Old 04-08-2015, 07:15 PM   #1
SpeedFromSwede
SpeedFromSwede's Avatar
Drives: WRB BRZ
3 turbo 2JZ 86
Anyone seen this? https://instagram.com/p/03cf1lhmmh/
SpeedFromSwede is offline   Reply With Quote
Old 04-08-2015, 07:16 PM   #2
raven1231
Why?
Old 04-08-2015, 07:29 PM   #3
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
For the same reason some dudes watch shemale porn; some people get off from sheer shock factor.
nastynate88 is offline   Reply With Quote
Old 04-08-2015, 09:53 PM   #4
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Oil money and because they can. Not the first time a tri-turbo setup has been done on a 2jz. It's plainly for show.
hmong337 is offline   Reply With Quote
The Following 3 Users Say Thank You to hmong337 For This Useful Post:
kch (04-08-2015), SpeedFromSwede (04-08-2015), strat61caster (04-08-2015)
Old 04-08-2015, 10:57 PM   #5
strat61caster
strat61caster's Avatar
Nah shock factor is only why you watch it the first time.
Every time after that it's because 'more genitals' > 'fewer genitals'.
More turbos > fewer turbos.
ineedyourdiddly
ScionOfHorus (04-09-2015)
Old 04-08-2015, 11:20 PM   #6
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
That paint/wrap job
V_86 is offline   Reply With Quote
Old 04-08-2015, 11:49 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I am disgusted. 3 is such an odd number, if your going to go balls to the wall, why not 4 turbos? why not 5...WHEN DOES IT END?!
Old 04-08-2015, 11:57 PM   #8
kch
Senior Misanthrope
kch's Avatar
TWIN TURBOS PER CYLINDER
Old 04-09-2015, 12:01 AM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
hmong337 (04-09-2015), raven1231 (04-09-2015), ScoobsMcGee (04-09-2015)
Old 04-09-2015, 12:22 AM   #10
swarb
purple coilovers? D2?
Old 04-09-2015, 12:36 AM   #11
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Why?
That's why, to bother you.
It's nicely executed at least so I have no axe to grind. He could have done more, though.
Old 04-09-2015, 01:24 AM   #12
WesleyG
Drives: 2014 Satin White Pearl GTS auto
I can have all the boost
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 04-09-2015, 05:52 AM   #13
Tbird232ci
Drives: 2013 FRS
Beautiful example of compound turbos.
Tbird232ci is offline   Reply With Quote
Old 04-09-2015, 05:13 PM   #14
themadscientist
Hotlink Terrorist
Can you imagine the pipe run under those screws?
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
FS:A Garrett turbo,& a Greddy turbo kit with extra parts. Cessblood Engine, Exhaust, Bolt-Ons 76 02-18-2015 08:47 AM
Toyota Trademarks: D4-S Turbo, More turbo, 9 Scion Names Veloist Off-Topic Lounge [WARNING: NO POLITICS] 9 08-27-2014 11:29 PM
