Old 08-10-2016, 06:23 PM   #99
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by TRAKRAVN View Post
From the bottom of the pinch weld to the top of the shortest block is about 1.5" in the front of the car. So I'd say you could lower it about 1" with the BL-7000 and 1.5" with the BL-5000 since it's about 1/2" shorter.
Great! because i am going to drop about 1.2 inch all around.
I will update thread when i install it in Sep
Old 08-10-2016, 08:27 PM   #100
TRAKRAVN
Drives: 2015 Scion FRS - Raven
You could always go lower and drive the car up on a 2x4 then slide the BL-7000/5000 in from the sides instead of driving over it and pulling it out.
TRAKRAVN is offline   Reply With Quote
The Following User Says Thank You to TRAKRAVN For This Useful Post:
zc06_kisstherain (08-12-2016)
Old 05-13-2017, 03:29 PM   #101
ft86me
ft86me's Avatar
Drives: 2013 FRS
Height of the unit
So those of you with the 5000slx, how has it been working out for you ? Also , how tall is the unit when fully collapsed ? My car is lowered and have sideskirts so I'd like to do a measurement before purchasing.
ft86me is offline   Reply With Quote
Old 05-13-2017, 07:02 PM   #102
TRAKRAVN
I have the 7000SLX and it's great. I wish I would have bought it a long time ago.
For lowered cars I just sandwiched two 12"x12" peices of 1/2" plywood (1"total height) and use those as a spacer for each tire. Then I slide in the Quickjack from outside the car. It still keep everything small and portable.
My 7000 is 3.5" and the 5000 is 3"collapsed respectively.
The Following 2 Users Say Thank You to TRAKRAVN For This Useful Post:
ft86me (05-16-2017), SPCorBUST (05-13-2017)
Old 05-13-2017, 08:58 PM   #103
cjd
cjd's Avatar
Drives: 2017 BRZ
I was at about the minimum usable height with a 36mm drop for the 5000slx... Clearance + the required half inch on the lowest blocks. Works really well. I have to lift sideways when doing an alignment to fit between platforms, but its awesome to have.
cjd is online now   Reply With Quote
The Following User Says Thank You to cjd For This Useful Post:
ft86me (05-16-2017)
Old 05-16-2017, 12:07 PM   #104
zc06_kisstherain
Drives: SWP BRZ
i have 5000slx and i am dropped 1.2 all around and have sti side skirts as well. no problem at all
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
ft86me (05-16-2017), Sportsguy83 (05-23-2017)
Old 05-22-2017, 07:21 PM   #105
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Originally Posted by Ec1990 View Post
Awesome. I figured using a jacking point anywhere along any part of the pinch weld wouldn't really be an issue.
it works because the weight is distributed along the whole rail. I would not jack at any point other than the 4 spots with a regular jack or jack stands.
Ernest72 is offline   Reply With Quote
Search this Thread:
Advanced Search
Car for $5000? dem00n Other Vehicles & General Automotive Discussions 35 01-08-2014 04:44 PM
FS: 2013 White out Manual FRS under 5000 mi Matt Andrews Cars for Sale/Trade 17 12-09-2013 02:00 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) -- General Topics 20 08-22-2013 01:55 PM
Anyone else above 5000 miles too? Superhatch BRZ First-Gen (2012+) -- General Topics 32 06-28-2012 01:08 PM
5000 to spend on what? MtnDrvr86 Other Vehicles & General Automotive Discussions 29 03-18-2010 05:10 PM
