But I have been running this for almost a year now. |
#37 |
Racing Enthusiast
Drives: Bone stock 2019 BRZ manual
Guys, this sound is completely normal. I believe it comes from the differential, and I actually enjoy it. If it's getting too annoying, you could check the diff bushings, but it is absolutely nothing to worry about. You'll notice the same sound from e46 gen 3-series BMW's, that's my only experience with a car that whines a bit.
But, I repeat, this is normal and nothing to worry about. I was actually considering getting a solid diff-riser to eliminate the rear axle-angle issue, but a solid mount would magnify that whine like a racecar. This is what it sounds like magnified at lower speeds: [ame="https://www.youtube.com/watch?v=I1NTNzWBFy0"]FR-S Differential Riser Sound - YouTube[/ame]
“$20 per diddle? I can diddle myself for free and do a fine job”
#38 | |
Drives: Whiteout
#39 |
The Fail Boat
Drives: CWP S.B.
sometime this car just makes so much noise that i don't know what's going on. =.=
Was pushing the car in GMR yesterday, then i noticed my engine sound really different.... let the car rest a bit then it sounds the same again........ |
#40 | |
Racing Enthusiast
On our cars, it is much more noticeable in 6th gear. Specifically at interstate speeds, if you feather the gas pedal, you will hear it go on and off. You can't hear it at lower speeds because the differential is not spinning near as fast. In the video I posted, the differential is on a solid mount, so the sound is magnified, making it audible at all speeds. If you feel like looking into it, go ahead, but I do promise it is normal.
#41 |
Drives: FRS
Has anyone figured out yet? Is it really something I have to live with? This started happening and driving me crazy. It is so annoying. My mpg went down by 2-3 mpg too.
#42 |
Drives: 2013 frs
I was googling as im getting this. Along with p0420 code and catless header. Mine is only while starting off, first or second. At 1000-3000rpm, It does sound like a trans gear whinding up weird to me but have to stop being so paranoid, have a feeling these cars will last a long time.
Anyways heres a good link! http://www.theglobeandmail.com/globe...service=mobile
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
| Faint Honking sound | Raven604 | Issues | Warranty | Recalls / TSB | 117 | 07-14-2023 06:04 AM |
| Whistling sound..? | tintumz22 | Issues | Warranty | Recalls / TSB | 34 | 11-21-2015 09:54 PM |
| not very loud, but high pitched sound at 70+mph | fiveoneoh | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 10-16-2013 11:30 PM |
| High pitched whine from sound tube and idle jumping | Nourdmrolnmt1 | Issues | Warranty | Recalls / TSB | 0 | 04-18-2013 12:00 AM |
| TSB - FRS (re: High pitched chirping...) | PNW FRS | Issues | Warranty | Recalls / TSB | 1 | 01-19-2013 02:05 AM |
