Old 04-06-2015, 01:27 PM   #1
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Custom Valved Koni Front Struts and Rear Shocks
Shocks and Struts are SOLD
Well, I'm not competing the BRZ in SCCA CS this year and won't be needing my custom Koni's. The rears are 2 year old OTS Koni SA's that have been recently refurbished and custom revalved by Koni USA. They have 2 weeks of street use on them since the refurb. The fronts are brand new SA full struts also custom revalved by Koni USA. They have never been installed.
The valving was set by Koni based on my intended use description - SCCA street class autocross - aggressive low speed compression and rebound damping with the most digressive damping possible in these bodies. While I did ask for plots with the revalving, I guess I should've been more 'lawyerly' because what I got were traces right off the plotter with no units/numbers/etc(!). These are pictured below. Qualitatively, (1) there is no cross talk on the rebound adjustment to the compression side, (2) the compression side is REALLY digressive, (3) there is a LOT of fairly digressive rebound adjustment to work with, and (4) they are well matched R-L.
It's been two years, but when I switch from stock to OTS I didn't notice much, if any, difference on the street. Even with just the rears, I definitely notice a difference between these and OEMs.
Koni's quote for the package was $1270, but they came in a little lower - I'm pricing them at $1050 OBO delivered to the lower 48. Shocks and Struts are SOLD
A few pics:
Last edited by jdrxb9; 04-24-2015 at 05:26 PM. Reason: added OBO to price / [B]Shocks and Struts are SOLD[/B]
jdrxb9 is offline
Old 04-10-2015, 08:48 PM   #2
jdrxb9
jdrxb9's Avatar
I had a question/concern about the spring seats and the apparent corrosion on them. These did go through two PA winters and the seats did pick up a fair amount of surface rust. They still seem solid to me. Replacements are reportedly available from Koni if you are uncomfortable with them. Here are a couple more pics of one after I spent about 5 minutes cleaning it up with a wire wheel (and with the pic taken in better lighting):
jdrxb9 is offline
Old 04-11-2015, 08:53 PM   #3
AFRichZC6
AFRichZC6's Avatar
Good luck with the sale!
I wish these were available last month when I purchased Koni dampers. Now that I've driven on OTS Koni struts and shocks, I kind of want them revalved.
AFRichZC6 is offline
The Following User Says Thank You to AFRichZC6 For This Useful Post:
cactus (04-12-2015)
Stock rear shocks / struts gone at only 40,000 miles? Black Tire Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-21-2019 12:52 PM
WTB: Koni Shocks/Struts from a retailer in Canada BRZZZZZZZZZZ Canada Classifieds 11 03-10-2014 09:44 AM
GB: Koni Sport Yellow Shocks/Struts - CRAZY PRICING - FREE S&H - IN STOCK! AJ@ECSMotorsports Groupbuys 13 09-15-2013 09:21 AM
FS: Koni Yellow Struts/Shocks front-rear set never used Kinzo Brakes, Suspension, Chassis 5 06-10-2013 09:36 PM
Tein Street Basis coilover, Koni struts and shocks JoeBoxer Brakes, Suspension, Chassis 6 12-25-2012 10:43 AM
