#267 |
Ah you must have the PMD header instead of the PLM.
#269 |
Yes sir! PMD will tell you more about it. That's the reason theirs cost about $300 more than the PLM.
#270 |
That would be the third pic, runs 5 - 6. My best tune without wayno's additions. The torque dip isn't easy to tune out without a dedicated dyno. Get a supercharger. It completely eliminates torque dips. If I ever eliminate the torque dip on my car before I get my ESC, I'll post the Intake and Exhaust "safe" tables to put into your tune. I hate that torque dip with a smoldering resentment, like "How could they?". It's an insult to this fine automobile.
| The Following User Says Thank You to KoolBRZ For This Useful Post: | Koa (06-17-2015) |
#271 |
Drives: 2013 brz limited
Anyone PLM header can fit OEM air box? For me I think it is not enough space
#272 | |
Drives: '13 10 Series FRS #1203
The larger resonating chamber in the intake does get quite warm. There may be a chance of it melting under really heavy repeated load. However a full drift day in 90* heat and I did not have a problem. I will be getting an aftermarket intake at some point however. |
#273 |
VE spreadsheet calc's anyone
I went to http://www.otctools.com/ve to calculate VE on my best run. Not good. Best at full throttle, top speed was 77%. High IAT was definitely a factor. I'm going to find the calculations to do a quick and dirty VE to include in a spreadsheet that I can paste my logs into. That will at least help me tune out the torque dip by increasing the VE in the bad areas. Here are some pics illustrating the bad areas.
#274 |
Shadetree Project Ratchet
Drives: series.Blue
P.M.D. Header Dyno test results linked below.
[ame="https://www.youtube.com/watch?v=muAt4evb7Sk"]P.M. Dawn - Set Adrift On Memory Bliss (16:9 HD) /1991/ - YouTube[/ame] edit: This is what happens if you don't buy PMD. Apparently the part dies without you... [ame="https://www.youtube.com/watch?v=C_qWlPCEnGM"]PM Dawn - I'd Die Without You - YouTube[/ame]
The Shadetree Project: I turn wrenches
#275 | |
Can u post pic? Thanks Sent from my iPhone using Tapatalk |
#276 | |
Sweeper
#277 |
#278 |
I have to admit while I love the sound of the header at natural revs, under a heavy load they sound like shit..
I just spent the night replacing and trying to find an exhaust leak, there does not appear to be one so I can only assume its the headers making noise from being "thin" and probably a shitty merge collector. I'm going to play around a bit more and see if I can track it down, otherwise I'm going to attribute it to header noise. The higher pitch sound at high RPM's doesn't bother me. I think these headers make the exhaust itself sound quite exotic with my TRD catback. I just can't stand going past buildings and hearing a "ticking/rattling" noise under load from the header. |
#279 |
#280 |
| Tags |
| cheapbastards, dbags, knockoff |
| (Irvine / SoCal) ForSale FA20Club Long Tube Catted Header $350 | mad_sb | Engine, Exhaust, Bolt-Ons | 12 | 03-31-2015 12:53 PM |
| wtb: sound tube delete inlet tube | Jimmy817 | Engine, Exhaust, Bolt-Ons | 1 | 12-21-2014 10:15 AM |
| Long tube catted headers possible? | wparsons | Engine, Exhaust, Transmission | 6 | 01-31-2014 10:56 AM |
| New 4-2-1 Long Tube Header | Anorexic 86 | Engine, Exhaust, Transmission | 28 | 08-25-2013 04:28 PM |
| Cinco de Slamo Meet in Long Beach NY (Long Island) | whitefrs | New England | 11 | 05-01-2013 10:03 AM |
